> Engine Help
Nico914
post Jan 5 2013, 03:56 PM
914 lover/ owner
Hey guys i haven't received my repair manual yet and i need some help with my engine. Like I said i'm new to the 914 world. The engine turns over, its getting fuel but it will not start. I got the firing order correct , it has a new coil and distributer head. Is there any direction you guys can point me in and any help at all? By the way where is the green wire suppose to go coming off of the distributer. Thank you and any help would be great. (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post Jan 5 2013, 04:56 PM
Resident Electrician
Green wire comes from the points (in the distributor) It goes to the negative side of the coil. There is a Black/Violet also on the negative side of the coil. This is the tach wire.
This would explain why you have no spark if left disconnected.
442nd914s
post Jan 5 2013, 06:32 PM
Open up dizzy cap and verify rotor bug turns.
Next, I would check continuity on the rotor bug & coil wire. Of course with NO POWER.
Dave_Darling
post Jan 5 2013, 09:53 PM
914 Idiot
Make sure you have spark. Use an extra spark plug, tape it with the outer electrode or threads touching a ground, plug it in to a plug wire. Have someone crank the starter while you look for spark at the plug.
No spark? Check the ignition system. Got spark? The problem is somewhere else.
If the green wire from the distributor isn't connected to anything, you will get a no spark condition.
--DD
Nine_14
post Jan 6 2013, 04:54 AM
Region Association: Germany
QUOTE(kg6dxn @ Jan 5 2013, 11:56 PM) *
- Lo-Fi Version Time is now: 22nd December 2024 - 12:03 AM
