Front valance rubber spacers, Size?? |
Valy |
Aug 28 2012, 02:23 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
There are 2 rubber spacers that go on the M6 bolts holding the front valance near the wheel well.
The parts are NLA but does anyone know the thickness of those spacers? Thanks. |
jeffdon |
Aug 28 2012, 03:08 PM
gothspeed |
Aug 28 2012, 06:57 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
These are the dimensions for the rubber spacers at each end of the stock steel rockers. I would assume they are the same size as the spacers used on the valences. (IMG:style_emoticons/default/popcorn[1].gif)
In inches: .60" OD .240 ID .325" Height In MM: 15.3 MM OD 6.10 MM ID 8.1 MM Height * Since these are made of rubber all dimensions are approximate due to the compliance of the rubber. Hope this helps!! |
76-914 |
Aug 28 2012, 06:58 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
stack some 1/4" faucet washers. looks OEM (IMG:style_emoticons/default/biggrin.gif) works on the rear, too.
Valy |
Aug 28 2012, 07:19 PM
Perfect. Thanks.
I think that a piece of rubber hose will do the trick (IMG:style_emoticons/default/wink.gif) |
76-914 |
Aug 28 2012, 07:44 PM
Perfect. Thanks. I think that a piece of rubber hose will do the trick (IMG:style_emoticons/default/wink.gif) Mt 73 had pieces of hose but it distorts and won't compress. If you can't find any pm me. I've got hundreds. IIRC you'll need to pass a 7/64 bit thru them to enlarge the #8 hole so the factory bolt can slide thru. |
Cap'n Krusty |
Aug 28 2012, 08:47 PM
A number eight hole is bigger than the 4mm bolt that goes there .....................
The Cap'n |
76-914 |
Aug 29 2012, 11:27 AM
A number eight hole is bigger than the 4mm bolt that goes there ..................... The Cap'n Your probably right John but I remembered losing my temper trying to squeeze the washers over the bolt threads so I enlarged them. The reason that I used a larger bit will become self evident once you try to drill rubber. Especially Buna-N type rubber. I suppose a small rat tailed file in a drill might work better. BTW, here is a pic of a #8x32 showing it's metric o.d. dimension. I didn't mic it but the nominal measurement displayed here should be acceptable, in that we are just "Jury Rigging", anyway. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 11:49 AM |
