45 Pages V « < 13 14 15 16 > »
> My 3.3L Subie Conversion Thread, Got me some 914rubber stuff
CptTripps
post Jun 9 2014, 07:45 AM
Post #265
:: Punch and Pie ::
You should be fine with that. I just bigger than I thought I would need....because I usually under-estimate things.
post Jun 9 2014, 08:05 AM
Post #266
(IMG:style_emoticons/default/thumb3d.gif) Great job, Chris. Doug is correct. There is about 3/8" up n down movement on that rod due to the movement of the pedal cam thru it's cycle. I ended up with a 3/4" hole which I thought was small but I don't live in lower Slobovia, either. (IMG:style_emoticons/default/lol-2.gif) That bellows seal will cover any hole up to 1.5". Once you've determined the clutch pedal travel, set the stop nut on the end of the pedal. I suspect this is where Doug "felt" flexing or his floor metal is thin. You shouldn't have to exert more than 5lb pressure to engage the clutch so if the pedal flexes and adding one brace 2" to the right side helps, I'd look elsewhere. IOW, if it flexes, the left side of the cluster is receiving the down force and the right side the up force, so a brace on the right should be unnecessary but it won't hurt anything either. Good to see you posting again, Chris. Hurry, you only have 3 weeks until Winter strikes Chicagoland again. (IMG:style_emoticons/default/lol-2.gif)
Chris H.
post Jun 9 2014, 09:17 PM
Post #267
Well, I finally headed back to the engine bay to work on the exhaust/engine mount stuff and noticed this:
Left Subie motor mount.... I knew it was cracked before but over the winter it really opened up. Probably can't ignore it any more or it will crack in half. It's 20 years old...can't be too surprised. Looks like the SVX guys do one of three things:
1. replace these with STI "Group N" mounts ($150 shipped per pair)
2. Fill the cracked mounts with urethane and let them harden (sounds sketchy)
3. buy new ones for ~$300+ (nope)
I noticed the PrecisionChassis 3.3L looks like the engine cradle is bolted directly to the engine at the motor mount points without any rubber isolators. Always wondered if I could do something like that since I have rubber mounts at both ends of my cradle.
mgp4591
post Jun 10 2014, 05:23 AM
Post #268
QUOTE(Chris H. @ Jun 9 2014, 09:17 PM) *
I wouldn't want to trust that for a couple of reasons. First, I think the engine vibration could promote cracking at weld points on the cradle or possibly more. The 3.3 has a good amount of torque- might pretzel up a cradle. Second, vibration into the rest of the car could make a harmonic howl that drives you crazy! (IMG:style_emoticons/default/blink.gif)
Chris H.
post Jun 10 2014, 07:00 AM
Post #269
Yeah the vibration is what I'm worried about. Looks like the Group Ns are pretty stiff. Another project! Yeah! (IMG:style_emoticons/default/smilie_pokal.gif)
BIGKAT_83
post Jun 10 2014, 07:15 AM
Post #270
Found the right side mount,still looking for the left. PM me your address and I'll ship you a set.
Bob
Chris H.
post Jun 10 2014, 07:22 AM
Post #271
Thanks Bob! Will do! That saves me a huge pile of money and time!
post Jun 10 2014, 02:40 PM
Post #272
FYI, I just noticed that the pic Doug posted has the brace on the wrong side. That might induce some flex. Also, I recommend that you take a piece of 2" PVC x 1.5" long and when looking at it from the end, cut out a section from 12 o'clock to 4 o'clock. This piece will "snap" over the steering rack. Once on, rotate it until the void (12-4) is facing down. This will give the clearance needed for the steering cover to bolt up w/o interference. There will be enough room for this piece to fit between obstacles but only on the left side. The reason for this PVC piece is twofold. 1st is to protect the metal on the steering arm from the harder steel brace and secondly it should have some quietening effect upon the pedal assm.
Chris H.
post Jun 10 2014, 03:49 PM
Post #273
QUOTE(76-914 @ Jun 10 2014, 03:40 PM) *
My brace is on the correct side then? I think it is. Great call on the PVC. I was planning to use some extra rubber welting or something.
post Jun 11 2014, 12:47 PM
Post #274
QUOTE(Chris H. @ Jun 10 2014, 02:49 PM) *
The brace goes between the two M/C's, the left side of the clutch MC. (IMG:style_emoticons/default/beerchug.gif)
CptTripps
post Jun 11 2014, 01:13 PM
Post #275
:: Punch and Pie ::
I forget what I switched it to, but one side gave me a ton of flex, and the other was solid. I did have it wrong at one point. I ended up adding a second just to be safe. Now it's solid as a rock.
Chris H.
post Jun 11 2014, 02:40 PM
Post #276
So I had it on wrong too then...is what you're saying very nicely Kent... (IMG:style_emoticons/default/lol-2.gif)
See that's why I'm going slow...been a little stressed lately...I'm surprised you didn't notice this...
Yeah I drilled out and widened THE WRONG HOLE for the brace initially. No harm done but I felt pretty stupid. That's when I stopped for a week or so and gathered more parts. Back at it now though!
Chris H.
post Jun 17 2014, 01:45 PM
Post #277
Wellll....really good day today!
Got my speedhut gauges:
And even better, I got this from BIGKAT_83.
I bought my exhaust setup from Bob last year and knew it might take some fiddling to get it to fit with Ian's cradle but I wanted it. Then I recently found a cracked motor mount (has nothing to do with the cradle or exhaust, it's just 20 years old). So Bob GAVE ME his old mount which bolts directly to the engine. It's similar to the smallcar mount and very sturdy and strong. Can't wait to get it bolted up! Everything will fit perfectly now. Thanks again Bob!!!! (IMG:style_emoticons/default/beerchug.gif)
Chris H.
post Jun 17 2014, 03:18 PM
Post #278
Keeps getting better.... Got a package from Kent! Some pedal cluster stuff and half a map cylinder to attach to the front valance. Just in time too! My pictures were not legible enough to post but I'll take some more later. Thanks Kent!
post Jun 17 2014, 05:11 PM
Post #279
QUOTE(Chris H. @ Jun 17 2014, 12:45 PM) *
Those are sweet. Hide the bill from your wife. (IMG:style_emoticons/default/lol-2.gif) I'm just jealous. (IMG:style_emoticons/default/hissyfit.gif) Shoot us a pic of your cracked mount. I want to be sure I didn't miss that and a pic would help. FWIW, I shit canned those stamped metal pieces (w/3 bolt holes on the front mounts) and replaced them with 3/16" plate steel. Keep after it my brother. (IMG:style_emoticons/default/poke.gif) You only have 2 more weeks of summer in Chicago.
euro911
post Jun 17 2014, 10:37 PM
Post #280
QUOTE(Chris H. @ Jun 17 2014, 11:45 AM) *
Attached Image...
Nice (IMG:style_emoticons/default/smile.gif) ... Did you get them to eliminate the 'Speedhut' printing?
Chris H.
post Jun 18 2014, 08:06 AM
Post #281
No, the logo is prominently displayed (IMG:style_emoticons/default/biggrin.gif) . I didn't get anything special actually, just the blue lighting which I thought was cool. Man these things are thin. 2" or less.
Kent, I'll try to get those mounts off and shoot you some pics today.
EDIT: Also BTW Kent the good news is I've collected so many gauges I can probably recoup 60% of my Speedhut cost! Now...if I can just allow myself to sell 'em! They're like family now!
Chris H.
post Jun 21 2014, 12:09 PM
Post #282
OK here are the pics of the dead mount....
The cracks seem to form where the indentions are in the rubber. They are almost all the way around it.
It started losing its magic fluid too...looks and smells like some sort of gear oil.
I had one of the 911 sport mounts go wonky on me so had to order a replacement...in the meantime I'm cleaning up the engine bay. The entire firewall was covered with glue residue...whaddayaknow it's BLUE under there!!! (IMG:style_emoticons/default/biggrin.gif)
Still have to mount the battery tray on the other side, etc.
3d914
post Jul 31 2014, 07:54 AM
Post #283
Great project Chris. Keep at it.
Chris H.
post Jul 31 2014, 08:02 AM
Post #284
Thanks Gerard! Yours is looking good too! I like the way you extended your firewall without losing the stock shape. I have lots of updates, just haven't had time to post them but will try to get at it soon.
- Lo-Fi Version Time is now: 21st April 2025 - 09:10 AM
