CV bolt, lock washers |
euro911 |
Jan 30 2013, 05:43 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I bought a big bag from Eric ... (IMG:style_emoticons/default/smoke.gif)
Did you get yellow ones? ... they install faster (IMG:style_emoticons/default/poke.gif) |
0396 |
Jan 30 2013, 05:59 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
McMark |
Jan 30 2013, 06:48 PM
Since we are talking about these little washers. Is there a correct way they should face or it doesn't matter. Know what I mean ?? :-) Absolutely! (IMG:style_emoticons/default/biggrin.gif) The ID should be towards the bolt head. I guess a picture is better... Attached image(s) |
913B |
Jan 30 2013, 07:26 PM
Senior Member Group: Members Posts: 855 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Thank you sir !
Mike Bellis |
Jan 30 2013, 10:01 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
(IMG:style_emoticons/default/hijacked.gif)
What ever happened to the group buy for drilled CV bolts? (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
Jan 31 2013, 12:29 AM
(IMG:style_emoticons/default/hijacked.gif) What ever happened to the group buy for drilled CV bolts? (IMG:style_emoticons/default/confused24.gif) I drilled mine myself. A few minutes with a drill press. Countersink the holes to get rid of sharp edges. Check the picture in my first post. Not hard to do. |
Elliot Cannon |
Jan 31 2013, 12:31 AM
Since we are talking about these little washers. Is there a correct way they should face or it doesn't matter. Know what I mean ?? :-) Absolutely! (IMG:style_emoticons/default/biggrin.gif) The ID should be towards the bolt head. I guess a picture is better... The washers I have always used have a serrated surface on BOTH sides of the washer arranged at an angle. This one looks a little different. (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
Jan 31 2013, 02:15 AM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
(IMG:style_emoticons/default/hijacked.gif) What ever happened to the group buy for drilled CV bolts? (IMG:style_emoticons/default/confused24.gif) I did a GB, sent out a few for those that wanted them. still have them. -Mark |
McMark |
Jan 31 2013, 10:14 AM
The washers are serrated on both sides. It just doesn't look like it in the pic.
02loftsmoor |
Jan 31 2013, 10:20 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
Boy I'm glad someone spoke out, those kinds of washers will flatten out and you will loose your torque, wired or not.
Elliot Cannon |
Jan 31 2013, 12:41 PM
The washers are serrated on both sides. It just doesn't look like it in the pic. Thanks Mark. I'm easily confused. (IMG:style_emoticons/default/biggrin.gif) |
d7n7master |
Jan 31 2013, 01:01 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
JFJ914 |
Jan 31 2013, 02:54 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Mike Bellis |
Jan 31 2013, 06:21 PM
(IMG:style_emoticons/default/hijacked.gif) What ever happened to the group buy for drilled CV bolts? (IMG:style_emoticons/default/confused24.gif) I did a GB, sent out a few for those that wanted them. still have them. -Mark PM sent |
hotlanta914 |
Jan 31 2013, 06:36 PM
Newbie Group: Members Posts: 21 Joined: 15-July 06 From: Atlanta, GA Member No.: 6,438 |
how about these
Attached thumbnail(s) |
Elliot Cannon |
Jan 31 2013, 08:10 PM
Wow! I wonder where we can get those?
montoya 73 2.0 |
Jan 31 2013, 08:14 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Schnorr washers are stock and good enough, Safety wire is redundant but cheap insurance.
Elliot Cannon |
Jan 31 2013, 08:17 PM
Might be a good thing on a race car. Looks like a special socket and clip ring pliers required.
montoya 73 2.0 |
Jan 31 2013, 08:21 PM
Ah, good idea for quick release on the triple square. Maybe a machined slot in the head of the fastener to slide the clip on.
Lo-Fi Version | Time is now: 5th January 2025 - 01:03 AM |
