Too Much Heat~!, Not the Engine the Cabin |
914werke |
Sep 12 2012, 11:09 AM
"I got blisters on me fingers" Group: Members Posts: 10,542 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So after resurrecting the Phoenix Ive been attempting to expel a few remaining demons (IMG:style_emoticons/default/biggrin.gif)
A couple are clearly FI & electrical, a couple others are simple mechanical issues that will just take time/patience to correct... But one that is somewhat annoying me and sort of surprising is that IVE GOT TO MUCH HEAT! The car runs right in spec temp-wise but the heat generated by the HE's is bleeding into the cabin to the point that it is uncomfortable especially in our warm summer days here in the PNW (IMG:style_emoticons/default/sad.gif) What can I do? I was planning on replacing/renewing the "sealing" material on the flap in each heater box, is part of the problem that the foam seals in the fresh air box valves also shot ? (IMG:style_emoticons/default/headbang.gif) I dread ripping that setup apart again! (IMG:style_emoticons/default/smash.gif) |
VaccaRabite |
Sep 12 2012, 11:30 AM
En Garde! Group: Admin Posts: 13,553 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Rebuild the flapper boxes in the engine bay. They are what is letting hot air into the cabin ducts.
brant |
Sep 12 2012, 11:52 AM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
sometimes the cable on the flapper boxes gets attatched in such a way as to limit their ability to close fully.
I used to crawl under the car and loosen the cable every summer and then tighten it every fall once its loose it won't pull them 100% open so you are giving up a tiny bit of heat, but at least it closes fully brant |
AZ914 |
Sep 12 2012, 11:55 AM
914 Dumbass Group: Members Posts: 1,461 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
What Brant says... at least disconnecting the cable at the box is a quick way to tell if your flappers are sealing or not.
SLITS |
Sep 12 2012, 04:23 PM
On the run to Beaver, I experienced that. I had indexed the flapper box wrong so the flapper was being held open.
107 desert heat + really hot air from HE .... I didn't sweat 'cause it dried before my clothes got soaked. (IMG:style_emoticons/default/biggrin.gif) |
mrbubblehead |
Sep 12 2012, 10:21 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
mine had a loose nut that had fallen in there and was holding the flapper open.
Lo-Fi Version | Time is now: 26th September 2024 - 05:32 PM |
