3 Pages V  1 2 3 >
> Boxster Wiper Motor
McMark
post Jul 17 2012, 02:13 PM
914 Freak!
Just bought a wiper motor off a 2003 Boxster to see how interchangeable they are with ours. Modern speed wipers is on my list of things to make the 914 wife-worthy.
Pictures and thoughts once the part arrives later this week.
*Looked a Boxster seat belts as well. (IMG:style_emoticons/default/idea.gif)
post Jul 17 2012, 02:22 PM
Resident German
(IMG:style_emoticons/default/cheer.gif)
CG-914
post Jul 17 2012, 02:38 PM
good idea if its going to work! (IMG:style_emoticons/default/piratenanner.gif)
I know the 996 motor for the sunroof fits in an 73 911 (IMG:style_emoticons/default/shades.gif)
I just wonder at the steering wheel the wiper switch!!!
I defiantly would not want the boxster switch to replace a good looking 914 one!
aharder
post Jul 17 2012, 02:51 PM
The wiper motor is on my list of to-do's (IMG:style_emoticons/default/biggrin.gif)
I've got plenty on time because the priority rating is sitting @ 99.
mrbubblehead
post Jul 17 2012, 04:41 PM
Twodollardoug
Mike Bellis
post Jul 17 2012, 09:41 PM
Resident Electrician
Thinking about using the VW Passat one on mine. Steering column swap too, along with turn signal stuff...
McMark
post Jul 17 2012, 10:32 PM
914 Freak!
I just bought the bare motor and I'm hoping it will connect to the 914 linkage and be a simple swap, yet still improve upon the stock motor.
scott_in_nh
post Jul 19 2012, 02:04 PM
a couple of good coats of Rain-X + some speed and who needs wipers? (IMG:style_emoticons/default/confused24.gif)
A delay would be nice, but that is a whole lot of work for very little effect imo
post Jul 19 2012, 02:14 PM
Resident German
QUOTE(scott_in_nh @ Jul 19 2012, 01:04 PM) *
Just use the stock intermittent relay for the stock wipers ...
jimsfolly
post Jul 19 2012, 02:15 PM
I added a delay box from JCW for about $25, gives a 2-20 variable delay... can't live without an intermittent wiper in the Pacific Northwet.
Not sure just swapping the motor will do anything without a the switch to go with it... waiting to someone to step up and update to a modern control stalk set...both lights and wipers
post Jul 19 2012, 02:48 PM
QUOTE(McMark @ Jul 17 2012, 09:32 PM) *
(IMG:style_emoticons/default/popcorn[1].gif) To quote Col. Klink, "Vely interestink."
wingnut86
post Jul 19 2012, 07:15 PM
...boola la boo boola boo...
Mike,
What years of Passat? Or are you just going to fabricate anything that pops up during the swap?
tanks...
ruby914
post Jul 19 2012, 08:00 PM
QUOTE(jimsfolly @ Jul 19 2012, 01:15 PM) *
I was thinking the same. I used all the suby wiring I could. With the WRX intermittent switch to the 914 motor all is good.
IronHillRestorations
post Jul 20 2012, 07:30 AM
I. I. R. C.
FWIW, there's a plug in VW intermittent wiper relay that's plug and play for the early Boxsters, the VW part number is 357 955 531 or 1HM 955 531B. It might take one of our electrical engineers to make it work, but I'm betting it wouldn't be too hard.
jimsfolly
post Jul 20 2012, 10:47 AM
QUOTE(ruby914 @ Jul 19 2012, 07:00 PM) *
did you use the wiper/light switch assembly as is? haven't messed with mine since I did the washer switch upgrade... is it much of a hack to get the assembly to replace the stock setup?
really want a modern stalk wiper/light switch setup since my new dash design doesn't support the factory panel mounted switches...
McMark
post Jul 20 2012, 04:58 PM
914 Freak!
Tracking says it was delivered. I get to play on Sunday. (IMG:style_emoticons/default/boldblue.gif)
effutuo101
post Jul 20 2012, 05:02 PM
Half way through a 2004 VW steering swap. It is a lot of work if you want to maintain the adjustability.
ruby914
post Jul 20 2012, 05:25 PM
QUOTE(jimsfolly @ Jul 20 2012, 09:47 AM) *
I put in the complete steering column, gauge cluster, light and wiper controls from the WRX.
Yes, it is a lot of work.
I am not unhappy with the speed of mine but swapping motor you may get some more speed? That would not hurt.
jimsfolly
post Jul 20 2012, 06:41 PM
QUOTE(ruby914 @ Jul 20 2012, 04:25 PM) *
How did you adapt to the intermediate shaft? Does the Subaru use 36 spline 16mm? I've been looking at use an 'EZ Fit'variable length shaft to allow offsetting the column left to line up with my NSX seats.
ruby914
post Jul 20 2012, 10:12 PM
Please excuse us McMark.
jimsfolly, as I recall the shaft / spline was the same.
You can see more here.
http://z8.invisionfree.com/ClubNARP/index....=5431&st=40
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 3rd January 2025 - 01:18 AM
