FS: 1975 914-V8 Bay Area CA, SOLD SOLD SOLD SOLD!!! Thanks |
matthepcat |
Oct 22 2012, 01:53 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I have been dancing around selling to move to another project for about a year. (IMG:style_emoticons/default/idea.gif) Some of you have seen it in person, other on the forum. I have owned this car since 2010, and fixed most of the bad. (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.5.jpg) I am starting at 11,500 firm. Engine 1975 Chevy 355 with mild cam, 9:1 compression, smog legal Holly carb & intake (pretty stock and reliable) ~35,000 miles on engine. Early Renegade kit, that the original owner beefed up with additional bracing & engine mount. 901 trans-axle rebuilt by renegade ( 1st gear block out with tall gears) sometime in the 90's. Chassis Whole chassis reinforced,wheel wells, rear strut towers tied together and to the fire-wall, boxed steel reinforced engine compartment, Boxed trailing arms, welded seams in passenger compartment. Original owner spared no expense to make this car solid. ( could easily be set up for track) You can jack the car from one jack point and lift the whole side of the car up and door opens like its flat on the ground. List of what I have done: • Back date bumpers to 70-74 style bumpers. • Converted front suspension to 1989 Carrera Carrera hubs, rebuilt Bilstein inserts, Carrera vented brake rotors, new ball joints, new turbo tie rods, new wheel bearings. • Porsche 944 Turbo brake calipers with PBR pads and steel braided lines, new 19mm master cyl. • Rear 5 lug was converted using 911 hub with new wheel bearings from Eric. • 100MM wheel studs were used all around the car. • HARTMAN 3 piece forged racing wheels with Yokohama track/street tires. • New custom Fluidyne radiator (utilizing a Pantera radiator core) • Custom cut steel front bumper for radiator and new bumper pad from 914rubber.com • Complete Interior rust removal, Oil base prime/paint, sound deadening, new fuse panel and auxiliary fuse panel, speakers and i-pod connect. • Completely refurbished and powder coated pedal assembly with aluminum foot-board • Custom solid aluminum dash • Transmission output shaft from a 915 trans, along with 100MM Porsche 944 CV upgrade, Machined 914 axles. • J.W. Speaker Hi/Low LED fog light/headlights (very high end) • Prosport gauges: Oil pressure, water temp, voltage, Wide-Band O2 & LED back-lit dash gauges(From AL) for improved night visibility. What it needs Windshield wipers stopped working, but I never drive in wet weather and experience showed me Rain-X worked as a cheap solution. No Heater or A/C becuase people will ask. As reliable as it is, I think it would be good to install TBI ( save some $ at the pump) Needs the back pad light installed & wired. It's a driver, not a show car with some paint chips and scratches. It starts every time, even on a cold morning. I can jump in it now and drive anywhere ( if you could afford the gas and have ear plugs!). PM if you are interested. Matt P.S.--Car comes with a weltmeister front swaybar, and a box of extra stuff. Also the car comes with a binder from the owner before me, and most of my receipts. |
Andyrew |
Oct 22 2012, 10:07 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Please add 3k to your asking price...
Chris H. |
Oct 22 2012, 10:09 PM
Senior Member Group: Members Posts: 4,050 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
(IMG:style_emoticons/default/agree.gif) Seriously...that is a STEAL. Beautiful car Matt.
McMark |
Oct 22 2012, 10:43 PM
(IMG:style_emoticons/default/agree.gif) Way too much awesome for $12.5
matthepcat |
Oct 23 2012, 12:57 PM
Thanks for the compliments guys. I have had a bunch of interest in it from Craigslist.
I may venture onto e-bay and up the price. |
matthepcat |
Oct 23 2012, 01:01 PM
bulitt |
Oct 23 2012, 01:03 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
You cant build one as nice for anywhere near the price you are asking.
It's badass. Love those rear tires! |
Mike Bellis |
Oct 23 2012, 11:04 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Very sad... (IMG:style_emoticons/default/sad.gif) Someone needs to buy this car!!!
matthepcat |
Oct 24 2012, 09:26 AM
Mike,
I will probably ask for advice on the next project, as you have much vehicle guru knowledge. Wil still be a member here to see how everyone's projects are going. |
matthepcat |
Oct 29 2012, 11:50 AM
No floorboard tar removal dirty work for the buyer.
(IMG:http://www.914world.com/bbs2/uploads_offsite/img827.imageshack.us-11125-1351533052.1.jpg) Driver view (IMG:http://www.914world.com/bbs2/uploads_offsite/img21.imageshack.us-11125-1351533052.2.jpg) Trunk ( battery could be located to engine bay) (IMG:http://www.914world.com/bbs2/uploads_offsite/img196.imageshack.us-11125-1351533053.3.jpg) Chassis reinforcement (IMG:http://www.914world.com/bbs2/uploads_offsite/img819.imageshack.us-11125-1351533053.4.jpg) Seats in good shape (IMG:http://www.914world.com/bbs2/uploads_offsite/img3.imageshack.us-11125-1351533053.5.jpg) |
NecronomiconJules |
Oct 30 2012, 10:35 AM
Newbie Group: Members Posts: 7 Joined: 3-January 07 From: CA Member No.: 7,422 |
All,
I have seen the car; Matt took it out for a spin too. In a word: it is every bit as awesome as it looks. Solid, thoroughly built, very usable, and a presence that pictures just can't evoke. Matt is an engaging guy, as honest as his 914, quick to point out what minor niggles it has, patient in explaining to the unskilled (me). In the end I decided it isn't quite my type of 914, but it's certainly the best $12.5k deal I've ever seen. GLWS Matt. J. |
matthepcat |
Oct 30 2012, 02:55 PM
Thanks for the honest feedback on my car.
Very nice to meet another member from the world, and good luck finding that perfect ride your looking for. Matt All, I have seen the car; Matt took it out for a spin too. In a word: it is every bit as awesome as it looks. Solid, thoroughly built, very usable, and a presence that pictures just can't evoke. Matt is an engaging guy, as honest as his 914, quick to point out what minor niggles it has, patient in explaining to the unskilled (me). In the end I decided it isn't quite my type of 914, but it's certainly the best $12.5k deal I've ever seen. GLWS Matt. J. |
SUNAB914 |
Nov 2 2012, 01:57 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
(IMG:style_emoticons/default/rolleyes.gif)
HMM I'll be watching this!! Is the paint really that nice?? |
matthepcat |
Nov 2 2012, 04:10 PM
It's nice...but not perfect.
She's on e-bay now. (IMG:style_emoticons/default/rolleyes.gif) HMM I'll be watching this!! Is the paint really that nice?? |
flippa |
Nov 3 2012, 09:12 AM
Advanced Member Group: Members Posts: 3,178 Joined: 7-May 07 From: Boston, MA Member No.: 7,720 Region Association: North East States |
Why has this car not been sold (IMG:style_emoticons/default/confused24.gif) ; it would already be in my garage if I had the spare cash. Bump to the top.
Nice car, good luck with the sale. |
SUNAB914 |
Nov 4 2012, 04:46 PM
Too soon. uuggg!
tumamilhem |
Nov 4 2012, 06:43 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
wow. if i could have a second 914, i would definitely like one that's modified and beefed up like yours. very nicely done, sir. i commend you on your car while i am in total jealousy of you. lol (IMG:style_emoticons/default/smile.gif)
matthepcat |
Nov 4 2012, 06:53 PM
Thanks for kind words. It has been a labor of love to be where she is today. On another note, I had a member come look at the car this evening. He mentioned that the shifting problem might be an issue for many people. I decided to give another try at clutch adjustment, and that seems to have fixed the first gear issue. Stoked! Seems I just had the clutch cable too loose to find 1st gear at a stop nicely. wow. if i could have a second 914, i would definitely like one that's modified and beefed up like yours. very nicely done, sir. i commend you on your car while i am in total jealousy of you. lol (IMG:style_emoticons/default/smile.gif) |
tumamilhem |
Nov 4 2012, 07:19 PM
Quick and east fix. No worries. (IMG:style_emoticons/default/smile.gif)
bfrymire |
Nov 4 2012, 09:02 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Glad to hear it was an easy fix. Your car is very nice, and I am sure someone will step up and buy it.
Actually, someone please buy it, so I will not be tempted. (I looked at it today,and if I didn't already have 6 cars, it would have come home with me. ) (IMG:style_emoticons/default/smile.gif) THere are a lot of details that are lost in the photos. A very nice build, to my eyes at least. Some details not mentioned. 1. Wide band O2 sensor and gauge mounted in dash. 2. Relay board delete. 3. JWest fuse board update 4. This car was coverted before pre-1975 smog exemption and is smog legal, if the law is ever repealed. It has the referee sticker. GLWS! -- brett Thanks for kind words. It has been a labor of love to be where she is today. On another note, I had a member come look at the car this evening. He mentioned that the shifting problem might be an issue for many people. I decided to give another try at clutch adjustment, and that seems to have fixed the first gear issue. Stoked! Seems I just had the clutch cable too loose to find 1st gear at a stop nicely. wow. if i could have a second 914, i would definitely like one that's modified and beefed up like yours. very nicely done, sir. i commend you on your car while i am in total jealousy of you. lol (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 2nd January 2025 - 11:28 AM |
