45 Pages V « < 26 27 28 29 > »
> My 3.3L Subie Conversion Thread, Got me some 914rubber stuff
Chris H.
post Mar 15 2016, 09:41 PM
Post #525
I'll pull it and shoot some pics tomorrow. I wired it up exactly as it was before using the stock wiring harness end.
Let me know on the manifold situation! Sounds like something quite a few people would like.
Cracker
post Mar 16 2016, 04:47 AM
Post #526
Chris - Sorry for the late reply...I don't have any experience with the 5 speed. Several of the members here have them behind Subbies I believe. The ONE thing I do know is they have a smaller R&P - if your car would ONLY be a hot rod/street car. I highly doubt you'd ever have a problem. I don't know if the adapter, flywheel and clutch pack is dynamically cheaper than the 6-speed - maybe.
It is not generally a cheap way to go (Unless you're are BOB)...he can make anything happen for nothin'!
All the best and enjoy what you've got!
Tony
QUOTE(Chris H. @ Mar 14 2016, 08:50 AM) *
How's the gearing on the 5 speed? Go big or go home? 6 speed or nothing?
Chris H.
post Mar 16 2016, 08:58 AM
Post #527
QUOTE(Cracker @ Mar 16 2016, 05:47 AM) *
Hey no problem Tony. I thought maybe the adapter would be a lot cheaper on the 5 speed...if not then the 6 speed seems like the only way to go. Is the adapter really that much more complicated that it costs $3k vs the usual $550 or so? Must be.
Cracker
post Mar 16 2016, 09:03 AM
Post #528
Again, I don't know if the adapter, flywheel and clutch are different between the two - someone here surely can chime in (who has a 5 speed version - same as the audi/vw variants). It is NOT just the adapter plate - that price includes the entire assembly (adapter, flywheel, PP an clutch). For the 6 speed - it is quite impressive and much more robust than the standard set up.
Tony
QUOTE(Chris H. @ Mar 16 2016, 09:58 AM) *
914forme
post Mar 16 2016, 09:38 AM
Post #529
QUOTE(Chris H. @ Mar 15 2016, 07:55 PM) *
Hi Jeff,
Steve (914forme) was looking for an ECU harness, but if you have MORE than one I'd take one too. Happy to throw some $ your way. If you just have one Steve is welcome to it. He deserves it after welding about a mile of sheet metal (IMG:style_emoticons/default/biggrin.gif) .
It is yours Chris, for what I am doing with the car I would like things like launch control etc.... That being said I am still really thinking about SDS, as they have done EG33s and turbo EG33s.
So I am ditching the intake upper section at a bare minimum. Trying to determine if I am going single manifold or ITBs. Part of me really wants to do ITBs (IMG:style_emoticons/default/happy11.gif) But Single manifold is a lot easier to turbo if I wish to do that latter. Maybe build both as I like to build
a914622
post Mar 17 2016, 10:15 PM
Post #530
So it looks like the manifold mod is a little more than I was going for. I was going to cut the Tbody surface 90 deg to the secondary manifolds and install keenserts to bolt the throttle body back on. Not enough meat on the svx manifold. I'm going to make a plate and see if the welder can/will spark things back together?
It should move the Tbody .5 inch froward and point straight back not up and back.
I pulled an extra vss out of the stash to check the bottom bushing. It had a lot of wear and I suspect was hanging up or leaking air.
motoTrooper
post Mar 18 2016, 07:59 AM
Post #531
Hey there! I've been avidly reading the EG33 builds here and wanted to comment and thank you all for your pioneering work. I am planning a conversion but into a different car -a 1977 Lancia Scorpion. Seems apropos as like the 914, the Scorpion was a weird cast-off stepchild with a lot of potential. Just needs love, understanding, and an infusion of triple the power to show what it can do... (IMG:style_emoticons/default/sawzall-smiley.gif)
Best regards,
Christopher
Chris H.
post Mar 18 2016, 05:04 PM
Post #532
QUOTE(a914622 @ Mar 17 2016, 11:15 PM) *
Sounds interesting Jeff. BTW...the VSS you're describing doesn't sound like mine.
Here's the one I am using.
Screws right in to the WRX trans but it's from the SVX trans. The T shaped part spins which is the speed indicator. It has 3 leads on top. Power, signal, ground. seems to spin OK. Don't see any bushings unless they are missing? Maybe I need to lube it and put some RTV on the threads to make sure it gets a good seal on the trans.
Christopher,
I'm familiar with the Scorpion. Very cool little car. Not many left out there. You're putting an EG33 in it??? Post some pics!
mgp4591
post Mar 18 2016, 05:23 PM
Post #533
QUOTE(motoTrooper @ Mar 18 2016, 07:59 AM) *
Best regards,
Christopher
The Scorpion has a transverse layout if I'm thinking correctly. An ideal candidate for an MR2 drivetrain or a Honda B16-18 setup- that little bugger would fly!! Good luck with your build! (IMG:style_emoticons/default/w00t.gif)
post Mar 18 2016, 07:48 PM
Post #534
Chris, can you look inside the trans to see the where it seats? I ask because I don't remember if mine looks like that on the trans side. Then again at this age I can't remember what I had for breakfast.
motoTrooper
post Mar 18 2016, 09:33 PM
Post #535
The Scorpion I got is a basket case. I have run the mental gamut of putting in an Alfa 164 V6 (cool but they have their own issues and it's been done repeatedly), a Honda/Acura K20/K24 IL4 (powerful & cool but a four banger and sounds like one), a Honda V6 (not a total fan of the transverse layout), the Subaru flat 4 (they all sound like a subaru flat 4 but have the longitudinal layout I like), which brought me to the EG33 (strong, smooth, low center of gravity, balanced longitudinal layout, and sounds like a Ferrari BB512!) The EZ30's appealed also but are more expensive as I'm sure you're aware.
I need to fabricate all the floorpans and address rust issues too so it's going to be a long row to hoe. I'll happily share my progress if you're interested. I love modding vehicles, I've built a few cars and a bunch of motorcycles. I like the friendly camaraderie that I have seen reading through the threads here. (IMG:style_emoticons/default/beerchug.gif)
Chris H.
post Mar 18 2016, 10:05 PM
Post #536
QUOTE(76-914 @ Mar 18 2016, 08:48 PM) *
Chris, can you look inside the trans to see the where it seats. I ask because I don't remember if mine looks like that on the trans side. Then again at this age I can't remember what I had for breakfast.
Here's what the other end looks like Kent:
The T piece fits in that slot (or it won't screw in). The WRX one looked pretty strange on top. Couldn't tell where the wires went. It was just a round piece. The lower part was the same. It was made of plastic.
Christopher, post away! We like pictures (IMG:style_emoticons/default/biggrin.gif) . FYI the EG33 is fairly heavy for a car of the Scorpion's size and weight but if you like it, go for it. A VW VR6 might work transversely... (IMG:style_emoticons/default/idea.gif) . Only if the longitudinal layout didn't end up working out. The Audi 2.8 is also a nice small motor (not the narrow angle V6). Could mount that to a Boxster/Passat Trans.
a914622
post Mar 19 2016, 09:05 AM
Post #537
Chirs my mistake. I had an air leak on the vain in the intake. I was thinking if yours was sticking or leaking air that might be the shuttering problem. The vacuum valve it hooks up to had a crack on mine so it wasn't fully opening or closing the "air splitter" in the intake.
The trans pulse should be rock solid. The trans had one or did you have to put it in? Some of the ty756 trans didn't come with it and the have no gear inside. If you have a wrx tran it's probably a ty755?
motoTrooper
post Mar 19 2016, 09:59 AM
Post #538
Quick question -could you give me some dimensions of the engine/trans assembly?
Assembly length, engine width, distance from front of engine to trans axle stubs would be greatly appreciated!
motoTrooper
post Mar 19 2016, 11:11 AM
Post #539
Just found these for comparison sake, the 914 has a 6" longer wheelbase but they seem pretty close...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1111.photobucket.com-19774-1465832035.1.png)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1111.photobucket.com-19774-1458407477.2.png)
914forme
post Mar 19 2016, 01:11 PM
Post #540
QUOTE(motoTrooper @ Mar 19 2016, 01:11 PM) *
Well the entire thing from front pulley to end of the shift rod is just under 51"
It is just under 33" wide
And from the stub axle center to the front pulley you have 29" approximately.
All the numbers are approximates but they will get you close enough with a little bit of tape work or a couple card board boxes you can figure out if it will fit
Chris H.
post Mar 19 2016, 01:36 PM
Post #541
QUOTE(a914622 @ Mar 19 2016, 10:05 AM) *
Ah that explains it. That would definitely cause issues. I decided a while back to switch back to the stock intake just to make sure I eliminate any potential compatibility problems. The engine ran fine in the SVX. Just something simple I'm sure. The trans is a 2006 and the gear was in there before. Pretty sure it should work the same way.
Chris H.
post Mar 19 2016, 03:12 PM
Post #542
Measurements for you Christopher...these are approximate.
About 28" wide
The engine itself is just under 22" deep, then you have to add the snorkel for the stock intake manifold, which would add about 4" or so
The engine and trans are about 48.5 front to back, again, add 4" or so for intake.
The height of the engine is tough because I pulled the manifold off but I would guesstimate it at about 26" from oil pan to the top of the manifold.
motoTrooper
post Mar 19 2016, 03:14 PM
Post #543
Thanks to both of you!
Chris H.
post Mar 19 2016, 03:20 PM
Post #544
And then I did a tiny amount of work (IMG:style_emoticons/default/biggrin.gif) .
Got the timing belt cover off, pulley, etc:
The leak is right here...VERY small one but I hate oil leaks.
At first I was a little panicked because that black stuff looked like JB Weld....which would mean something bad. But it's not. It's black RTV. Scraped right off and is pliable. Someone tried to stop the leak temporarily with it. Any idea how much work that was in an SVX? Brings lazy to a new level.
- Lo-Fi Version Time is now: 21st April 2025 - 12:13 AM
