45 Pages V « < 29 30 31 32 > »
> My 3.3L Subie Conversion Thread, Got me some 914rubber stuff
76-914
post Apr 14 2016, 08:54 AM
Post #585
It shouldn't be (IMG:style_emoticons/default/confused24.gif) ?? It's SS and not the "wire rope" style. I would caution that you keep the rpm below 1500 rpm. They will shoot out little wire darts if run too fast. Just don't use a Steel brush on aluminum.
motoTrooper
post Apr 14 2016, 10:12 AM
Post #586
Maybe a dremel with a small wire brush attachment? You can sleeve it with a bit of shrinkwrap to keep the wire under better control and use low rpms.
post Apr 14 2016, 10:21 AM
Post #587
914-6 GT in waiting
Brake clean and a brush. The brake clean does most of the work.
Chris H.
post Apr 15 2016, 07:47 AM
Post #588
Thanks guys. I was thinking of a 3m green scotch brite pad material in a bullet-ish shape that could be used with a drill linke one of those rim cleaner/buffers but I guess soft metal brushes and cleaner will have to do.
Feel free to invent that green pad thing and I'll test it (IMG:style_emoticons/default/biggrin.gif) .
mgp4591
post Apr 15 2016, 01:57 PM
Post #589
QUOTE(mepstein @ Apr 14 2016, 10:21 AM) *
Brake cleaner is amazingly versatile and does a helluva job. With the supplied spray head tube, it reaches everywhere and dissolves everything. A soft brush or sponge should take care of everything else that you can't take off by scraping or brushing. Take off all the thick stuff first, then use the spray for everything else. It works!
Chris H.
post May 19 2016, 08:39 PM
Post #590
I'm back at it. Kent didn't even have to (IMG:style_emoticons/default/poke.gif) me this time! My kid graduated from high school last weekend so my schedule is getting much more open.
Cracked into my goodies from Bob's...there's gotta be 10 coils in that pile along with the rest of the stuff. The smell of old gas is dominating the air for now...but I'm working on that. Just a small amount in the fuel rails is all it takes. That stuff was sitting at his house for a while.
2 sets of injectors!
Here's a riddle for you...the larger, more substantial (temporarily smellier) injectors came from Bob's car. The all plastic smaller wimpy ones came from mine.
My car ran fine with the smaller ones. I'm thinking I'll use the ones from Bob's car though. They have a larger metal tip and when I search the OEM part number (16611AA310) the pic looks like the bigger ones. Don't know for sure if the later cars used the more plastic-y ones or if these were replacements. Anyone hate the idea or am I good? I'll send the injectors to Mr Injector for a cleaning and re-sealing.
BTW the plastic ones' pintle caps (plastic piece at the end) were VERY brittle.
Three of them just crumbled off when I touched them. Mr Injector replaces those as part of the service. I might get both sets serviced, we'll see.
Next up I'm cleaning up the engine and intake parts, getting ready to flip the intake. Back to the garage and I'll update later.
Chris H.
post May 19 2016, 09:52 PM
Post #591
This is the vacuum canister that is attached to the underside of the intake. I had to JB Weld one of the tubes on mine. Now I can swap it!
Here's a good example of Bob's skill level. You have to make a blockoff plate if you eliminate the EGR system. Mine is a piece of scrap metal. Bob of course pinched and perfectly welded the end of the original piece right down the center. Think I'll use his (IMG:style_emoticons/default/biggrin.gif) .
Air tight seal
Next (when my dremel recharges) I'll be fixing a small problem that's a real PITA for me. This little nipple helps regulate the fuel tank pressure in the SVX. Not needed for the 914.
I left this on there in phase 1 and it really got in the way of things at the back. I'm planning to cut the nip off right past the nut and fill it with JBWeld. I have an extra one if anything happens but it should be fine.
Chris H.
post May 20 2016, 07:45 AM
Post #592
And now it's just a bolt (IMG:style_emoticons/default/biggrin.gif) .
I tried looking for a bolt to fit into the hole but it's tapered and it's a strange size (I think M10x1.0). Since there can be NO leakage I didn't want to risk using something that might fail. I'll wait a week and this sucker will be solid.
ThePaintedMan
post May 20 2016, 07:50 AM
Post #593
Cool stuff Chris! Did you remove the injectors from the rails, or did Bob do that before you got them? I have not been successful at getting mine out and I'm really worried about breaking them.
post May 20 2016, 08:11 AM
Post #594
QUOTE(Chris H. @ May 19 2016, 07:39 PM) *
You cut it close. (IMG:style_emoticons/default/lol-2.gif) Glad to see your back on it. You need to start planning your first trip to an event in your car, now. Our trip to AZ was a good shake out run and I'm in the process of tweaking little things. Re-doing the exhaust for the 4th time. (IMG:style_emoticons/default/headbang.gif) I'll post after I have it nailed. Keep the pics coming.
Chris H.
post May 20 2016, 08:48 AM
Post #595
QUOTE(ThePaintedMan @ May 20 2016, 08:50 AM) *
I removed them and honestly they were a bitch to get out. They're in there so tight that I didn't know if they were keyed with a notch or not. They are not keyed, and technically rotate "freely". I sprayed a small amount of WD40 into crack between the injector and the rail underneath and that got them a little loose. The technical procedure is:
- rotate injector 90 degrees so that the top is over either lip where the cover screws in
- use a VERY WIDE screwdriver to pry the injector up (1/2")
- if that doesn't work find a fairly soft surface, set the rail on it evenly and gently tap the rail a bit with a small rubber mallet.
Here's a set of directions I found.
Injector Removal
Hey George what do your injectors look like? Bob's or mine?
ThePaintedMan
post May 20 2016, 09:14 AM
Post #596
Yeah, I tried the service procedure with no luck. Was super worried about breaking something. I'm thinking of building a little jig to grab them at the top, tighten a screw and pull them out, sort of like a mini 2-jaw puller. Since I haven't gotten them out, I don't know for sure, but they have the pintle caps on the bottom, so I think they're the smaller version.
Chris H.
post May 20 2016, 09:49 AM
Post #597
Pintle cap should = smaller one. weird that Bob's are so much bigger!
Chris H.
post May 20 2016, 10:54 AM
Post #598
Yeah so I'll just (IMG:style_emoticons/default/dead horse.gif) OK George (IMG:style_emoticons/default/biggrin.gif) ? So on Rockauto all of the injectors pictured for the SVX are Bob's style. I think either is fine but most likely ours have been replaced with cheaper ones. So that means unless one or more of his are bad we'll have some extras of the pintle cap variety. Good news for you !
914forme
post May 20 2016, 11:02 PM
Post #599
Keep it up or else I might beat you back on the road (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/screwy.gif)
Don't worry that was the optimistic project manager in my head, he tends to over estimate the rate of work and severely underestimate the amount of time it will take.
I have a bunch of parts I should send your way also, as I don't need them anymore. I just ordered up my new EFI system. It is an SDS, a little primitive compared to the MegaSquirt Pro or III. I finally decided to (IMG:style_emoticons/default/ar15.gif) as I have liked the design for a long time, and they do lots of EG33 work in aircraft. Yeah I don't have launch control, flat throttle shifting and a million other options. But If I wanted all that stuff, I would buy a new car. The 914 needs to have a certain basic raw feel to it, make it to nice and it becomes a Cayman!
Chris H.
post May 30 2016, 09:46 AM
Post #600
You just might beat me Steve. You're a welding madman.
Got a bunch of small stuff done which I will update, but working on flipping the intake now.
Question for George (The Painted Man)...
So when I put the intake in place backwards the ^*&^*ing (gosh darned) diaphragm for the induction control valve hits the coolant pipe. This keeps me from bolting the manifold down by about 1/2 inch or so on the left (passenger) side.
Just BARELY off!
But it seems like even with a spacer it'd hit a little.
It's also pretty amazing how HIGH the intake is flipped around. WOW!
Did you run into this George? I know Bob mentioned he ran his without the induction control and didn't notice anything. I'd like to run it if I can though. The coolant pipe is aluminum so I'm not skilled enough to carve a notch in it and weld it up, and I'm not sure if the flow would be too restricted either. Still thinking about it... (IMG:style_emoticons/default/idea.gif)
Well, If I would have looked at George's thread for 5 seconds I would have gotten the answers. Looks like he addressed this in his flip. Be back soon!
post May 30 2016, 02:24 PM
Post #601
Ha ha. I was just thinking to myself that he addressed that. Looking for more from you! (IMG:style_emoticons/default/beerchug.gif)
flmont
post May 30 2016, 06:37 PM
Post #602
Hey Chris H,....is this a new belt and re-seal or did u do any performance work,..like cams,and injector's,...??? Iam trying to decide 3.3 or 3.6 install ,..I have the 3.6 ,but not alot of info for that install,..I'am thinking 3.3 if you can get the pwr from them...??? Thanks Frank
Chris H.
post May 30 2016, 07:57 PM
Post #603
Mine is stock, so it should be about 230 hp. That's quite a bit for a 914 really. If you already have the 3.6 I'd run it stock rather than spending big $$$ on massaging an EG33.
flmont
post May 30 2016, 08:02 PM
Post #604
Yea,..I know , its about another 4500.00 to get the 3.6 on the road,..but I like the EG33 looks,..and they do sound good,...I have no idea what the 3.6 will sound like,..Good luck man,..!!! and Thanks
- Lo-Fi Version Time is now: 25th November 2024 - 04:23 AM
