Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Yeah Mike, for you that's video is child's play. Did you install that Porsche projector thing? How did the new cradle turn out? Easier on your CVs I hope. Kent that's great news on your clutch. I ordered mine Friday but haven't gotten a shipping confirmation. If it doesn't go out tomorrow I'm calling. The clevis should get there tomorrow. Working on the cable shifter now! I modified the cradle rather than rebuilding it. I did have to make new motor mounts to bolt onto the cradle. BTW, I do like the "idiot" light. I was thinking the same thing before I decided to install the dash cluster. There have been plenty of one step forward and two back on my build. Most of those did not make it into my build thread(s). Now I'm getting ready to swap out the 6 speed for the 5 so I can send the 6 to Dr. Evil. Time for new bearings. (IMG:style_emoticons/default/sad.gif) |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,055 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
New bearings? Man you are driving that thing like it should be driven aren't you?
Well the "idiot" light is perfect for me (IMG:style_emoticons/default/biggrin.gif) . Apparently on the OBD 1 you can rig it to blink out the codes so you just have to find out what they mean. The nice thing is that it does not go into "limp mode". I'm also installing a momentary switch where the block off plate for the rear defroster switch is. Got a 40 amp relay as well. My old Rabbit switch (it's what the factory used) frequently takes a couple turns to crank and I've read that the new ones are made in China. I know the Subie relay is easier on the ignition switch but I'd rather not dig into the steering column and swap it only to have the new one break soon after. Got this: ![]() It looks huge but it's not. It's the same size as the block off plastic piece. most people won't even notice it since it looks the same. If it ends up being a temptation for others to push I will use it as the windshield washer pump switch and get a different one later. |
Chris H. |
The good news is that I finally drove it... WOW is it fast!
The bad news is that 2 blocks away I snapped a CV (IMG:style_emoticons/default/headbang.gif) . Didn't even get a chance to give it much juice really. No tire spin or anything, just snapped. So the question is...do I use another 914 CV that I have stashed away or just upgrade to 951's now? Leaning towards the 951s. |
Mike Bellis |
Chris H. |
Yep, that's what I thought Mike. Just bought some from e-bay.
On a lighter note, this thing is sooooo much faster and more responsive than any 914 I've ever driven. I let the clutch out expecting one thing, and get something totally different! The noise it makes is pretty sweet too. |
Mike Bellis |
Drive over here so we can race. (IMG:style_emoticons/default/beer.gif)
Chris H. |
(IMG:style_emoticons/default/av-943.gif) It ain't that fast Mike. Keep in mind it was pushing ~72hp before. Not used to having to AIM it first before I hit the gas.
mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,608 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
(IMG:style_emoticons/default/av-943.gif) It ain't that fast Mike. Keep in mind it was pushing ~72hp before. Not used to having to AIM it first before I hit the gas. As another who is doing the EG33 thing that's great to hear! I'm looking into using a Subie front bearing instead of the Porsche so I can use the hub and axles designed for that power. Got some fabricating to do for it tho... (IMG:style_emoticons/default/idea.gif) |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,698 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Congrats on completing a very nice addition to the Suby Conversion Stable. (IMG:style_emoticons/default/first.gif) If you move quickly you can be on the road again this weekend. (IMG:style_emoticons/default/piratenanner.gif) OH, I almost forgot........... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
mgp4591 |
Congrats on completing a very nice addition to the Suby Conversion Stable. (IMG:style_emoticons/default/first.gif) If you move quickly you can be on the road again this weekend. (IMG:style_emoticons/default/piratenanner.gif) OH, I almost forgot........... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) AND SOUND!!! (IMG:style_emoticons/default/aktion035.gif) |
Chris H. |
Congrats on completing a very nice addition to the Suby Conversion Stable. (IMG:style_emoticons/default/first.gif) If you move quickly you can be on the road again this weekend. (IMG:style_emoticons/default/piratenanner.gif) OH, I almost forgot........... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) I did put 2 miles on it but "completed"...well...technically! I HOPE the axles come before the weekend. I'll start dis-assembly tomorrow. Since the axle floats maybe I can wrestle the thing out without taking the whole axle off. The one thing I haven't been able to bring myself to do is cut the front trunk holes. Hopefully by Friday I'll get up the guts to get that done. Was looking at some other options but I think I'd better stick to the standard way. Kent, what size are your holes? I'll get some video going when we get the axle back together. Right now it sounds a lot like Andyrew's "broken CV autocross video". Vrooommmm.....clunkclunkclunkclunkclunkclunk. |
76-914 |
Well, while waiting on parts you could drag your camera into the garage and take tons of pics then post them here. (IMG:style_emoticons/default/biggrin.gif)
Chris H. |
Funny thing is I just realized I don't THINK I have to take the thing quite as far apart as I thought...The floating axle might make it fairly easy to remove/replace that CV... (IMG:style_emoticons/default/idea.gif) I have two more 914 CVs... (IMG:style_emoticons/default/idea.gif)...still gonna go 951's regardless but I'm pretty impatient. Might be Monday before they get here. I guess I'll see how easy it is to remove and go from there.
Kent, have you removed your axle pins (Subie side)? Assume I just need a punch (but NOT a wood punch). Also, what size are the OUTLET radiator vent holes (in the fender wells) on your car? |
Chris H. |
Whew I needed I good laugh.
Searched what size punch to use to get the roll pin out (3/16) over on NASIOC. A younger gentleman was having trouble getting his out. Plenty of great suggestions, then someone said "Try hitting it with your purse.". (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) |
mgp4591 |
I took one of my longest and narrow necked punches with a flat tip and ground it down til it fit the pin size. The modified section is over 3 inches long and easily taps out the roll pin. When you put it back in, make sure the chamfered sides of the hub match the VERY SLIGHTLY chamfered side of the stub axle- that's the only way they'll go in. Plus the holes are offset from the centerlines so it makes it easier. Trying to pin it from the other side just creates frustration and releases language you haven't heard in years... may ruin the pin too. Great progress!!
76-914 |
Funny thing is I just realized I don't THINK I have to take the thing quite as far apart as I thought...The floating axle might make it fairly easy to remove/replace that CV... (IMG:style_emoticons/default/idea.gif) I have two more 914 CVs... (IMG:style_emoticons/default/idea.gif)...still gonna go 951's regardless but I'm pretty impatient. Might be Monday before they get here. I guess I'll see how easy it is to remove and go from there. Kent, have you removed your axle pins (Subie side)? Assume I just need a punch (but NOT a wood punch). Also, what size are the OUTLET radiator vent holes (in the fender wells) on your car? Not yet but they should push thru easily as new as they are. Get a set of drive pins at HF, <$5 and worth it. The holes are 1.5". (IMG:style_emoticons/default/beerchug.gif) |
Chris H. |
The Harbor Freight 3/16 long punch (comes in a 5 pack) works perfectly. Bottom line is if you tap it good a few times and it doesn't move you're tapping the WRONG SIDE.
BTW got the axle out, pix pf the carnage are forthcoming. |
ruby914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None ![]() |
(IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) ![]() |
Chris H. |
Thanks Mike. I'd love to post pics of the CV carnage but there WAS NONE. Seems I must have been (un)lucky enough to twist the axle just right while the conversion was going on to work one of the bearings loose or something since the engine was installed/removed several times. No metal fragments at all, everything was just loose in there. Weird.
Anyway I have the thing apart and still need to finish a few things in the cooling system so might as well wait one more day and get the 951 CVs. After hearing from a few 6 cylinder/V8 conversion folks that the 914 CVs will inevitably fail I'd rather not worry about it. |
76-914 |
Now we need to get a group buy on decals of your avatar. Anyone here make them?
Lo-Fi Version | Time is now: 20th April 2025 - 09:30 PM |
