Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Sweet. Cool steering wheel.
Hey Jeff, I remember that pic from back in the day of... Dad's car? What are those wheels that are on it? Are they around somewhere? (IMG:style_emoticons/default/happy11.gif) |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,750 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
American Torque Thrust aluminum 15x7, How many do you want ?
helios |
Member ![]() ![]() Group: Members Posts: 234 Joined: 15-May 08 From: Bellingham Wa Member No.: 9,055 Region Association: Pacific Northwest ![]() |
After a bit of a hiatus, I crawled around the car for a bit yesterday in between yard work. Ended up having to pull the steering column back out, because I failed to line up the notch in the steering shaft w/ the pinch bolt. (IMG:style_emoticons/default/chair.gif) Got that re-oriented and bolted down. Just need to hook up wires, then I can get the lower dash pad re-installed.
Got a work night planned for Tuesday night at the house with some friends. Hoping to get the wheels studs installed (need to get shorter ones eventually (IMG:style_emoticons/default/blink.gif) ), figure out which wheel is seized (stuck brake or fried wheel bearing) and hopefully get it rolling again. If there is time, I also got a new RMS I'd like to try to get installed in the motor. |
NORD |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest ![]() |
I have to go see a Judge in Oregon Tuesday or I'd be there. Have some tires to return to you also. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 5th March 2025 - 09:20 PM |
