Intermittent Wipers, What do I need? |
steuspeed |
Oct 12 2012, 01:44 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Summer is over and the first rain hit today (IMG:style_emoticons/default/sad.gif) I have a 73 and want to add intermittent wipers. What do I need, and where can I get it? |
Oct 12 2012, 01:54 PM
Resident German Group: Admin Posts: 41,954 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Summer is over and the first rain hit today (IMG:style_emoticons/default/sad.gif) I have a 73 and want to add intermittent wipers. What do I need, and where can I get it? - Make sure you have the wiring in the steering column. A early '73 may not have it. - Get the extension harness. It plugs into your wiper motor connectors and adds a relay socket. - Get the correct relay - Brake off the tab on the wiper lever that prevents the lever from going down a notch. This article mentions the extension harness and relay: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) PS: Do a search here, there are some good threads about the subject already ... |
Eric_Shea |
Oct 12 2012, 01:58 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I used a 924 switch, a 914-6 pump, a factory intermittent relay and a relay harness from Mr. Bowlsby.
All looks and operates factory... which isn't saying much. If you're electrical savvy, Valy can share his schematic for a better solution. The factory intermittent is really not worth the effort. His will operate at the speed you select with the stalk. Pretty slick. |
markb |
Oct 12 2012, 07:46 PM
I have the extension wiring and an NOS relay for sale in the classifieds......
steuspeed |
Oct 13 2012, 08:58 PM
So Mark has the factory 914 harness for intermittent wipers. I believe it was called 'flick wipe'. Does it work just like normal intermittent wipers?
Eric_Shea |
Oct 13 2012, 09:48 PM
Here's how it works, if you have the factory intermittent switch.
Lower the right stalk for intermittent. I don't recall what it is but, it's like a 3-4 second delay. That's it. Better than full on but not amazing by today's standards. The rest of the stalk works the same; one up for low, two up for not as low as low. (IMG:style_emoticons/default/biggrin.gif) |
steuspeed |
Oct 13 2012, 10:37 PM
I saw in the archives that pull give you wash + 4 wipes. I don't know if mine does this now since the washer pump does not work and I never use it. I think my spare needs more tire pressure, or maybe something wrong with the pressure valve.
markb |
Oct 13 2012, 10:45 PM
Sorry, but someone just swooped in & bought my harness.
If you're going to put in the int wipers, you might also go to an electric washer pump. SirAndy has a writeup on how to do that.wipers, |
Valy |
Oct 13 2012, 11:43 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
See this post.
http://www.914world.com/bbs2/index.php?s=&...t&p=1447738 The programmable relay is really nice. |
steuspeed |
Oct 14 2012, 12:16 AM
I found that wire diagram on the Samba site I think. That sounds really slick. Now I just need to implement.
steuspeed |
Oct 27 2012, 08:47 PM
Got my #99 programmable wiper relay on the way. Found this hook-up diagram.
http://blue67.co.uk/tech_images/int_wiper_mod.jpg |
Lo-Fi Version | Time is now: 2nd January 2025 - 12:01 PM |
