Clutch cable heat protection, Clutch cable heat protection |
1845 |
Dec 30 2012, 01:32 PM
Newbie Group: Members Posts: 27 Joined: 30-July 03 From: Gambrills, MD Member No.: 966 Region Association: MidAtlantic Region |
Anyone have a line on a clean heat sheild product that you can put around the clutch, accelerator and speedo cables to protect them from the heat exchangers?
JawjaPorsche |
Dec 30 2012, 01:37 PM
The accelerator cable is nowhere near the heat exchangers on my car. My clutch and speedo cables are far enough from the exchangers to not be a problem.
Maybe someone else on this forum thinks a heat shield is needed? |
1845 |
Dec 30 2012, 01:44 PM
Sorry, should have been more specific, on the 914-6 the 3 cables all run along the same path under HE toward the transmission. The factory didn't put anything on them and clipped them to the HE but thought I saw a wrapped that someone has used.
jimkelly |
Dec 30 2012, 01:46 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
maybe a cloth exxhaust wrap is all the is needed?
http://www.jegs.com/c/Heat-Shields-Insulat...CFYqZ4Aod_lUAVQ or this sleeve http://www.jegs.com/p/JEGS-Performance-Pro...130487/10002/-1 |
Woody |
Dec 30 2012, 01:47 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
mrbubblehead |
Dec 30 2012, 02:08 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
this is what i use. i use it on the clutch cable, driver side parking brake cable (which sits on the exhaust) and my fuel lines... http://www.summitracing.com/search?keyword...leave&dds=1
gothspeed |
Dec 30 2012, 02:31 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Good stuff listed above (IMG:style_emoticons/default/smile.gif)
Here is another from McMaster Carr: http://www.mcmaster.com/#standard-wire-ins...leeving/=ktklsf Attached image(s) |
Lo-Fi Version | Time is now: 2nd January 2025 - 02:00 PM |
