Carlitos Way |
I did it MY WAY ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California ![]() |
I just noticed a pretty nasty leak in my engine compartment. The hoses don't seem to be all there, some are cracked, and there's at least one leaking. I'd like to replace them all.
Does anyone know what size/type/kind to get? Please advise Carlos |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
7mm from the article by Dark Dave - approximately 5/16" if you're Americanized - high pressure fuel line only.
Carlitos Way |
Thanks!!!
what about the smog/air lines? |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
While you can buy 8mm (5/16) fuel hose, 7.5mm is correct and fits much more securely. Be sure you get real FI hose good to at least 60 psi. Good hose may seem expensive, but it's cheaper than repairing fire damage ............... Vacuum line is 3.2mm and 4.5mm (vac retard line). There is also some 12mm hose in the evap and AAR systems (as well as in the cyl head breathers and PCV if your car has them) and 9mm in the decel valve circuit, if so equipped. HTH, The Cap'n
Lo-Fi Version | Time is now: 25th June 2024 - 06:19 PM |
