GB: CSP Bellcrank Linkage for dual IDF, including the throttle cable bracket - SHIPPING |
JFJ914 |
Feb 12 2013, 10:25 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
McMark |
Feb 12 2013, 10:32 AM
I emailed Gunter again to see what's up. I just looked again at the CSP site and perhaps it's compatible with this spring which is an add on option.
Hopefully I will hear back from Gunter soon and we can see about ordering the spring for those who want them. |
biosurfer1 |
Feb 12 2013, 01:45 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Count me in for a spring
Gint |
Feb 14 2013, 10:00 AM
Mike Ginter Group: Admin Posts: 16,094 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
No. Just the carb springs at this point. I don't think I want a return spring. I prefer a nice light throttle. I haven't really driven it yet though either.
Gint |
Feb 17 2013, 09:50 PM
That works great! What an improvement over those stupid cross bar linkages.
Harpo |
Feb 18 2013, 07:49 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Please add me to the list for the additional return spring
Thanks DAvid |
billh1963 |
Feb 20 2013, 06:53 AM
Car Hoarder! Group: Members Posts: 3,404 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Didn't look closely at mine....I also thought these were going to have the built in return spring. Put me down for a spring.
Gint |
Feb 20 2013, 07:00 AM
I'm not using a spring other than what's on the carb shafts. Works great!
DBCooper |
Feb 20 2013, 07:30 AM
Unless there's something wrong with your carburetors you shouldn't need an additional return spring. That linkage is so low friction that it doesn't "add" anything. That's not to say you don't need a spring, I don't know, but if you do you might want to take a look at your throttle cable, or your carb's throttle shafts.
Gint |
Feb 21 2013, 06:58 AM
Or at least get it installed first! (IMG:style_emoticons/default/poke.gif) You don't know that you don't need a return spring unless you've tried it.
JFJ914 |
Apr 9 2013, 09:25 AM
Any news about the spring?????
ConeDodger |
Apr 9 2013, 03:36 PM
Apex killer! Group: Members Posts: 23,824 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Any news about the spring????? Yes, and it's good news too! It's Spring! (IMG:style_emoticons/default/av-943.gif) |
McMark |
Apr 11 2013, 12:21 AM
I've tried several times to get info from CSP about the return spring. The bottom line is that I haven't gotten any word that there is a spring made specifically for our setup. The T1 spring may work, but I won't have time to do any research into this aspect. (IMG:style_emoticons/default/sad.gif)
B2524 |
Apr 13 2013, 09:58 AM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Are any of these still available, I missed this thread. Thanks,
Kd |
rmital |
Apr 27 2013, 11:18 AM
Northeast optimist Group: Members Posts: 1,951 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
I'm ordering a few CSP Bellcrank linkages and I figured I'd put it out as a group buy and offer a discount, as well as a package deal with the throttle cable bracket I make. This is the best, easiest to use/install linkage available. I've used a ton of them and the build quality is outstanding and installation is dead-simple. I'm also including the throttle cable bracket that I designed specifically for this setup. That means this a complete setup for dual IDF users. Original price for the linkage from CSP is $155 (at current exchange rates) Original price for the throttle bracket is $35 Total retail is $190. Group buy price: $165. Closes 12/18/2012 Order Now (IMG:http://www.914world.com/bbs2/uploads/post-419-1293649853.jpg) I will place the order with CSP on 12/18. The setups will ship from Germany to me, and then I'll reship to you. Expected shipping is the week of 1/10/2013. I installed the linkage, very nice....and the bracket....the barrel of the accelerator cable is past the connection point (cable too long)? anyone have this issue? did this last night, finished up around midnight, so going to take another look when I get home today; but certainly seems the accel cable is just too long..... |
McMark |
Apr 27 2013, 02:39 PM
There is a ball-socket at the pedal. This should be threaded all the way on. If not it can cause the problem you're looking at.
And while you've got your head in the pedal cluster, make sure the throttle stop isn't bent and allowing the throttle to return farther than normal. And inspect the throttle arm at the cluster to make sure the rod isn't bending. The arm to rod should be 90 degrees/ right-angle. |
LotusJoe |
Jul 25 2013, 08:18 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Is this setup still available?
Dtjaden |
Jul 25 2013, 08:49 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Can anyone compare this to the Tangerine cable linkage (ignoring the price difference)?
ConeDodger |
Jul 25 2013, 09:57 PM
The CSP is crazy good. I can't speak for the Tangerine though Chris pretty much universally makes great product...
McMark |
Jul 25 2013, 11:19 PM
I think I have a couple, send me a PM.
Lo-Fi Version | Time is now: 23rd November 2024 - 10:32 PM |
