What Relay Goes Here? |
mrbubblehead |
Jul 21 2012, 10:59 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i couldnt find a relay in the wireing diagram either. I'm not surprised since it was optional equipment. Not just the relay, but the whole harness with the socket was optional. (IMG:style_emoticons/default/popcorn[1].gif) PS: I have mounted the stock harness in my car, and if i recall correctly, the wire for the trigger is in the main harness but taped up somewhere near the drivers side air flap behind the brake fluid reservoir. The other wires from the harness go in line with the wiper motor connections. It's pretty much plug & play to install. sir andy, is the "trigger" brown with a black stripe? labeled T1a on the wiring diagram? it comes from the wiper switch? it must be..... |
Cupomeat |
Jul 23 2012, 01:51 PM
missing my NY 914 in VA Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Hmm, this sounds like a nice little upgrade project, I think I'll make it happen for the 75!
Thanks Tom for bringing this to the forefront and our attention! (IMG:style_emoticons/default/beerchug.gif) |
Jul 23 2012, 03:36 PM
Resident German Group: Admin Posts: 41,963 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i couldnt find a relay in the wireing diagram either. I'm not surprised since it was optional equipment. Not just the relay, but the whole harness with the socket was optional. (IMG:style_emoticons/default/popcorn[1].gif) PS: I have mounted the stock harness in my car, and if i recall correctly, the wire for the trigger is in the main harness but taped up somewhere near the drivers side air flap behind the brake fluid reservoir. The other wires from the harness go in line with the wiper motor connections. It's pretty much plug & play to install. sir andy, is the "trigger" brown with a black stripe? labeled T1a on the wiring diagram? it comes from the wiper switch? it must be..... Yes, that is the one. |
Lo-Fi Version | Time is now: 8th January 2025 - 01:29 AM |
