7 Pages V « < 5 6 7
> GB: CSP Bellcrank Linkage for dual IDF, including the throttle cable bracket - SHIPPING
r_towle
post Jul 26 2013, 02:16 PM
Post #121
Custom Member
QUOTE(McMark @ Apr 11 2013, 02:21 AM) *
I've tried several times to get info from CSP about the return spring. The bottom line is that I haven't gotten any word that there is a spring made specifically for our setup. The T1 spring may work, but I won't have time to do any research into this aspect. (IMG:style_emoticons/default/sad.gif)
Post a pic of the spring if this is still a problem.
We had good success with MSC or McMaster Carr when we needed springs, they have all springs...
Looks like (from what pictures I see here) the spring would be part of the bell crank, so its a torsion spring.
They have a hug section of these at the two HW vendors above...
We order ten different ones for a robot once, kept trying them till we found the right tension for the application...
They were pretty cheap.
rich
JFG
post Oct 10 2017, 12:36 PM
Post #122
Does anyone have pictures of the carbs where the csp plates fit? I can't tell which one they're calling left or right and the images in the instructions are blackened photocopies
nditiz1
post Oct 10 2017, 01:04 PM
Post #123
QUOTE(JFG @ Oct 10 2017, 10:36 AM) *
McMark made a pretty good video showing the setup. Look for his vid here. I believe you are wondering about the rods. They attach to the carb plates. They are very similar to the hex bar setup you had on there.
http://www.914world.com/bbs2/index.php?showtopic=317510
JFG
post Oct 10 2017, 01:39 PM
Post #124
I'll watch that video in full tomorrow.
My confusion is the instructions refer to right/left carbs and the throttle plates provided in the kit replaces one of them?
Have users connected them to the standard plates that come with the carbs?
IronHillRestorations
post Oct 10 2017, 05:50 PM
Post #125
I. I. R. C.
QUOTE(JFG @ Oct 10 2017, 11:39 AM) *
You have to put an adapter on each one. When you have the parts in front of you, you can see it's simple and very straight forward
simonjb
post Aug 31 2018, 08:59 AM
Post #126
KiwiMan
Help, but which Carb is left and which is right? I am installing and trying to following the instructions. Thanks !
7 Pages V « < 5 6 7
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2024 - 08:35 PM
