trailing arm stiffening kit |
scotty b |
Mar 7 2013, 08:55 AM
Is it REALLY necessary ? I've done a couple of these but have yet to understand why. I have NEVER seen a trailing arm bent from anything otther than a hard collision. I see no way they could be twisting or flexing in any way in hard cornering. I'm curious if any of the hardcore racers have seen a true need for them. Anyone ever seen a ARM crack from use not rust ? Sure the consoles crack, the body cracks but the trailing arm ? Seems like unneccesary weight to me (IMG:style_emoticons/default/confused24.gif)
Talk amongst yourselves I'll check back in later (IMG:style_emoticons/default/popcorn[1].gif) |
brant |
Mar 7 2013, 09:01 AM
914 Wizard Group: Members Posts: 11,831 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I think a lot of the Noticeable flex that was attributed over the years was probably mistakenly attributed to the swing arm when it was actually the chassis and swing arm mount that was flexing....
however they do still flex a truly skilled builder and racer who is 10 faster in his 914 than I ever will be, insists that he can tell the difference on a car with or without trailing arm reinforcement. he has built 20-30 914 race cars and always installs both the mount brace bars on the chassis and also the swing arm reinforcements. Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. The thread is one of the best threads that has ever been on this site. It shows that there is flex and that sticky race tires could produce that flex. So in summary.... a little flex although the chassis mount brace kits are equally responsible for a little racing flex. brant |
mrbubblehead |
Mar 7 2013, 09:20 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i wonder it is better to have the trailing arm be the weak link. they are replaceable. instead of transferring the load to the chassis. my opinion is that if the trailing arms are going to be reinforced than the pickup points must be reinforced also.
ThePaintedMan |
Mar 7 2013, 09:23 AM
Yep, Chris' thread testing the arm is pretty damn extensive. And I think this is why he sells both the trailing arm stiffening as well as the mount stiffening itself.
brant |
Mar 7 2013, 09:27 AM
i wonder it is better to have the trailing arm be the weak link. they are replaceable. instead of transferring the load to the chassis. my opinion is that if the trailing arms are going to be reinforced than the pickup points must be reinforced also. I think when racing its better to have neither be flexible... the same reason race cars are built to be as stiff as possible and use roll cages to develop a stiffer chassis.... to allow the suspension to work better on the street, if your building for failure zones with the knowledge that eventually you will hit a curb and you want a failure point then developing a failure point because you know as a manufacturer that some of the drivers are bad drivers, then it kinda makes sense...? in the same way that modern cars have crumple zones? but no flex is better for racing period! |
ChrisFoley |
Mar 7 2013, 09:35 AM
I am Tangerine Racing Group: Members Posts: 7,974 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. I designed the trailing arm stiffening procedure I now use during those tests. The metal we add weighs far less than the boxed reinforcing kits, and doesn't over-strengthen the arm. I think that welding the box reinforcements warps the trailing arms, adding toe-out. Previously I had determined that the chassis around the suspension mounts and the outer console bracket both twist in hard cornering. There are documented failures of trailing arms cracking where the box meets the pivot tube. Gusseting there provides a significant benefit. |
ConeDodger |
Mar 7 2013, 09:54 AM
Apex killer! Group: Members Posts: 23,870 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. I designed the trailing arm stiffening procedure I now use during those tests. The metal we add weighs far less than the boxed reinforcing kits, and doesn't over-strengthen the arm. I think that welding the box reinforcements warps the trailing arms, adding toe-out. Previously I had determined that the chassis around the suspension mounts and the outer console bracket both twist in hard cornering. There are documented failures of trailing arms cracking where the box meets the pivot tube. Gusseting there provides a significant benefit. I don't understand Chris. Why are you bad-mouthing the box reinforcements. (IMG:style_emoticons/default/blink.gif) You seem to take every opportunity to put them down. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
slothness |
Mar 7 2013, 10:00 AM
It's business time Group: Members Posts: 110 Joined: 7-October 04 From: Valencia, CA Member No.: 2,906 Region Association: Southern California |
Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. I designed the trailing arm stiffening procedure I now use during those tests. The metal we add weighs far less than the boxed reinforcing kits, and doesn't over-strengthen the arm. I think that welding the box reinforcements warps the trailing arms, adding toe-out. Previously I had determined that the chassis around the suspension mounts and the outer console bracket both twist in hard cornering. There are documented failures of trailing arms cracking where the box meets the pivot tube. Gusseting there provides a significant benefit. I don't understand Chris. Why are you bad-mouthing the box reinforcements. (IMG:style_emoticons/default/blink.gif) You seem to take every opportunity to put them down. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
ChrisFoley |
Mar 7 2013, 10:05 AM
I just don't learn.
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/lol-2.gif) |
Eric_Shea |
Mar 7 2013, 11:14 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We do a very simple and easy mod for our customers that almost anyone can do.
I was told it added nearly 50% in stiffness and the bonus is, there's no weight penalty. I like it because it's inexpensive, simple, it works and it's fairly noninvasive. Get a long bit and drill two holes straight through the arms. Then get a Step Bit and drill those holes out to 1" like so: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1362676444.1.jpg) Weld in two 1" tubes to add lateral stiffness: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1362676445.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1362676445.3.jpg) Paint or powder coat the arms: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1362676445.4.jpg) We also add gussets to the shaft tube: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1362676446.5.jpg) I also added the bulkhead to inner mount bars on my car. Not sure of the overall effectiveness for a street car but, the car feels like it's on rails. (IMG:style_emoticons/default/wink.gif) |
MDG |
Mar 7 2013, 11:27 AM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Nice, Eric. I like this - thanks for sharing. (IMG:style_emoticons/default/thumb3d.gif)
balljoint |
Mar 7 2013, 01:11 PM
I made the mistake of putting those old school clunky stiffeners on my first 914. I hated them. Way too heavy and a ridiculous thing for a regular street car.
I have some pics of the popsicle stick and hot glue gun treatment that I did on my sunflower yellow car, Mr. Sunflower. I'll see if I can post them later. (IMG:style_emoticons/default/mellow.gif) |
76-914 |
Mar 7 2013, 01:33 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,653 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
QUOTE Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. The thread is one of the best threads that has ever been on this site. It shows that there is flex and that sticky race tires could produce that flex. So in summary.... a little flex although the chassis mount brace kits are equally responsible for a little racing flex. brant I glad you mentioned this. Before my time so I looked it up. Good reading. http://www.914world.com/bbs2/index.php?showtopic=42873 |
Socalandy |
Mar 7 2013, 02:26 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
I went with Eric's solution and it was easy to do (IMG:style_emoticons/default/welder.gif)
Woody |
Mar 7 2013, 04:19 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. I designed the trailing arm stiffening procedure I now use during those tests. The metal we add weighs far less than the boxed reinforcing kits, and doesn't over-strengthen the arm. I think that welding the box reinforcements warps the trailing arms, adding toe-out. Previously I had determined that the chassis around the suspension mounts and the outer console bracket both twist in hard cornering. There are documented failures of trailing arms cracking where the box meets the pivot tube. Gusseting there provides a significant benefit. I don't understand Chris. Why are you bad-mouthing the box reinforcements. (IMG:style_emoticons/default/blink.gif) You seem to take every opportunity to put them down. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Well played. (IMG:style_emoticons/default/lol-2.gif) |
ConeDodger |
Mar 8 2013, 12:16 AM
Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. I designed the trailing arm stiffening procedure I now use during those tests. The metal we add weighs far less than the boxed reinforcing kits, and doesn't over-strengthen the arm. I think that welding the box reinforcements warps the trailing arms, adding toe-out. Previously I had determined that the chassis around the suspension mounts and the outer console bracket both twist in hard cornering. There are documented failures of trailing arms cracking where the box meets the pivot tube. Gusseting there provides a significant benefit. I don't understand Chris. Why are you bad-mouthing the box reinforcements. (IMG:style_emoticons/default/blink.gif) You seem to take every opportunity to put them down. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Well played. (IMG:style_emoticons/default/lol-2.gif) Thanks Woodster! (IMG:style_emoticons/default/biggrin.gif) |
euro911 |
Mar 8 2013, 02:52 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
We do a very simple and easy mod for our customers that almost anyone can do. Nice (IMG:style_emoticons/default/idea.gif)I was told it added nearly 50% in stiffness and the bonus is, there's no weight penalty. I like it because it's inexpensive, simple, it works and it's fairly noninvasive. Get a long bit and drill two holes straight through the arms. Then get a Step Bit and drill those holes out to 1" like so: Weld in two 1" tubes to add lateral stiffness: Paint or powder coat the arms: We also add gussets to the shaft tube: I also added the bulkhead to inner mount bars on my car. Not sure of the overall effectiveness for a street car but, the car feels like it's on rails. (IMG:style_emoticons/default/wink.gif) |
Steve |
Mar 8 2013, 08:00 AM
914 Guru Group: Members Posts: 5,775 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
JW aka Otto, RIP, who holds track records in 914's was a firm believer in the trailing arm stiffening kit. I bought his kit and installed them on my car.
76-914 |
Mar 8 2013, 09:21 AM
Andy, did you use .060" or .090" tube? |
brant |
Mar 8 2013, 09:27 AM
Lo-Fi Version | Time is now: 10th January 2025 - 07:27 AM |
