Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
My mechanic had a number of unkind things to say about the brass-caged ones when we did the rebuild. He preferred the steel-caged bearings as well; probably because they were one unit and didn't fall apart as you were trying to install them. (At least, that's the impression that I got from what he was saying.) --DD The cages and balls can fall out, but the balls are captive in the cage. The main thing is that the steel doe snot shatter and the brass shatters very easy. I have seen more than once where a new one broke with minimal effort (not by me, luckily). That is a $200+ bearing that does this. I haven't really had a problem with the replacement brass cage bearings over the last 39 years, but I haven't done nearly as many trannies as you have. No comebacks, though, so the bearings must be holding up .............. The Cap'n |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
QUOTE I haven't done nearly as many trannies as you have. Sounds like a veiled insult! (IMG:style_emoticons/default/wink.gif) Seriously, I have not had a single standard brass bearing come back after I replaced it, but I have had to replace a lot of the brass caged bearings due to them being destroyed. I have never needed to replace a steel caged one. The brass is adequate, but inferior to the steel. |
Cap'n Krusty |
QUOTE I haven't done nearly as many trannies as you have. Sounds like a veiled insult! (IMG:style_emoticons/default/wink.gif) Seriously, I have not had a single standard brass bearing come back after I replaced it, but I have had to replace a lot of the brass caged bearings due to them being destroyed. I have never needed to replace a steel caged one. The brass is adequate, but inferior to the steel. No insult, veiled or otherwise, meant. Just 'cause I'm generally krusty doesn't mean everything I say is that way ............................................ Carry on with the good work! The Cap'n |
Dr Evil |
Time for an update. I did some LSD tonight, I am not that fond of this procedure, but it is necessary (IMG:style_emoticons/default/smile.gif) In the original pics of the intermediate plate it shows the old bearing retainer. That would not be good enough for Qarl, oh no! He went all fancy (IMG:style_emoticons/default/smile.gif) I put the fancy one on once I found he had shipped one (IMG:style_emoticons/default/rolleyes.gif)
Attached image(s) ![]() ![]() ![]() ![]() ![]() |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Time for an update. I did some LSD tonight, I am not that fond of this procedure, but it is necessary (IMG:style_emoticons/default/smile.gif) In the original pics of the intermediate plate it shows the old bearing retainer. That would not be good enough for Qarl, oh no! He went all fancy (IMG:style_emoticons/default/smile.gif) I put the fancy one on once I found he had shipped one (IMG:style_emoticons/default/rolleyes.gif) Muhahaha |
turk22 |
Treetop Flyer ![]() ![]() ![]() Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest ![]() |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Why the LSD?
Is it because of all the extra weight the longest ever 9146gt build will carry now? |
a914622 |
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest ![]() |
Isnt that a tork biased differential? not a lsd.
jcl |
Qarl |
Yes.. it is a torsen (torque biasing) differential. Different characteristics than the LSD.
Dr Evil |
For most people, LSD is not delineated into Tq bias or puck type. So, LSD is slang.
Dr Evil |
I had time to get back on this build tonight. Qarl told me to take my time (IMG:style_emoticons/default/smile.gif) I set the pinion depth to spot on factory spec and only need to clean the tail cone and button her up then ship her out.
Attached thumbnail(s) ![]() ![]() |
Cap'n Krusty |
Tell me that's not a redneck jackstand in the last picture! ..........................
The Cap'n |
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,441 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
ball retianer
Attached image(s) ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
That looks like a thick flange on the side cover. Does the 901 suffer from the diff trying to spread apart under high HP ?
Besides 1st what are the weak links in a 901? |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Forget Qarl send that thing to me. Mike i wish i could get you up here to look at my transmission, i would love to have a longer gear for 5th.
Dr Evil |
Dr Evil |
That looks like a thick flange on the side cover. Does the 901 suffer from the diff trying to spread apart under high HP ? Besides 1st what are the weak links in a 901? Not really necessary, but people do what they want (IMG:style_emoticons/default/smile.gif) The weak parts: - 1st gear, cant be helped - Gears, cant be helped. They are thinner than the 915, 930, G50, etc gears so they can shear under extreme stress. - Input shaft intermediate plate bearing, change to a steel caged one if you can find one. Otherwise, be gentile while handling or the shitty brass cage will break. No need to adjust gearing until 3.0 and higher. I have a 2.7 that is doing just fine. You have to consider RPM and HP. How low of an RPM will have how much HP? Too much HP at Low RPM = untimely death in wrong gear.....like down shifting into 1st form 5th doing 150mph. |
Mark Henry |
How low of an RPM will have how much HP? Too much HP at Low RPM = untimely death in wrong gear.....like down shifting into 1st form 5th doing 150mph. I think in that scenario you would have more to worry about than just your tranny.... There again in that scenario maybe the 901 letting go would be a good thing. (IMG:style_emoticons/default/wink.gif) |
sixnotfour |
Lo-Fi Version | Time is now: 29th June 2024 - 02:58 AM |
