Suspension, What rear springs |
qa1142 |
Nov 4 2004, 08:56 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Ok, winter work is about to begin. I'll have stock front torsion bars, new boge shocks and 19mm Weltmeister front bar.
With stock rear boges, what rear spring will work best for street with occasional fun runs and/or autocross? 100# Weltsmeister? or something else? Should I spring ( (IMG:style_emoticons/default/chairfall.gif) ) for adjustable rear purches? |
Brad Roberts |
Nov 4 2004, 09:30 PM
140's are a good balance with the 19mm bar and stock front torsion bars.. and Boge shocks. It will ride nice.
B |
seanery |
Nov 4 2004, 09:49 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I like my 125s on adjustable perches, comfy, yet trackable (IMG:style_emoticons/default/driving.gif)
Brad Roberts |
Nov 4 2004, 09:52 PM
If he had ajustable shocks... I assumed he didnt want to spend any money on adjustable perches/springs for Boge shocks (not even sure if you can run threaded collars with Boge)
B |
ChrisReale |
Im thinking about going back to stock front torsions and dropping my rear spring rate to 125-150. I have a Tarett bar. Which would be better for Autocross?
Brad Roberts |
Nov 4 2004, 09:59 PM
Stick with your current rear springs. The fronts need to be changed out so we actually have some room to adjust your front bar.
I'm open Thurs/Fri of next week. The torsion bars are free. You can install them. We will also cut down your rubber snubbers. We'll do it next door. B |
Rusty |
Nov 4 2004, 10:01 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
I have adjustable Koni's all round (set full soft), stock torsion bars, and 140s. Car seems very balanced for street driving.
So... 140s would be my vote on springs. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Brad Roberts |
Nov 4 2004, 10:05 PM
I just HATE the Weltmeister progressive springs. The car rolls first... then takes a set ??? HUH ???
Run a Eibach or H&R 125 or 150 spring. B |
GaroldShaffer |
Nov 4 2004, 10:08 PM
You bought another 914? Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
QUOTE have adjustable Koni's all round (set full soft), stock torsion bars, and 140s. Car seems very balanced for street driving. So... 140s would be my vote on springs. (IMG:style_emoticons/default/agree.gif) I have the same setup on my car, works nice. I have a stock sway bar up front and I disconnected the rear bar. For Axing I just set the Koni's to full firm, 40psi in the Falkens, and hold on (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/biggrin.gif) |
Brad Roberts |
Nov 4 2004, 10:10 PM
Do you know what happens when you set the rears soft and front hard ?
B |
seanery |
Nov 4 2004, 10:13 PM
my guess would be that the car would rotate nicely.
Brett W |
Nov 4 2004, 10:17 PM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Not really, it pushes.
Yeah Will go with a linear rate 150 rear spring. WIll go well with my rear trailing arms. |
Trekkor |
Nov 4 2004, 10:19 PM
I just want to say, I love the way my car is handling and performing.
Brad, thanks for all the help! (IMG:style_emoticons/default/clap56.gif) KT |
Brad Roberts |
Nov 4 2004, 10:23 PM
See you at Sears Trekkor...
It is great we can AutoX 10 months out of the year with 2-3 events each month. All my "students" have done an awesome job this year. B |
Trekkor |
Nov 4 2004, 10:26 PM
Fronts firm and rears soft works great for me.
At Candlestick which had whoop-dee-do's and washboard surface, Brad set my shocks to soft all around and I was faster and more in control. KT |
Brad Roberts |
Here is what happens when you make a Koni change:
The effect: you are slightly increasing the front spring rate when you set them full hard and set the rear full soft. Case in point: car is slinging the rear end around in tight slow speed corners... set front shocks more firm. This will keep the weight from transferring forward as quickly. B |
Brad Roberts |
Nov 4 2004, 10:27 PM
I went full soft on everyones cars at Candlestick. Too rough not too. Need to keep all four wheels on the ground.
B |
kermit |
Nov 4 2004, 11:26 PM
Member Group: Members Posts: 169 Joined: 2-November 04 From: Millbrae, CA Member No.: 3,049 |
If you'll still be driving it on the street, 140 lb range should be good.
Why Boge? Consider getting some Bilsteins, they're made really well. From what I heard, a little better than Konis, but you don't get the adjustability - assuming that is important. Depends on how competitive of a person you are, but adjustable spring perches or really nice if you ever want to fine tune or corner balance your chassis. |
John |
Dec 1 2004, 04:13 PM
Where can I get a set of the threaded tubes & adjusting collars? I've been looking around on the internet and not finding much.
I am currently using Eibach springs and Bilstein shocks with snap ring grooves. The only adjustments are about 1" apart... |
Mueller |
Dec 1 2004, 04:42 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
QUOTE(JOHNMAN @ Dec 1 2004, 03:13 PM) Where can I get a set of the threaded tubes & adjusting collars? I've been looking around on the internet and not finding much. I am currently using Eibach springs and Bilstein shocks with snap ring grooves. The only adjustments are about 1" apart... call Brad @ HPH....they should have them in stock....you'll need the 2.5" diameter springs... |
Lo-Fi Version | Time is now: 21st December 2024 - 07:44 AM |
