45 Pages V « < 25 26 27 28 > »
> My 3.3L Subie Conversion Thread, Got me some 914rubber stuff
Chris H.
post Feb 28 2016, 06:03 PM
Post #505
First I need to reseal the oil pump. Needs a bead of RTV. Missed that the first time. Changed every other seal on the thing! Next I'll try to flip the intake. Bob has some extra EG33 parts he is sending me including a nice painted manifold so I'll probably use that along with the known good IAC valve. Then I'll get the wiring looking a little better and find a couple of small patch panels from a parts car for the holes I cut in the trunk firewall the first time around. Also might want a new engine lid at some point. I'll test all of the sensors while I'm at it and replace the small vacuum lines with OEM ones. The intake might force me to move the battery back to the stock location, and I might go to a smaller one if so.
914forme
post Feb 28 2016, 06:56 PM
Post #506
Nice work there.
Chris you don't happen to have an extra ECU to Engine harness? I have a bunch of engine harness, think I pitched my ECU harness
Chris H.
post Feb 28 2016, 07:15 PM
Post #507
Sorry I don't Steve. Does anyone else out there have an extra one? If not you can post on these sites with a WTB and someone will likely have one:
http://www.subaru-svx.net/forum/
or
http://svxworldforums.com/
post Feb 29 2016, 09:20 AM
Post #508
QUOTE(Chris H. @ Feb 28 2016, 04:03 PM) *
I'm expecting lots of pics. (IMG:style_emoticons/default/biggrin.gif)
Chris H.
post Feb 29 2016, 09:39 AM
Post #509
You'll have some my friend. Appreciate the (IMG:style_emoticons/default/poke.gif) . Definitely want to document the manifold flip.
Chris H.
post Mar 13 2016, 07:43 PM
Post #510
Well I finally got the engine out. There she sits.
That's a lot of work. Still need to clean up the mess. I'll be working on it this week.
Lesson #1 - NEVER EVER do anything "for now". I have a list of stuff I wish I did all the way the first time but wanted to get the car running and driving quickly. It's a long list.
Look at that hole. Always makes you think "hey, what else could I shove in there?" Starting to get an itch for an LS engine...but we'll stick with this one for now.
914forme
post Mar 13 2016, 07:56 PM
Post #511
(IMG:style_emoticons/default/agree.gif) LS and a boxster transaxle share looks tempting, but then like you, I'll stick with what I go for now.
Cracker
post Mar 13 2016, 08:06 PM
Post #512
Do it and you'll never look back...I promise.
Tony
QUOTE(Chris H. @ Mar 13 2016, 08:43 PM) *
Chris H.
post Mar 14 2016, 07:50 AM
Post #513
If I go that way might as well get a new crate motor. Bob was saying you can get one for ~$5500ish if you wait for a sale. That's without the ECU but still...good deal for a new one. The days when you could find a nice used Camaro SS for $2k and pull the engine are gone. Then there's the Boxster 6 speed and the very expensive adapter plate....wow! How's the gearing on the 5 speed? Go big or go home? 6 speed or nothing?
It's a couple years out but why not start planning it now.
mgp4591
post Mar 14 2016, 08:18 AM
Post #514
QUOTE(Chris H. @ Mar 14 2016, 06:50 AM) *
I didn't catch why you were pulling your engine - installing a Subaru trans? Engine reseal? Bored?? (IMG:style_emoticons/default/blink.gif)
post Mar 14 2016, 08:22 AM
Post #515
Alright Chris, you cut a fat Hog in the ass. (IMG:style_emoticons/default/piratenanner.gif) Feels better now doesn't it. And you hit the nail on the head about that "do it for now" construction. That engine bay looks clean as a whistle. BTW, I'm giving you a "C" on pic's. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/poke.gif) Are you using a Polaroid and can't afford the film? (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) Seriously, take lots of pics. There are other guys using the EG that will benefit from those pics'. (IMG:style_emoticons/default/shades.gif)
Other than the manifold flip what's on your plate now that the engine/trans are out? (IMG:style_emoticons/default/popcorn[1].gif)
Chris H.
post Mar 14 2016, 10:29 AM
Post #516
LOL very funny Kent (IMG:style_emoticons/default/biggrin.gif) . Yes I will definitely pick up the pics thing. Confession...I feel pretty dumb that I did not put a coolant drain valve in...and made a pretty big f&*(&*(ing mess draining the coolant. No other way to put it. One of the many things I should have done correctly the first time (IMG:style_emoticons/default/headbang.gif) . No matter how many times I thought it was dry, more kept coming when I leaned the car this way or that way. So because we have small dogs it was like a haz mat spill every time more than a few drops hit the garage floor. Clean, scrub, wipe floor, rattle the hoses again, etc.
So Kent and Mike, I need to reseal the oil pump, flip the manifold (not as easy as it sounds as George mentioned), check all the sensors, clean the engine and trans a little better, tidy up the wiring.
ThePaintedMan
post Mar 14 2016, 10:47 AM
Post #517
Good stuff Chris! If you decide to try the spacer route for flipping the intake, the best version I found is made by this guy:
http://svxworldforums.com/forum9/6230.html
Also, sorry to hijack (once again) - Chris, do you remember, in your reseal kit, are the coolant crossover tube gaskets included with it?
jimkelly
post Mar 14 2016, 11:03 AM
Post #518
Delaware USA
interesting. gives some points to a 4 install from a 4 car that had a 5 spd. clearly i need to read this thread from the beginning : ) nice work!
QUOTE(Chris H. @ Feb 26 2016, 06:46 PM) *
Right, tunability, and also there are some quirks associated with the fact that the ECU is for a different car.
For the EG33, stock ECU concerns are:
- Some experience a sudden stall issue because all US SVX's are automatic. When you convert to 5 speed there is not a constant "load" on the engine and it can stall.
- There is also sometimes an idle issue for the same reason
- Lot of extra wires going to things you won't use like the PS pump, etc
- EGR and old school atmospheric pressure sensor (eliminated with Megasquirt)
- The "learning mode" is eliminated with MS which is a pain when you unhook the battery
- The rev limit is 6500. With MS you can go to 7400ish
But the ability to tune it to your liking is the best part.
Chris H.
post Mar 14 2016, 11:58 AM
Post #519
QUOTE(ThePaintedMan @ Mar 14 2016, 11:47 AM) *
Excellent info, thanks George! You can comment or ask questions any time. I don't mind at all.
So I think you are talking about this pipe:
If so then yes. They are just little donuts. Small but very important. Also comes with one for the dip stick holder thing. One of the most likely areas to leak.
Jim, MS has a plug and play model for certain 4 cylinder cars, which means you could literally just plug it in to a stock harness and it would already have a base map set up and everything. 2002-2005 WRX I think.
mgp4591
post Mar 15 2016, 04:12 PM
Post #520
Chris, while your engine is out how about some pics of your cradle showing a little more detail for us curious types? (IMG:style_emoticons/default/popcorn[1].gif)
a914622
post Mar 15 2016, 05:36 PM
Post #521
Chris
The problems you listed on page 25 are mainly caused by no speed sensor or the one that "fools" the ecu. Did you rig up a 5 pulse speed sensor? The vss probably needs cleaning as well.
The computer chip can be hacked and changed. I have yet to do the svx but I have done a obd1 for the 2.2. I will need to did up the info on the chip set. BUT I think the performance end is pretty good.
I didn't read thru the hole post. I will later.
Did you need an extra ecu harness? I probably have at least one.
Jeff
Chris H.
post Mar 15 2016, 05:55 PM
Post #522
Hi Jeff,
Nice to hear from you. Hope all is well. I hope I describe this correctly...
So when I had no speed sensor hooked up at all the car just had an occasional stall issue and an idle issue, which I think is common since the SVX is automatic. If there wasn't enough load the car would stall. Late last year I took the speed sensor that I had saved from the SVX trans and installed it in the 2006 WRX trans I am running. Screwed right in just fine. Although I noticed a huge improvement in the idle and some behaviors, it seemed to bog down and stutter, especially when I opened it up, but also on takeoff from a stop. It's a '95 so it doesn't have that '92-'93 issue that some might be thinking of where the car bogs down off the line. I was wondering if it was just a loose wire or something. Maybe the IAC valve was sticking...something like that. I think there are two speed sensors on the SVX. Do I need to rig something else up too? Would a different VSS be better?
Steve (914forme) was looking for an ECU harness, but if you have MORE than one I'd take one too. Happy to throw some $ your way. If you just have one Steve is welcome to it. He deserves it after welding about a mile of sheet metal (IMG:style_emoticons/default/biggrin.gif) .
post Mar 15 2016, 06:42 PM
Post #523
Damn sure sounds like the VSS is screwy. I'd change it out but I don't know whether it's a mis-match or simply defective. (IMG:style_emoticons/default/confused24.gif) Wonder how you can test one? (IMG:style_emoticons/default/idea.gif)
a914622
post Mar 15 2016, 09:20 PM
Post #524
Chris
Thanks good to be back. Iv been helping a guy with the 95.5 basterd child swap into a type 3.
Is the vss all the way closed just sitting? I would pull it out and see if crap has cloged it. Second the vas is conected to the outside port on the switch valve?
As far as flipping the manifold hang on .. I am working on a fix for the svx to fit the vanagons and the 914. I just did one for the type 3 2.2 but I'm not sure on the svx. I'm working on an extra manifold as I write.
You have inspired me to get this think back to smoking tires.
- Lo-Fi Version Time is now: 20th April 2025 - 09:30 PM
