4 Pages V « < 2 3 4
> Bernie Bergmann Turbo Kit, anyone seen one?
poorsche914
post May 4 2016, 07:25 PM
Post #61
T4 Supercharged
This 914 belongs to my neighbor. It is one of the original 914s built by RPM in Florida back in the... '80s (IMG:style_emoticons/default/confused24.gif)
https://www.youtube.com/watch?v=LThicZODfQU
r_towle
post May 4 2016, 07:45 PM
Post #62
Custom Member
Disney film magic..
nein14
post May 5 2016, 05:01 AM
Post #63
Can't be done
ClayPerrine
post May 5 2016, 07:11 AM
Post #64
The "You can't turbo a 914" joke started back in the late 90s on the Rennlist 914 email forum. It was in response to Jenny's brother attempting to turbo a stock D-Jet engine.
For all of you who have not been around here as long as some of us, that response is a running joke. We all know you can, but all of us want to be the first to post it in any thread about turbocharging.
Maltese Falcon
post May 5 2016, 09:32 PM
Post #65
And you can't turbocharge a vintage Speedster...unless you're the dude on the left in the sandalsAttached Image
Maltese Falcon
post May 5 2016, 09:38 PM
Post #66
924 Porsche forced induction...can't turbo that one either. MSDS kit was available a couple years ahead of the factory 931.Attached Image
Mueller
post May 6 2016, 12:19 AM
Post #67
914 Freak!
QUOTE(Porscheman @ May 4 2016, 03:42 PM) *
QUOTE(r_towle @ May 4 2016, 06:30 PM) *
It's an old and long standing joke...
The issue you will have is limited support for the setup, there might be less than 100 in the world that have done this.
And, the head to cylinder sealing is gonna leak, so you will need to keep the boost down and design a method to seal the head better when things get bad.
The 911 turbo, and others, have used basically a guitar string machined into the head and cylinder to assist in sealing them.
It's not a low cost road to go down, but there are many member here that have turbo setups that work.
Thanks for your input ..I was going to install a small Subaru ple 500 .supercharger made for small displacement engines ..as I want to run the stock fuel injection ..and set up
.rather going with a turbo ..and all the expensive efi blow though desings ..figure the supercharger is small and has a self contained oil set up ..and is cheap to build..and probsbly only pushes 4 to 6 psi anyways
I suggest you buy a book or two on the subject of supercharging.
Then I'd spend some time researching this supercharger....
http://superchargersunlimited.com/specs.html
Making the engine larger via biggest pistons and cylinders you can find (which makes you sound like a 12 year old and I doubt you really want to spend that kind of money) will require a bigger supercharger or this small supercharger to be overdriven so much so that it will just turn into a heat pump, something which is not good at all for the supercharger or the motor. You can only remove so much heat from the compressed charge.
Dave_Darling
post May 6 2016, 10:48 PM
Post #68
914 Idiot
QUOTE(ClayPerrine @ May 5 2016, 06:11 AM) *
Longer ago than that, even. The "fine" folks at "european car" magazine told someone who write in that you cannot turbo a 914. Sammy G, and Jeff Shyu (Jenny's brother) and a couple more were actually doing it at the time, and ejm's and Evill Ed's were in the works.
It developed into a running joke from there.
--DD
andrewb
post May 6 2016, 11:27 PM
Post #69
You can't wheelie a shaft drive bike either. (IMG:style_emoticons/default/biggrin.gif)
It must be true - I read it on the interweb.
McMark
post May 7 2016, 08:35 AM
Post #70
914 Freak!
QUOTE(Porscheman @ May 4 2016, 06:33 PM) *
I'm building a 2.0 motor and going to install a turbo cam ..hydrolic lifters ..and the biggest pistons and cylinders ..I can find ...I also know the skat track 9500 cam is good for fuel injection motors ...
Sounds very under-researched. Just get giant pistons, huge crank, massive cam, huge supercharger. Bigger is better, so what could go wrong? (IMG:style_emoticons/default/happy11.gif)
veekry9
post May 7 2016, 09:12 AM
Post #71
OldMember
Group: Retired Members
Bergmann
Some linkups to the impossible,as searching 'turbo' the result is too many refs to tie rods.
http://www.bergmannvw.net/
https://www.google.ca/search?q=type+1+vw+en...elFBVcQ_AUIBigB
http://www.914world.com/bbs2/index.php?sho...=276095&hl=
http://www.914world.com/bbs2/index.php?sho...=248774&hl=
http://www.914world.com/bbs2/index.php?sho...=276501&hl=
http://www.914world.com/bbs2/index.php?sho...=262635&hl=
http://www.914world.com/bbs2/index.php?sho...=276795&hl=
http://www.914world.com/bbs2/index.php?sho...=275449&hl=
http://www.914world.com/bbs2/index.php?showtopic=275794
http://www.914world.com/bbs2/index.php?sho...=274385&hl=
http://www.914world.com/bbs2/index.php?showtopic=202113
https://www.google.ca/search?q=porsche+936&...gB&dpr=1.75
https://www.google.ca/webhp?sourceid=chrome...pe%201%20engine
http://www.brothersvwmachineshop.com/parts.htm
http://www.cartechbooks.com/techtips/how-t...a-turbocharger/
http://forums.nasioc.com/forums/showthread...3446&page=4
There are likely a few more thds on the subject,across all time,I selected a few relevant.
That sparks an idea,hmm..and a question.
Other than Porsche and Bruce Crower,has anyone turboed a Flat-8?
Chris H.
post May 9 2016, 08:39 AM
Post #72
QUOTE(McMark @ May 7 2016, 09:35 AM) *
It always worked for this guy....
veekry9
post May 10 2016, 03:31 AM
Post #73
OldMember
Rainer
https://www.youtube.com/watch?v=xWK593V7ju0
ORRATECH Infofilm
Construction, commissioning and trial run of a 3.0L engine with Typ4 ORRATECH P300SF270 heads.
Bore / Stroke: 105mm x 86mm
Heads: ORRATECH P300SF270
Valves: EV52 AV42-Nimonik, titanium retainer plate, 125kg double springs,
Crankshaft: ORRATECH 86mm with small connecting rod journals, Chromo counterweighted forged,
Rods: H-shaft steel, 5.4 "long 50mm feet, 12mm bolt
Cam / follower: 86b1 "/ 54g mushroom tappet 19mm socket
Cooling: C2-fan, 75Ah-phase AC Lima
Exhaust: 48mm compartments A! or Phyton
Source: Weber 48IDF7OS, intake manifolds with premix ORRATECH
Ignition: 1-2-3 Ignition 16, HD-ignition
This Infofilm shows the basic structure of a 3.0L engine Typ4 and initial commissioning. In particular, the P300SF270 cylinder heads are shown here.
Data: flow value of the inlet 290cfm, 270cfm with 15mm stroke.
Inlet valve 52,3mm, exhaust 42mm Nimonik, 125kg double springs, titanium spring plate, double vent, flat rounded inlet trumpet, D-port outlet, etc.
It is a compilation of a 4-hour procedure, in which, inter alia, also the engine oil is changed and the valve clearance is checked.
https://www.youtube.com/channel/UCuWMICweeQ99cXuKoLrMQmw
https://www.youtube.com/watch?v=rw1FigYoozE#t=6.080083
https://www.youtube.com/results?search_quer...sche+914+type+4
I'm surprised to find he's using a Cincinnati with a Heidenhain CNC,a rare machine.
veekry9
post May 10 2016, 09:03 PM
Post #74
OldMember
http://www.mahle-aftermarket.com/na/en/cat...catalogtc-10-14
barefoot
post May 11 2016, 05:56 AM
Post #75
More turbo installations:
Never say never
4 Pages V « < 2 3 4
- Lo-Fi Version Time is now: 22nd April 2025 - 06:49 AM
