CV bolt, lock washers |
Elliot Cannon |
Jan 28 2013, 08:05 PM
I sent to Pellican for CV bolt lock washers. I think I could have found these at the local hardware store. Are the others not available anymore. Should I trust these?
rick 918-S |
Jan 28 2013, 08:13 PM
Hey nice rack! -Celette Group: Members Posts: 20,835 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Actually, I found schnorr washers at my local Ace hardware store. I would not use those washers they sent but that's just me.
Elliot Cannon |
Jan 28 2013, 08:15 PM
There is an Ace hardware in town. I'll check there tomorrow. Thanks.
ChrisFoley |
Jan 28 2013, 08:21 PM
I am Tangerine Racing Group: Members Posts: 7,969 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Bad on Pelican.
I buy Schnorr washers a hundred at a time. |
bigkensteele |
Jan 28 2013, 08:25 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Mr. Shea has them as well.
dlestep |
Jan 28 2013, 08:30 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
serrated, black oxide spring washer (Schnorr)
Elliot Cannon |
Jan 28 2013, 08:34 PM
serrated, black oxide spring washer (Schnorr) That's what I thought I was getting. Looks like I'll be sending them back. (IMG:style_emoticons/default/happy11.gif) |
LotusJoe |
Jan 29 2013, 04:48 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.schnorr.com-11085-1359499734.1.jpg)
I would use the proper washer. |
toadman |
Jan 29 2013, 04:53 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
I got mine from Brad Mayeur at 914 LTD.
GeorgeRud |
Jan 29 2013, 06:33 PM
If no luck locally, McMaster Carr is your friend.
McMark |
Jan 29 2013, 07:07 PM
PM me your address. I'll send some out tomorrow.
rhodyguy |
Jan 30 2013, 09:23 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
elliot, i have a washer bag that came from mcmaster (iirc) for the washers.
100 pack #93501A030 hardened steel serrated BELLEVILLE washers 5/16" screw sz, .331"id, .512"od, .0280" min thk. k |
A&PGirl |
Jan 30 2013, 10:14 AM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
Belleville and Schnorr are actually (2) different washers.
The Schnorr Safety Washer S (registered) is the correct washer to use. They come black, yellow, clear zinc and stainless steel. M8 is 1000/box. I've contacted Schnorr before and gotten a quote from them. I am willing buy the washers from Schnorr as business in your choice to get the best pricing. |
rhodyguy |
Jan 30 2013, 10:18 AM
whats the dif between the belleville and the schnorr carrie? metric vs sae? they seem to fit the same and have the 'cupping'.
Phoenix-MN |
Jan 30 2013, 10:28 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
From the Schnorr handbook
The benefi ts of SCHNORRĀ® Disc Springs also known as Belleville Springs result in design engineers continually increasing preference for them: 1. Load/defl ection curve of straight, progressive or regressive character, according to the design requirements. 2. Alteration of spring performance as desired by the addition or removal of single discs. 3. Space saving. 4. Largely self-damping, particularly with parallel stacking, giving good shock absorption and energy dissipation. 5. No deformation or fatigue under normal loads. 6. Long service life. 7. The large range of possible applications for individual spring sizes simplifi es stock-keeping. |
jeffdon |
Jan 30 2013, 10:36 AM
I sent to Pellican for CV bolt lock washers. I think I could have found these at the local hardware store. Are the others not available anymore. Should I trust these? Same thing happened to me. Been debating using them. I also safety wire mine, so I would think its ok. |
rhodyguy |
Jan 30 2013, 11:08 AM
so...pelican lists them as superseded to 999 523 102 OB OEM @ a buck a pop or 100 of them for $.1025 each from mcmaster. (IMG:style_emoticons/default/dry.gif) interesting...pelican lists 8 required per car. that should read per 8 axle or 16 per car. get on that dave. (IMG:style_emoticons/default/biggrin.gif)
k |
Elliot Cannon |
Jan 30 2013, 05:05 PM
I sent to Pellican for CV bolt lock washers. I think I could have found these at the local hardware store. Are the others not available anymore. Should I trust these? Same thing happened to me. Been debating using them. I also safety wire mine, so I would think its ok. I safety wire mine as well but I will NOT be using these washers. I've got some on the way. Thanks Mark. |
McMark |
Jan 30 2013, 05:21 PM
McMaster washers come in a bag labelled SCHNORR in big letters. I'm content. (IMG:style_emoticons/default/cool_shades.gif)
913B |
Jan 30 2013, 05:38 PM
Senior Member Group: Members Posts: 855 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Since we are talking about these little washers. Is there a correct way they should face or it doesn't matter. Know what I mean ?? :-)
Lo-Fi Version | Time is now: 2nd January 2025 - 08:46 PM |
