Shift Bushing kit, I don't know what I don't know! |
malcolm2 |
Feb 19 2013, 11:54 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I am pretty sure that I need any and all bushing used in a side shift 75, 1.8L, L-jet. However, neither AA nor PP have a package that comes out and says THESE ARE ALL of the bushings. I see 3 bushing kits, 5 bushing kits, 7 bushing kits, single bushings. Emailed AA and got no reply. The guy at AA's ebay site did reply (still no help). He directed me to buy their tech notes book, which I have. And BTW it has no complete bushing list either. (IMG:style_emoticons/default/stirthepot.gif)
Common sense may tell me to buy the largest kit, but I need details. Does anyone have a layout, pictures, a website link, anything that will definitively tell me what I need and where they go, what they are named. You see, my car is completely dismantled, so I can't just look at the old ones. I can, of course, see where a bushing might go, but I don't know the names of those locations. I am not from Missouri, but I do need someone to SHOW-ME. (IMG:style_emoticons/default/confused24.gif) Thanks, Clark |
flash914 |
Feb 19 2013, 12:06 PM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
PEL-SKS914-02N Pelican parts super kit for stock side shift. This will have all the bushings you need. Firewall or through body (1) Cage or coupler (2) Rear shift rod bushing (1) Rear ball cup (1) Gordon
john_g |
Feb 19 2013, 12:11 PM
Member Group: Members Posts: 110 Joined: 1-November 12 From: british columbia Member No.: 15,100 Region Association: Canada |
I am pretty sure that I need any and all bushing used in a side shift 75, 1.8L, L-jet. However, neither AA nor PP have a package that comes out and says THESE ARE ALL of the bushings. I see 3 bushing kits, 5 bushing kits, 7 bushing kits, single bushings. Emailed AA and got no reply. The guy at AA's ebay site did reply (still no help). He directed me to buy their tech notes book, which I have. And BTW it has no complete bushing list either. (IMG:style_emoticons/default/stirthepot.gif) Common sense may tell me to buy the largest kit, but I need details. Does anyone have a layout, pictures, a website link, anything that will definitively tell me what I need and where they go, what they are named. You see, my car is completely dismantled, so I can't just look at the old ones. I can, of course, see where a bushing might go, but I don't know the names of those locations. I am not from Missouri, but I do need someone to SHOW-ME. (IMG:style_emoticons/default/confused24.gif) Thanks, Clark Here's a Pelican how-to article on replacing the three main bushings in the linkage: http://www.pelicanparts.com/techarticles/9...ift_improve.htm And here's the parts page from Pelican for the bushing kit: http://www.pelicanparts.com/catalog/shopca...t_pg1.htm#item0 You want the bushing kit for the 73-76 cars - five bushings and two set screws. |
malcolm2 |
Feb 19 2013, 12:24 PM
PEL-SKS914-02N Pelican parts super kit for stock side shift. This will have all the bushings you need. Firewall or through body (1) Cage or coupler (2) Rear shift rod bushing (1) Rear ball cup (1) Gordon Thanks. I don't remember seeing that kit. I dug deeper and there are good descriptions of each. Just what the Dr. ordered. Clark |
scott_in_nh |
Feb 19 2013, 12:28 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
Here's a Pelican how-to article on replacing the three main bushings in the linkage: http://www.pelicanparts.com/techarticles/9...ift_improve.htm And here's the parts page from Pelican for the bushing kit: http://www.pelicanparts.com/catalog/shopca...t_pg1.htm#item0 You want the bushing kit for the 73-76 cars - five bushings and two set screws. I would suggest changing the rear trans mounts too. Pelican has the 911 sport engine mounts that work as a trans mount for the 914. I noticed mine had quite a bit of deflection in them even though they weren't torn. That deflection = binding. I did this after replacing all of the shift bushings and felt there was another incremental improvement in shifting. |
hot_shoe914 |
Feb 19 2013, 08:42 PM
on ramp passer Group: Members Posts: 3,806 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
I just had a bushing kit arrive in the mail today. Contact Johnathan at GPR. He will hook you up with what you need. I got the firewall, tranny, shifter, coupler the whole works. Hope to get them installed before the ax this weekend.
euro911 |
Feb 20 2013, 01:24 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
If you can afford it, go with a poly-bronze bushing in the shift console on the trans and the pair on the rear shift rod coupler aft of the firewall ...they'll last a lot longer (IMG:style_emoticons/default/idea.gif)
cary |
Feb 20 2013, 06:58 AM
Ditto on the poly-bronze if its in your budget.
I also installed Chris's firewall bushing/bearing. It make a tremendous difference. Honestly I've never changed the bushing at the base of the shifter. I think I have 3 or 4 them in one of my parts drawers. Might have to give that a shot. |
maf914 |
Feb 21 2013, 01:30 PM
Ditto on the poly-bronze if its in your budget. Could someone explain what the poly-bronze option is? I am aware of the typical poly/plastic shift linkage bushings which are available, and the bronze console bushing (which I have), but I am not aware of poly-bronze shift linkage bushings. |
euro911 |
Feb 22 2013, 12:59 AM
Poly bronze shifter bushings are oil impregnated and machined to much closer tolerances than the OEM or aftermarket plastic bushings. They last longer and provide more accurate shifting. Every little bit helps. I also have them in the coupling at the front of the rear shift rod.
If you have a bronze console bushing, it's more than likely poly bronze. |
ThePaintedMan |
Feb 22 2013, 10:33 AM
Poly bronze shifter bushings are oil impregnated and machined to much closer tolerances than the OEM or aftermarket plastic bushings. They last longer and provide more accurate shifting. Every little bit helps. I also have them in the coupling at the front of the rear shift rod. If you have a bronze console bushing, it's more than likely poly bronze. Hey Mark, Does anyone make one other than Patrick Motorsports? Can you recommend a supplier? |
Eric_Shea |
Feb 22 2013, 10:42 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
"Poly" bronze is a proprietary Elephant racing bushing with a layer of polyurethane wrapped around it to take up the slack on inconsistent suspension components. (IMG:style_emoticons/default/biggrin.gif)
Oil impregnated bronze or standard bronze is the more common bushing for this application. Cleaning up your shift linkage (in terms of bushings and slop) is the single best thing to do to improve shifting quality. |
maf914 |
Feb 22 2013, 11:59 AM
"Poly" bronze is a proprietary Elephant racing bushing with a layer of polyurethane wrapped around it to take up the slack on inconsistent suspension components. (IMG:style_emoticons/default/biggrin.gif) Oil impregnated bronze or standard bronze is the more common bushing for this application. Thanks, Eric. That is what I was thinking when the term poly-bronze was used. |
euro911 |
Feb 22 2013, 12:02 PM
Poly bronze shifter bushings are oil impregnated and machined to much closer tolerances than the OEM or aftermarket plastic bushings. They last longer and provide more accurate shifting. Every little bit helps. I also have them in the coupling at the front of the rear shift rod. Hey Mark,If you have a bronze console bushing, it's more than likely poly bronze. Does anyone make one other than Patrick Motorsports? Can you recommend a supplier? Pelican sells brass coupling bushing replacements (PEL-BUSH-BR) Click here ... I don't see the shift console bushings listed in the catalog Thanks for setting us straight on the 'Poly', Eric (EDIT: Someone beat me to it) |
Lo-Fi Version | Time is now: 26th December 2024 - 08:23 PM |
