Shifter Springs, Removed all the grit, now... |
wndsnd |
Dec 17 2012, 04:48 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Cap'n Krusty |
Dec 17 2012, 04:57 PM
How did you get those little bugger springs back in? Thanks John Long 4mm punch. Remove the pin, bow the spring so it's lined up with the holes at both ends, insert the punch on one end and press the spring sown (flat) as you push the punch through. Once it's completely through, insert the pin from the side where the shaft of the punch sticks through, displacing the punch as you push the pin through. Attach the clip on the end of the pin after it's pushed all the way through. Repeat for the second spring. It's actually one of the easy ones, all things considered. The Cap'n |
wndsnd |
Dec 17 2012, 05:12 PM
How did you get those little bugger springs back in? Thanks John Long 4mm punch. Remove the pin, bow the spring so it's lined up with the holes at both ends, insert the punch on one end and press the spring sown (flat) as you push the punch through. Once it's completely through, insert the pin from the side where the shaft of the punch sticks through, displacing the punch as you push the pin through. Attach the clip on the end of the pin after it's pushed all the way through. Repeat for the second spring. It's actually one of the easy ones, all things considered. The Cap'n Thanks Cap'n, I am on it! |
wndsnd |
Dec 17 2012, 05:25 PM
It worked slick, I have been messing with it for an hour and doing it right took two minutes! Thank you.
Cap'n Krusty |
Dec 17 2012, 05:51 PM
My pleasure! Better put some grease in there ...............................
The Cap'n |
Tom |
Dec 17 2012, 06:51 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Cap'n,
Thanks, that was a nice explanation of how to do this. Doesn't sound like the Cap'n's answers I am used to reading. LOL!! Hope all is OK! (IMG:style_emoticons/default/smile.gif) Tom |
Cap'n Krusty |
Dec 17 2012, 06:56 PM
Nice, honest, questions result in nice, honest, answers.
The Cap'n |
wndsnd |
Dec 17 2012, 09:10 PM
Used white lithium. Is that too light?
jim_hoyland |
Jan 30 2015, 06:40 PM
Get that VIN ? Group: Members Posts: 9,575 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Yup: did a search on replacing the shifter springs and found the Captains method. Took 5 minutes (IMG:style_emoticons/default/piratenanner.gif)
Gloves and safety glasses highly recommended... (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
pete000 |
Jan 30 2015, 06:53 PM
Senior Member Group: Members Posts: 1,886 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Those suckers can be tough !
pete000 |
But when they go in its Miller time !
jim_hoyland |
Jan 30 2015, 07:23 PM
I cleaned away a lot of gunk. Are any of those parts between the springs supposed to be greased ? Seems like the plate rides on a Teflon bearing...
Java2570 |
Jan 30 2015, 07:26 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Yeah, don't get hit in the face with the spring like I did!! I was wearing safety glasses but it bounced off my cheek..... (IMG:style_emoticons/default/blink.gif)
Jan 30 2015, 07:36 PM
914-6 GT in waiting Group: Members Posts: 19,696 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 12th January 2025 - 09:33 AM |
