FS-Weber Jet Drill Set,Spare Tire Clamp&Trunk Shelf, Balljoint,Renegade Water Pump Fittings |
bulitt |
Sep 3 2012, 07:01 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
FS- Buyer pays shipping on all items unless otherwise noted.
Original Weber Carb Drill Set for drilling jets. Bought this in 1973 and you won't find them around anymore! Contains 36 drill bits (missing 4 sizes- .65, .95, 1.85, 2.15). Bits from .40 to 2.35 in .05 increments- Bits are in excellent condition.- 85$ OBO Front Trunk Carpeted Shelf- Pretty nice, could use some contact cement around edges on backside. - 40$ OBO Spare tire hold down clamp and bolt- 10$ Two New Renegade Water pump fittings- bolt onto front of SBC to use remote pump.- 40$ |
bulitt |
Sep 5 2012, 07:22 AM
Have three sets of used press-in studs. All standard 14mm x 1.5. All have been chased with a die to insure good threads. Will separate- 1.50$ each
One set (ten) of 40mm (34mm of thread area) silver off H&R Spacers- 15$ One set (ten) of of 40mm (34mm of thread area). black- 15$ One set (ten) of 40mm (34mm of thread area). black - 15$ |
bulitt |
Sep 5 2012, 10:38 AM
Used Balljoint - I inserted it in control arm then realized I needed the later version, so basically new!. See application on box
(uses bolt not pin).- 30$ Buyer pays shipping |
bulitt |
Sep 6 2012, 10:57 AM
bump
pilothyer |
Sep 6 2012, 07:11 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I would like to get the: Used Throw out bearing in VGC- 30$. PO did clutch change prior to my purchasing vehicle in 2011. Probably has less than 300 miles on it. I upgraded to KEP clutch and bearing.
Buyer pays shipping P_m Sent with ship to info> Thanks. Jerry |
pilothyer |
Sep 6 2012, 09:40 PM
Pay Pal Has Been Sent.
bulitt |
Oct 19 2012, 05:37 AM
New items added! (IMG:style_emoticons/default/piratenanner.gif)
Griffinroydonald |
Oct 19 2012, 08:48 AM
Newbie Group: Members Posts: 49 Joined: 21-January 10 From: Kings Mtn N.C. Member No.: 11,274 Region Association: None |
Paypal sent on jack - Thanks
Jack arrived Oct 20 and is great - Thanks (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:20 PM |
