My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
76-914 |
Jun 6 2017, 09:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,520 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif) Remember the post card with the Cow standing on her own utter which read "So you think you've got problems!"? Well don't feel alone my friend. I damned near took mine out back and shot it this last weekend. I won't pollute your thread with my problems though. (IMG:style_emoticons/default/lol-2.gif) But, as with every problem there lies an answer within and I finally found mine. Looks like we may be posting in tandem again. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif)
Madswede |
Jun 6 2017, 09:51 AM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
So "how's it going" with the MS3X install? I think it's best summed up by the first 43 seconds of this clip. ... Bob's been helping me a lot but the MS forum has been poor. I think I might post some stuff here in case anyone has other ideas... Please do. I have an older MS installation on my 3.2 twin plug, cammed build with EDMIS and PMO throttle bodies. I've had some of the inevitable bugs to work out after the masterful build by Series9 (Joe O'Brien) that I could share. I've been thinking of improving the current setup with a Clewett TPS (basically a "wide band" TPS) for the PMOs to take advantage of the Megasquirt ability to do ITB tuning maps which is a blend of MAP at lower loads and RPMs and alpha-n under loads/acceleration. I want to get rid of my backfire issues and improve performance. It's complicated! |
Keyser Sose |
Jun 6 2017, 09:53 AM
Member Group: Members Posts: 57 Joined: 1-July 14 From: West Member No.: 17,576 Region Association: None |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif) Remember the post card with the Cow standing on her own utter which read "So you think you've got problems!"? Well don't feel alone my friend. I damned near took mine out back and shot it this last weekend. I won't pollute your thread with my problems though. (IMG:style_emoticons/default/lol-2.gif) But, as with every problem there lies an answer within and I finally found mine. Looks like we may be posting in tandem again. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) Wait. So the solution is to shoot it? Or just threaten? |
914forme |
Jun 6 2017, 10:23 AM
So "how's it going" with the MS3X install? I think it's best summed up by the first 43 seconds of this clip. Bob's been helping me a lot but the MS forum has been poor. I think I might post some stuff here in case anyone has other ideas... Your spoiled by this forum. I'm on lots of others and this place hands down has much less of the (IMG:style_emoticons/default/stromberg.gif) factor. I can name a few others I never go back to., unless I really must. (IMG:style_emoticons/default/dry.gif) Post away I will try to help all that I can, you need the coil pack back? Or are you running the coil on plugs still? |
Chris H. |
Jun 6 2017, 10:43 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
So "how's it going" with the MS3X install? I think it's best summed up by the first 43 seconds of this clip. Bob's been helping me a lot but the MS forum has been poor. I think I might post some stuff here in case anyone has other ideas... Your spoiled by this forum. I'm on lots of others and this place hands down has much less of the (IMG:style_emoticons/default/stromberg.gif) factor. I can name a few others I never go back to., unless I really must. (IMG:style_emoticons/default/dry.gif) Post away I will try to help all that I can, you need the coil pack back? Or are you running the coil on plugs still? Yes I AM spoiled by this forum and the people. Totally agree. Bob has spent HOURS with me but he really didn't use MS on the EG33 for too long before switching engines plus he's 700 miles away. And MS3X is slightly different than MS2. I'm sticking with COP so we're all good on the coil pack (for now at least (IMG:style_emoticons/default/wacko.gif) ). So are you buying Bob's old car? PM me if so. I'll tell you all about it. MadSwede, will do. Post whatever you want to share! The firing order on the 3.3 is the same as the 3.2. Might be able to adapt some tuning. BTW you should have heard the backfire I got when I tried to start this SOB. Luckily the engine was not cycling at that moment and it came out the exhaust. It was right after I stopped cranking it. Sounded like an M80 going off. kaBOOOOOOM. Kent's what's wrong with your car? |
76-914 |
Jun 6 2017, 03:51 PM
Well let's just say my last diagnosis was completely inaccurate. IOW's, I was (IMG:style_emoticons/default/sheeplove.gif) wrong. I'll detail it in my thread so others won't make the same mistake. I will be using the other half of that roll of hose soon if just to clean up the front trunk area. (IMG:style_emoticons/default/beerchug.gif) EDIT: I didn't answer your question, "What is wrong with your car?" Answer; the builder! (IMG:style_emoticons/default/sad.gif)
Chris H. |
Jun 6 2017, 04:13 PM
Ah...still getting a little hot? It'll cool WAY down with the 1.25s. Just try not to have any detours or bends in the hoses. Straight back...think about going underneath this time...way less drama. I can send pics if you need them.
BTW I REALLY want ITBs but the cost is just too much I think. Would look SO GOOD too. |
76-914 |
Jun 6 2017, 05:42 PM
Ah...still getting a little hot? It'll cool WAY down with the 1.25s. Just try not to have any detours or bends in the hoses. Straight back...think about going underneath this time...way less drama. I can send pics if you need them. BTW I REALLY want ITBs but the cost is just too much I think. Would look SO GOOD too. Yep. Engine and radiator temps are perfect but the radiator heats the gas tank. Turns out I'm not the 1st. Tony (cracker) had the same problem. He gave me several pointers. The best being; start by enlarging the wheel well openings! |
mgp4591 |
Jun 7 2017, 12:12 AM
914 Guru Group: Members Posts: 5,390 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Has anyone done any successful ducting to exit out the wheelwells? That seems to solve alot of the problems in other cooling systems in exotics, etc. It would isolate the heat from the gas tank and anything else much better and could be relatively light if it's done correctly.
914forme |
Jun 7 2017, 06:52 AM
Yes several examples.
As much as I like the above unit it is for a oil cooler. I (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/pray.gif) This is for a Radiator |
mgp4591 |
Jun 7 2017, 09:04 AM
Those are great examples but the radiator is what we're concerned with and while the carbon fiber is really cool, most of us don't have the skills for that so I'm looking for possibly a sheet metal creation of some sort. I'm currently working on the brakes and suspension but when I get to that point I think I'll need to come up with something functional for ducting. I'll probably be making some bends with the hose so I'll need all of the help I can get.
76-914 |
Jun 7 2017, 09:08 AM
Those are great examples but the radiator is what we're concerned with and while the carbon fiber is really cool, most of us don't have the skills for that so I'm looking for possibly a sheet metal creation of some sort. I'm currently working on the brakes and suspension but when I get to that point I think I'll need to come up with something functional for ducting. I'll probably be making some bends with the hose so I'll need all of the help I can get. I've considered using canvas w/ metal framing if I end up going this route. Quick and easy to fabricate or remove. (IMG:style_emoticons/default/idea.gif) |
Mueller |
Jun 7 2017, 09:41 AM
Clewett TPS (basically a "wide band" TPS) for the PMOs to take advantage of the Megasquirt ability to do ITB tuning maps which is a blend of MAP at lower loads and RPMs and alpha-n under loads/acceleration. ^Jon, do you have links to this setup configuration and more details about the TPS? |
Mueller |
Jun 7 2017, 09:45 AM
Those are great examples but the radiator is what we're concerned with and while the carbon fiber is really cool, most of us don't have the skills for that so I'm looking for possibly a sheet metal creation of some sort. I'm currently working on the brakes and suspension but when I get to that point I think I'll need to come up with something functional for ducting. I'll probably be making some bends with the hose so I'll need all of the help I can get. I've considered using canvas w/ metal framing if I end up going this route. Quick and easy to fabricate or remove. (IMG:style_emoticons/default/idea.gif) Sounds like an old airplane fabrication method, dope and fabric. http://www.aircraftspruce.com/catalog/kits...srebuilding.php |
914forme |
Jun 7 2017, 10:07 AM
Mike,
I think he is talking about the Hall Sensors for the PMO carb. TPS can not be a wideband. yOu could increase its ability to be more precise ultimately it ends as a voltage reading. Hall Effect TPS for PMO |
burton73 |
Jun 7 2017, 10:12 AM
burton73 Group: Members Posts: 3,569 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Those are great examples but the radiator is what we're concerned with and while the carbon fiber is really cool, most of us don't have the skills for that so I'm looking for possibly a sheet metal creation of some sort. I'm currently working on the brakes and suspension but when I get to that point I think I'll need to come up with something functional for ducting. I'll probably be making some bends with the hose so I'll need all of the help I can get. I've considered using canvas w/ metal framing if I end up going this route. Quick and easy to fabricate or remove. (IMG:style_emoticons/default/idea.gif) Sounds like an old airplane fabrication method, dope and fabric. http://www.aircraftspruce.com/catalog/kits...srebuilding.php You could build the shape out of canvas like you said and then coat it with fiberglass and polyester lamenting resin. I had a fiend do that to build a kayak when I was 11 You would have an item to sell if you used a standard cooling that guys building any water cooled 914 could use. I had heat blowing into my cabin in my old SBC set up in the 70s. “If you want to run cool, you got run on heavy heavy fuel” No I just always thought it was not a good idea to warm up the gas. Bob B |
Chris H. |
Jun 7 2017, 10:09 PM
Ruby914 made that carbon fiber masterpiece. Maybe he would be willing to make some fiberglass copies. Kent I think the thing you need to do is get all of the water lines away from the fuel tank. The larger ones would be a bitch to snake through your longs and then up through the body. I'd just go down the center of the car underneath like I did. None are near the fuel tank even though it looks like it. You could wrap the ends that will be inside the front trunk to keep the heat down too.
Hey Mueller, the latest MS manual has some good info in ITBs. Download the "setting up" manual here and start at page 64: MS3 Manual |
Chris914n6 |
Jun 7 2017, 10:56 PM
Jackstands are my life. Group: Members Posts: 3,352 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You could build the shape out of canvas like you said and then coat it with fiberglass and polyester lamenting resin. I had a fiend do that to build a kayak when I was 11 You would have an item to sell if you used a standard cooling that guys building any water cooled 914 could use. I had heat blowing into my cabin in my old SBC set up in the 70s. “If you want to run cool, you got run on heavy heavy fuel” No I just always thought it was not a good idea to warm up the gas. Bob B Fleece or tshirt cloth would be better, then fiberglass mat the inside for strength. It's how custom speaker enclosures are done. http://www.tribalvisiontruck.com/newsubbox.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/www.tribalvisiontruck.com-431-1496897817.1.jpg) |
motoTrooper |
Jul 17 2017, 10:14 AM
Newbie Group: Members Posts: 39 Joined: 18-March 16 From: Palo Alto Member No.: 19,774 Region Association: None |
Just checking in on the thread here to see if Photobucket had erased all the awesome photo documentation on this site. Still there! Whoo hoo!
motoTrooper |
Aug 24 2017, 03:54 PM
Hey Chris, I started a video series on my Lancia that you inspired with your build thread. This introduction is a bit long and raw and subsequent videos will be shorter and more focused. They will however still be somewhat silly, like me.
https://www.youtube.com/watch?v=u2MQ3dORePI |
Lo-Fi Version | Time is now: 28th June 2024 - 03:47 PM |
