| Chris H. |
Mar 21 2013, 09:00 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,070 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Never done a timing belt before so I wasted a lot of time re-doing it because I thought it was incorrect. Lined up the marks perfectly…cranked the engine one revolution…and the dang belt marks never realigned with the marks on the engine. Apparently they don't have to. The marks are for the initial alignment, so as long as the arrows on the engine line up with the ones on the belt wheels it’s all good. Hope that saves someone a couple hours. And if you screw it up, no worries. The EG33 is a non-interference engine. Didn’t expect that but it’s true. The car won’t run, but you won’t bang the valves against the piston tops.
Left side: ![]() Center: Right Side: ![]() Note how after one revolution the arrows on the wheel line up with the ones on the engine but the timing belt marks do not. |
| Chris H. |
Mar 21 2013, 09:24 PM
Don’t have any pics of this, but I did try flipping the intake…I’m not confident enough in my skills to do it this time. Too many variables if it doesn’t start once I get it done. When I flipped both the FI runner section and the top section there was interference with the AC unit. Found a company called Outlaw Engineering who will do a ¼” phenolic spacer for the SVX, but even with that it would still interfere. When I flipped just the top piece the fuel lines underneath didn’t cooperate. It can be done though, maybe version 2.0.
So on to the trans…mine is 2006 WRX unit, so it is a “turbo” trans (2.5T). Bought Ian’s kit to lock the diff and change to the older stub axle style. Ian is assembling a very concise set of photos to explain the process so I won’t outline all the steps since his will be better. First, the when you take off the center diff, which is the tail section of the trans it’s not immediately obvious what to do next. Just pull out this stuff: ![]() The center diff is worth between $150 and $300 depending on the year and how many people need it at the time you want to sell it. Here's the diff lock installed: ![]() To get the nut off for the diff lock you need to take the next section of trans cover off. You'll probably need a new gasket or some gasket maker. Mine tore into several pieces. It's made of a paper-ish material. New stubs in...ready to go. ![]() Tail end...the stock bolts are way too long for the cover. Shorter ones are provided in the kit. ![]() Some "gotchas": 1. If you are installing stub axles be very careful with the axle seals. I bent one by slightly tapping it with a wrench. They should sit flush with the axle holes. I also pushed one in a bit too far but was able to get it out. This is "way too far" in: Not quite German quality engineering we're dealing with so things don't all fit with a crisp snap like we are used to. 2. When you remove the middle section of the trans cover to get at the differential nut the gear selector shaft will just fall out onto the floor which is alarming. Don't worry, you did not break it. |
| Chris H. |
Mar 21 2013, 09:43 PM
Also bought a very inexpensive 2006 Impreza gauge cluster from e-bay. Thought I could take it apart and not feel bad if I break it for $36. I'd like to see if I can separate the cluster into three separate gauges similar to the stock 914 look....not sure if it's possible but we'll see. I'm torn between this and using an electronic Porsche VDO speedo.
Front: Back: ![]() Since the gauge is from a 2006 as is the trans the speedo should work. The tach will need an adapter like this one: Tach Adapt Temp will be directionally correct and I plan to use an Impreza fuel pump per BIGKAT's recommendation. |
| Chris H. |
Mar 21 2013, 09:50 PM
Next step is the engine wiring. I hear that's A LOT OF FUN.
Here are a few links that were helpful so far: H6 swap thread Bremar 2WD conversion directions SVX Engine PDF SVX Engine Reseal Thread Questions and comments are welcome as always. |
| a914622 |
Mar 21 2013, 10:10 PM
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Sweet. I just started on a second harness cut down. If you run into problems I could send some pics your way. I found a good deal on a hole swap set up. (Maybe turbo ver 2.0)
You will want to change most of those seals in that box pic. The top manifold can be flipped but it is a PITAss. It took 2 days to figure relocations of needed stuff and removal of the exahust gas regurgitater system. I would stay stock if you can, But done forget the vacuum lines. They will be hard and brittle. Keep up the good work. (IMG:style_emoticons/default/beer3.gif) |
| Chris H. |
Mar 22 2013, 07:03 AM
Thanks jcl. Yes most of those seals are on the engine. I have a list of them all if anyone needs it.
JCL when you removed the EGR stuff did you just block off the connection at the intake? Was planning to do that but just making sure I'm not overlooking anything. Pic: ![]() |
| a914622 |
Mar 22 2013, 08:35 AM
Yep. I plan on making long tube headers. A lot of the vanagon guys yake it off.
| Chris H. |
Mar 22 2013, 09:04 AM
Nice. Picked these up from Bob (BIGKAT) along with a custom built exhaust. One less thing to mess up for me!
| a914622 |
Mar 23 2013, 07:33 AM
sweet. And it looks like they dont have the "gas regurgitator" bung.
Hey and its way off topic but the Goop is also great for cleaning Granite counter tops if they havent been sealed. Goop keeps from drying and cracking the granite. I didnt even think about using it to clean engines. I have always used Jacobs paint stripper and a power washer. All right back to building... |
| Chris H. |
Mar 24 2013, 02:56 PM
sweet. And it looks like they dont have the "gas regurgitator" bung. Hey and its way off topic but the Goop is also great for cleaning Granite counter tops if they havent been sealed. Goop keeps from drying and cracking the granite. I didnt even think about using it to clean engines. I have always used Jacobs paint stripper and a power washer. All right back to building... No bung. That thing is impossible to get off of the stock header....it's baked on. By the way I found a really good resource for the vacuum line info. Spellis it out very well in terms of what is needed, diagrams, etc. Vacuum Lines Hope it helps someone.... |
| Chris H. |
Mar 28 2013, 08:58 PM
Time to start reinstalling the accessories onto the engine. The AC/alternator bracket had a lot of surface rust so I had to clean it up a bit:
Before: Ground off the chunky rust: Painted with high temp paint: |
| Chris H. |
Mar 28 2013, 09:04 PM
I heard the knock sensors were one of the keys to a smooth running Subie engine. On the subaru-svx site the experts say if there are ANY cracks at all replace them. Just checked mine and both are cracked. You can find them cheap, just ordered two for $12.99 ea on e-bay. Free shipping.
Badly cracked: One crack: Link to the e-bay site: Sensors |
| 76-914 |
Mar 28 2013, 09:09 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,828 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
| Chris H. |
Mar 28 2013, 09:31 PM
He special ordered them from somewhere...I THINK Outfront Motorsports but could be wrong on that.
Here's a link to something similar... Outfront He did make the exhaust system that mounts to it. It's jammed in the corner of my garage or I would post some pics. There are some in his blog if anyone wants to check it out. |
| Chris H. |
Apr 2 2013, 09:25 AM
Tackled the engine wiring harnesses....
Because there was a gathering of nesting materials under the intake the wiring needed to be checked pretty closely. Mice love to chew through 914 wires as we know, but it looks like Subie wires don't taste quite as good. Before: ![]() ![]() ![]() Nothing was chewed, but there were some nicked wires, which likely explained the blinky lights on the dash. It was raining when I bought the car and every time I started it a different set of warning lights lit up. The engine ran great so I figured it was a wiring issue... ![]() ![]() A little liquid tape..then regular electrical tape ![]() ![]() And the end result: ![]() The OEM covering was plastic tubing that can be found at Harbor Freight. It held up surprisingly well so that's what I replaced it with. The wiring underneath was very healthy and pliable. Of course I covered every last one even though it was not necessary... (IMG:style_emoticons/default/biggrin.gif) Next up are the vacuum hoses, reinstall intake, alternator, etc. Then the main wiring harness. I want to test fire the engine before I put it in the car so that it will be easy to troubleshoot if there is something not connected right, etc. |
| wingnut86 |
May 4 2013, 08:49 PM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Subd:-)
| Chris H. |
Jun 4 2013, 05:44 PM
Well things have slowed down a LOT but they are about to get back on pace. Been working on the main wiring harness...FUN!
This is below "Andy's camera" quality...did I even point it at the harness? ![]() A laundry basket full of electrical tape...from unwrapping the main harness...probably a couple miles of it there. Got the engine harness back in Refinished the flywheel even though it might have been OK - looks much better. ![]() Hydraulic clutch bits...still need to decide whether to use metal or poly lines...leaning towards poly. ![]() |
| Chris H. |
Jun 4 2013, 05:59 PM
Couple of notes....
1. Be very careful to choose the right clutch kit. For example, my trans is a 2006 WRX, which supported a 2,5T. Although many sites and ebay sellers will say that the cheaper KSB03 or KSB04 clutch kit works, they DO NOT. The one you need is the FJK1001. It's $100 more but if you use the cheaper one it won't engage properly and will chew up the clutch disc...search NASIOC for cross-reference for the clutch that works with your trans. 2. Apparently Subaru changed the oil separator that is under the flywheel from metal to plastic in the '90's...and it wasn't a good idea. Then they went to aluminum...still bad. Now the replacement is steel. If your engine has one made of plastic or aluminum change it. Both leak like crazy. Good thing I poked a hole in mine trying to lock the flywheel! YEAH! Meant to do that! Here's the old one and new one...universal and fits several models. The new part # is 11831AA210 ![]() |
| Chris H. |
Jun 4 2013, 06:12 PM
Here's what the oil separator plate looks like installed:
Lately it's been a game of hurry up and wait...I failed to realize that the bolts that hold the flex plate on the 3.3 are shorter than what is needed for the flywheel...now I had to order the bolts! No Subie dealer has them: Attached the engine mount (fits great so far) and got the engine down off the stand. I made this boxed wood frame so that the weight is evenly distributed and the engine and trans will be in the positions they will be in the car. It was VERY easy. Plus it keeps the oil pan off the ground. Once my bolts come in (and a couple of other issues come up and get resolved) we'll mount the engine to the trans and test fire it. Still have a lot of wiring work to sort through... |
| euro911 |
Jun 4 2013, 11:40 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
What supports the front of the engine, Chris?
Looking good (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 14th December 2025 - 04:58 AM |
