> 914/6 front rotors, Zimmerman
303racing
post Sep 26 2012, 07:38 PM
Shopping front rortors for my 914/6 and looking at the Zimmerman drilled. any feed back, good or bad.
Thank,
Tim
brp986s
post Sep 26 2012, 08:39 PM
I've had a set for a few thou miles. No problems. But mine is a street car, so they've never been smokin' hot. Somehow I ended up with another set that fit carrera that I can't use. If you're running "A" calipers maybe you'd be interested. Verify fitment. They're new, but one got wet and has superficial rust. Half new $.
303racing
post Sep 26 2012, 09:02 PM
QUOTE(brp986s @ Sep 26 2012, 07:39 PM) *
PM SENT
Eric_Shea
post Sep 26 2012, 09:42 PM
PMB Performance
Carrera rotors are 24mm wide and the 914-6, 911 up to 1984 are 20mm wide. No workie on a -6.
I think drilled is fine. If you do serious road racing expect to see some cracks develop. Anything under that and you should be good.
carr914
post Sep 26 2012, 09:57 PM
Racer from Birth
I don't like Drilled Rotors. I've had the Zimmerman Ventilated - Good
- Lo-Fi Version Time is now: 2nd January 2025 - 03:16 PM
