Introducing myself, introduction |
Gint |
Feb 14 2013, 07:44 PM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/welcome.png) How about some pics?
SouthCali914 |
Feb 14 2013, 07:53 PM
Newbie Group: Members Posts: 25 Joined: 1-January 13 From: North San Diego county Member No.: 15,320 Region Association: None |
Ask & ye shall recive. Attached thumbnail(s) |
SouthCali914 |
Feb 14 2013, 07:54 PM
SouthCali914 |
Feb 14 2013, 07:55 PM
SouthCali914 |
Feb 14 2013, 07:58 PM
SouthCali914 |
Feb 14 2013, 07:59 PM
Fire wall rust
SouthCali914 |
Feb 14 2013, 08:01 PM
hell hole
SouthCali914 |
Feb 14 2013, 08:03 PM
good thing I was taking pics for you guys, found the aux fan tube off & trying to get sucked into the fan.
SouthCali914 |
Feb 14 2013, 08:05 PM
The int. actualy looks a lot better in person than the pics & the wheels are the result of about twelve hours of refinishing. My buddies where ranking me quite bad over them before.
bigkensteele |
Feb 14 2013, 08:51 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
(IMG:style_emoticons/default/welcome.png) You will find yourself here a lot.
oz371 |
Feb 15 2013, 05:03 AM
Member Group: Members Posts: 101 Joined: 28-August 09 From: ontario, CA Member No.: 10,739 Region Association: None |
76-914 |
Feb 15 2013, 08:34 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Looks good. The only time rust "isn't very bad" is when it's on someone else car. (IMG:style_emoticons/default/dry.gif) That rusted out area behind the drivers seat is usually worse on the right side. Check it out. (IMG:style_emoticons/default/welcome.png)
KELTY360 |
Feb 15 2013, 08:44 AM
914 Neferati Group: Members Posts: 5,096 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
That's a great car for all the twisty roads you've got out there. Enjoy!
(IMG:style_emoticons/default/welcome.png) |
Kaduku |
Mar 3 2013, 11:30 PM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
Welcome! I am new too with a newly acquired 73.
Black22 |
Mar 3 2013, 11:55 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/welcome.png) Now quit farting around and break out the jackstands! (IMG:style_emoticons/default/lol-2.gif)
DEC |
Mar 4 2013, 03:21 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
SouthCali914 |
Mar 4 2013, 10:07 PM
(IMG:style_emoticons/default/welcome.png) Now quit farting around and break out the jackstands! (IMG:style_emoticons/default/lol-2.gif) I must first get my Galant vr4 out of Jsb status. Then trust me, she won't see the road again for at least a year. (IMG:style_emoticons/default/smash.gif) |
Nie Zu Alt |
Mar 4 2013, 10:20 PM
Member Group: Members Posts: 173 Joined: 1-June 05 From: Centennial, CO Member No.: 4,184 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/welcome.png) Greetings from Colorado! You'll find this site full of great 914 info.
Gint |
Mar 20 2013, 07:00 PM
Hey, in another thread you wrote:
Ok, got mine figured out & fixed. The starter solenoid just wants more amps than are making from the bat to the ignition & back to the starter. I had removed & cleaned all my grounds, all of them! Hiding all over the damn place (IMG:style_emoticons/default/headbang.gif) Checked for voltage drop to the ignition switch & back at the solenoid. The solenoid from time to time wants more amps than that circuit will give it for size & length. So I added a relay. Put it right next to the starter. About six inches of heavy gauge wire from the main starter bat+ lug & again back to the solenoid. ran the ground to the solenoid mounting screw & energize it with the original solenoid wire. It has cranked over much better at all times now & happy to report Zero no-crank issues. Took far longer to diag than to repair. To sum up. if you have a random no-crank pull the solenoid wire & see if it will light up a good test light. if it will then add a relay & call it fixed. If not you have my sympathy, it's not a fun circuit to trace. Upside I learned how to rebuild my underhood relay block. now my voltage always stays above 12. (IMG:style_emoticons/default/beerchug.gif) Exactly how did you wire that relay/solenoid/starter? Sounds different than the way mine is setup. I'll send you a PM. |
PanelBilly |
Mar 20 2013, 09:20 PM
914 Guru Group: Members Posts: 5,864 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I don't think I said hello yet,,,,,
Lo-Fi Version | Time is now: 27th December 2024 - 07:47 AM |
