Aluminum Taco Plate and Tuna Can Group Buy, CLOSED |
Porschef |
Nov 8 2014, 07:32 AM
How you doin' Group: Members Posts: 2,177 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
You'll need both if you wanna make tuna tacos... (IMG:style_emoticons/default/blink.gif)
Ok with that out of the way, the can provides a reservoir for some more oil. It bolts up inder the engine, where the screen is now. I have one and haven't installed it yet cause I'm not sure how to mount the pickup. I guess I should find out. The plate, I believe, is an updated version of what was available to carry a sender for the oil temp. Also bolts up under the engine. Next time you're under the car, you'll see the cover plates on the sump. Hth |
tumamilhem |
Nov 9 2014, 01:34 AM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
What's the benefit of having a reservoir for more oil?
euro911 |
Nov 9 2014, 01:26 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,858 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
jim_hoyland |
Nov 9 2014, 01:32 PM
Get that VIN ? Group: Members Posts: 9,512 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What's the benefit of having a reservoir for more oil? So you have a constant supply of oil at the pick up point ... especially during hard cornering when G-forces push the oil in your case over to one side or the other.(IMG:style_emoticons/default/agree.gif) I'be noticed this driving twisty roads, the Green Oil Light flashes as the G-Forces build; for daily driving in traffic, probably no advantage. The new Tuna Can is well made and look good; haven't had an oil leak. |
DRPHIL914 |
Nov 10 2014, 09:30 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Does this new tuna can work with a screen? The screen I ordered does no look like it will fit with this.
also I hve the gasket kit do I apply any additional sealant? Planning on putting this in tomorrow. |
DRPHIL914 |
jim_hoyland |
Nov 10 2014, 09:34 PM
I used the screen; had to enlarge the hole a small amount
DRPHIL914 |
Nov 10 2014, 09:51 PM
O.k so heres a picture of all the parts.
#1. Do iuse a gasket between the oil screenand the tuna can, and between the other side of the screen and the new bottom plate? ? What about between the tuna can and the oil pan?(car) #2. Seems to me the copper gasket supplied would not stop leak at the center screw. Should some type of gasket sealant be applied there as well? Attached thumbnail(s) |
euro911 |
Nov 11 2014, 12:46 AM
I was under the impression that 3 paper ring gaskets are needed: 1 between the case and the 'can', 1 above and 1 below the strainer flange.
My stock strainer 'bolt' always leaked, so I used red RTV on it - hasn't leaked since. |
jim_hoyland |
Nov 11 2014, 06:11 PM
Here's the pic of the recommended sender. Fits the billet Taco Plate perfect... (IMG:style_emoticons/default/smile.gif)
Bought from JEGS; $18 and free shipping Attached image(s) |
DRPHIL914 |
Nov 11 2014, 06:26 PM
I was under the impression that 3 paper ring gaskets are needed: 1 between the case and the 'can', 1 above and 1 below the strainer flange. My stock strainer 'bolt' always leaked, so I used red RTV on it - hasn't leaked since. Thought so. I have 3 sets so I will be using 3. I did not install it yet as I just ordered my sensor and will be doing what jim is doing with the new taco plate and sensor install. Thought id do them both at the same time. Just needto figure out what to use as a gasket on the taco plate install . |
jim_hoyland |
Nov 11 2014, 06:28 PM
Use the original orange rubber seal ?
DRPHIL914 |
Nov 11 2014, 06:34 PM
Duplicate thanks to my tablet
euro911 |
Nov 12 2014, 02:05 AM
Here's the pic of the recommended sender. Fits the billet Taco Plate perfect... (IMG:style_emoticons/default/smile.gif) Let me know how it goes, Jim. I ordered 2 of them from JEGS the other day too ... one for KaptKaos and one for the 'BB' (IMG:style_emoticons/default/smile.gif) Bought from JEGS; $18 and free shipping |
housepumpinpc |
Nov 23 2014, 02:03 AM
Give me time... I'll fix it eventually. Group: Members Posts: 31 Joined: 9-May 14 From: Chicago,Illinois Member No.: 17,323 Region Association: Upper MidWest |
I just got Neil's tuna can and taco plate. Will b installing soon(got black since there isn't red). The quality is excellent. Got to tell you though, never ever order without tracking because it took over a month to get to me. Wish I got in that group buy myself.
DRPHIL914 |
Nov 23 2014, 07:28 AM
I was going to install this yesterday but the sender I ordered from jegs over a week ago has not come! I need to follow up on that with them.
euro911 |
Nov 23 2014, 04:42 PM
I ordered two from JEGs and they got here really fast ... faster than I move, but the Odyssey battery took longer than expected (IMG:style_emoticons/default/confused24.gif)
Kansas 914 |
Nov 24 2014, 09:02 AM
I was going to install this yesterday but the sender I ordered from jegs over a week ago has not come! I need to follow up on that with them. Looks like the sensor is on back order at JEGS. I ordered mine on 11/11/14. We must have caused a run on that part. The website states if you order today the part will ship on 12/01/14. |
DRPHIL914 |
Nov 24 2014, 09:27 AM
I was going to install this yesterday but the sender I ordered from jegs over a week ago has not come! I need to follow up on that with them. Looks like the sensor is on back order at JEGS. I ordered mine on 11/11/14. We must have caused a run on that part. The website states if you order today the part will ship on 12/01/14. called them yesterday, mine is scheduled to ship today, supposedly their back ordered and new supply was to come into the warehouse over the weekend. maybe yours will ship out today as well. - they must not keep many on hand/in stock. |
Kansas 914 |
Nov 24 2014, 09:32 AM
called them yesterday, mine is scheduled to ship today, supposedly their back ordered and new supply was to come into the warehouse over the weekend. maybe yours will ship out today as well. - they must not keep many on hand/in stock. Thanks for the update Phil - we probably bought a year's supply in one month...... |
Lo-Fi Version | Time is now: 22nd November 2024 - 07:13 PM |
