| PBC914 |
Jul 9 2012, 08:54 PM
Member ![]() ![]() Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
For Sale: 1975 Porsche 914 1.8L. VIN# 4752911171 built on 8/75. Over 122,000 914s produced, Only 6,512 1975 1.8 litre cars produced.
Original engine, engine number EC045076, Chassis # 3349019, Original transmission, transmission # HA22014, original Bosch L-Jet fuel injection. Car was purchased new from Art Bunker Porsche Audi in Overland, KS on September 25, 1975 by Edward Lange. Car is Malaga Red (paint code L30C) with original white interior (cream colored), oatmeal colored carpeting. Appearance group-Clock, Volt and Oil Temp gauges with original Mahle wheels. Factory fog lights and factory sway-bars. Spare tire is a Mahle wheel with the original factory installed Michelin tire. Original owner had the dealer installed air conditioning, which has since been removed from the car. Sold with original owner's manual. Car has had 4 owners including me. Comes with original dealer brochure for the 914 1975 model year. Battery tray is in very good condition and has been cleaned, primed and painted. Longitudinals have been fixed or replaced as needed with no body sag. Area underneath battery is in excellent condition. Rust-found in the bottom corner of each front fender by the doorjamb (see pictures below). 118,100 original miles. New parts intalled/work completed (over $4,100.00 in new parts and maintenance in less than 1 year, receipts are in chronological order in a 3 ring binder): • New Hirschman antenna installed. • Engine grille PORSCHE letters replaced. • Rear window/windshield seal kits installed. • New jack plug covers. • Alloy center caps (missing in the photos), lug nuts polished. • PRESS stickers for seat belts (believe it or not a minor and expensive touch!). • Front trunk carpet kit installed. • Headlight relay and turn signal relay replaced. • Optima 34R battery and new negative terminal ground strap (original)nBattery clamp bolt not shown in picutre but is attached. • License plate housing light replaced. • Vacuum lines replaced. • Filler neck and oil cap gaskets replaced. • Tool kit (was missing). • New speedometer cable purchased and installed August 2012. • Leather covered steering wheel recovered by Automobile Atlanta. • Replaced faulty reverse light switch. • Replaced interior light and fixed/cleaned door contacts. • New turn signal lenses in front • Replaced low fuel warning light cover (was faded). • Installed new fuel pump. • Removed, cleaned, lubricated driver and passenger side door locks. • Installed correct 1975 Blaupunkt AM/FM cassette stereo deck (cassette adaptor to iPod is readily available) and original Blaupunkt speakers. • New front brake rotors. • Left front caliper replaced. • New front brake pads. • Rear brake pads and seals. • New #3 piston fuel injector and fuel line replaced. • Valve adjustment completed. • New O-rings on oil push rod tubes. • New ignition switch. • New clutch cable installed July 2012. • Oil change completed in June 2012 with 40w oil (dino). • Transmission oil changed with 75W-90 (non-synthetic). • New air filter. All 4 injectors replaced with newly rebuilt injectors from GB. • New factory correct valet key and driver keys obtained and cut. • New/old factory fuel tank replaced, new braided fuel lines, correct fasteners and fuel filter replaced under gas tank. • Clock restored by Palo Alto Speedometer. • Seats are recovered in factory correct cream colored vinyl from Automobile Atlanta. • New heater tubes from engine to longs replaced. • 1st gear and synchro replaced. • Engine was removed, degreased, parts removed, degreased, cleaned/replaced/repainted and re-installed-see the before and after pictures. Battery tray and areas under the battery tray were touched up with primer and paint, otherwise in good condition. New engine bay seals installed. ** Engine pictures are before and after the engine was freshened in the spring of 2012** Attached image(s)
| PBC914 |
Jul 25 2012, 07:40 AM
New photos added as of 7/27/12. Engine pictures are before and after cleanup and freshening of engine.
| BestefarJohn |
Aug 4 2012, 02:12 PM
Newbie ![]() Group: Members Posts: 1 Joined: 29-July 12 From: Indiana Member No.: 14,728 Region Association: None |
Hi, this is John in Indiana. Nice looking vehicle but a little more than I want to spend. I hope there is some flexibility in pricing. |
| SUNAB914 |
Aug 6 2012, 12:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Pretty car!
| mepstein |
Aug 6 2012, 01:40 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,287 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
[/quote] Hi, this is John in Indiana. Nice looking vehicle but a little more than I want to spend. I hope there is some flexibility in pricing. [/quote] If you are ready to buy and want to negotiate price, it's probably a good idea to contact the seller and talk directly with them. |
| PBC914 |
Aug 13 2012, 09:45 AM
This is a great looking and great running 914. There are no engine or electrical issues to sort through-just pay and drive away!
| 914newguy |
Aug 27 2012, 04:57 PM
Newbie ![]() Group: Members Posts: 6 Joined: 11-November 11 From: Moreno Valley Member No.: 13,772 Region Association: Pacific Northwest |
is car still for sale
| PBC914 |
Sep 1 2012, 12:43 PM
The car remains for sale.
| PBC914 |
Sep 20 2012, 10:53 AM
Car is still for sale. Please PM me with specific picture requests. I just enjoyed 400 mile round trip in the car and it ran flawlessly!
| PBC914 |
Oct 1 2012, 03:13 PM
deleted
| PBC914 |
Oct 13 2012, 07:43 AM
Deleted
| PBC914 |
Nov 8 2012, 11:13 AM
Deleted
| 0396 |
Nov 9 2012, 09:45 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Who ever buys this ride needs to secure the battery down - it's missing the mount / bolt.
| PBC914 |
Nov 9 2012, 11:03 AM
The battery bolt and clamp are there, not shown in the picture.
| RFoulds |
Nov 9 2012, 04:42 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 861 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
PM sent. requesting pics of:
Close up of rust at bottom of fender. close up of worn upholstery, top of each door. pic of repair or hole from A/C condensor removal. Or is it still there? pic of inside rear trunk area, especially closest to rear floor between tail lights. thanks |
| RFoulds |
Nov 10 2012, 08:52 PM
Hey there. Buyer with cash in hand Trying to get your attention. (IMG:style_emoticons/default/smile.gif)
| PBC914 |
Nov 12 2012, 04:41 PM
2 PMs sent with my personal contact information.
| PBC914 |
Jun 18 2013, 01:19 PM
Car is for sale
| PBC914 |
Jun 26 2013, 07:58 PM
Reasonable offers considered. Thanks for looking.
| PBC914 |
Jun 29 2013, 09:22 AM
Bump
Lo-Fi Version | Time is now: 14th December 2025 - 04:58 AM |
