LED Taillights, Custom Made for the 914 |
a914622 |
Jan 30 2013, 05:21 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
So Volvo uses a diffuser that looks like a half a magnifying glass between the led and lens. I will try to post some pics. The red leds they use are not all that bright, but stack the assmbaly together and WOW bright brake light. Maybe a diffuser lens / red lad would give you the pop your looking for?
jcl |
Spoke |
Jan 30 2013, 10:22 PM
Jerry Group: Members Posts: 7,113 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
montoya 73 2.0 |
Jan 30 2013, 11:59 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
a914622 |
Jan 31 2013, 07:33 PM
The super flux ones look just like the volvo 3rd brake light leds. I think the little dome on the top acts like a focus or diffuser?
jcl |
montoya 73 2.0 |
Jan 31 2013, 08:00 PM
My mom worked at LumiLEDS several years ago. She gave me a few of those SuperFlux LED's and they are bright as hell! I believe they are meant for automotive use.
Spoke |
Feb 1 2013, 11:22 AM
I checked out the LumiLEDs. They look pretty good. I will get some Amber and White ones.
I found Red LEDs through digikey to be more cost efficient than through Future who carries LumiLEDs. The plan now is to put red LEDs under the red brake lens and amber under the amber turnsignal lens. I have orders some more LEDs to try out. I want to make sure that whichever LED is chosen it will be as bright or brighter than the existing bulbs. Red LED Digikey Red LED Digikey Warm White LED Digikey Cool White LED Digikey Amber LED Future Electronics Neutral White LED Future Electronics |
zymurgist |
Feb 1 2013, 02:14 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Thanks for putting this together, Spoke. I bet you will sell a lot of them... (IMG:style_emoticons/default/thumb3d.gif)
Spoke |
Feb 1 2013, 09:15 PM
The test I did with 10 LEDs putting out about 40LM each didn't achieve the brightness I am looking for although they were bright as hell.
One item that is designed into all LED lighting is proper lense and/or reflector designed for the LEDs. This is true on all factory-designed LED lights. So I've been looking into reflectors for LEDs and ran across the following thread on CandlePoweredForum discussing LED brake and tail lights. I don't know any of these guys nor do I know their backgrounds but they sound quite knowledgeable about automotive lighting and LEDs. Seems all of the "experts" on this thread indicate that the drop-in LED replacement bulbs are not very good and may even be illegal to replace filament bulbs with LED drop-in's in tail and brake light fixtures in some states. They bring up good points about brake/tail light modifications and ramifications concerning liability if one is involved in an accident. CandlePoweredForum Thread In short, this LED implementation that I am doing could be illegal since it involves modifying a safety feature on an automobile. If I sell this to someone and they have an accident or get pulled over for having illegal lights, would I be liable? Maybe I'd have to state "for off-road applications only". Here's another thread on LED automotive lighting and lenses. Photonics Thread |
charliew |
Feb 1 2013, 09:33 PM
Many years ago I modified a 69 mustang rear tail light lens and found out it needed so much reflector lens to pass tx inspection. I bet if you make a light setup and it's brighter than the original lights it will be good. I would not worry about it on my car but you how lawyers are. Off road only is also ok for me.
I tried those led replacement bulbs in a 86 blazer and they were brighter but didn't last very long for some reason. |
Spoke |
Feb 1 2013, 10:22 PM
For those thinking about changing to LED bulb replacements, research carefully. This guy tried them on his bike and didn't like the results.
Superbright LED vs Standard 1157 Filament Bulb |
Cairo94507 |
Feb 1 2013, 10:50 PM
Michael Group: Members Posts: 10,165 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I would be perfectly happy for my tail light kit to come with a big sticker on the box that said "FOR OFF ROAD USE ONLY". I just really want this project to be a part of my build.
euro911 |
Feb 1 2013, 11:04 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
When I was involved with a colleague manufacturing custom cycle chassis, suspensions systems and other components, they were sold with a disclaimer stating "for show use only". Liability insurance quotes were astronomical (IMG:style_emoticons/default/screwy.gif)
Lighting systems must meet DOT requirements, but there are numerous aftermarket lighting components on the market, as we all see on the road every day. I'm curious if they have a disclaimer included in their instructions (IMG:style_emoticons/default/confused24.gif) |
Harpo |
Feb 2 2013, 08:21 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Yea, I'm OK with "for off road use only". Anything to keep this project moving forward.
Thanks for running with this. DAvid |
monkeyboy |
Feb 4 2013, 10:55 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Obviously I would only be using these on my track car. (IMG:style_emoticons/default/smile.gif)
Chris H. |
Feb 5 2013, 11:05 AM
Senior Member Group: Members Posts: 4,053 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
OK stupid question... how about finding a newer car with an existing LED setup that has a pattern similar to what we need? Could that be used as a starting point and modify/add from there? Too expensive? Maybe an American car that has plenty in the bone yards? I'm a complete novice on this....just popped in my head.
Bartlett 914 |
Feb 5 2013, 05:04 PM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I like this project and I hope you are able to follow through with it.
I think I would try and locate a light meter. This judging by comparison is not the best idea. Photographers use meters to get the best results. It shouldn't be too difficult to locate a reasonably priced meter. |
Spoke |
Feb 6 2013, 11:57 AM
OK stupid question... how about finding a newer car with an existing LED setup that has a pattern similar to what we need? Could that be used as a starting point and modify/add from there? Too expensive? Maybe an American car that has plenty in the bone yards? I'm a complete novice on this....just popped in my head. The issue finding a late model car with working LED tail lights is that the tail lights would command a good bit of coin as replacement parts. I got more LED samples and mounted them on my test board. I have more powerful white LEDs as well as several red and amber LEDs for brake and turn signals. I will be checking these out over the weekend. Attached thumbnail(s) |
gothspeed |
Feb 6 2013, 12:30 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Awesome!!! I hope this project comes through, so I can just buy them, instead of making my own (IMG:style_emoticons/default/beerchug.gif)
Chris H. |
Feb 6 2013, 02:12 PM
OK stupid question... how about finding a newer car with an existing LED setup that has a pattern similar to what we need? Could that be used as a starting point and modify/add from there? Too expensive? Maybe an American car that has plenty in the bone yards? I'm a complete novice on this....just popped in my head. The issue finding a late model car with working LED tail lights is that the tail lights would command a good bit of coin as replacement parts. Ah, got it...see I knew it was a dumb question! (IMG:style_emoticons/default/biggrin.gif) Glad you started this thread before I bought LED bulbs...was just about to pull the trigger. I'm in for sure on these. |
Spoke |
Feb 8 2013, 10:32 AM
The more I see LEDs on vehicles the more I'm convinced I will need some type of reflector to channel the light. Here's one I found online that looks like it would work.
Wholesale LED Reflector |
Lo-Fi Version | Time is now: 12th January 2025 - 02:06 AM |
