Pop up headlight delete? |
John1180 |
Mar 7 2013, 11:45 PM
Newbie Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None |
I've been looking for some ideas for an alternative to pop up headlights. Haven't found anything in search. Any ideas or pics?
bfrymire |
Mar 7 2013, 11:58 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Did you look in the vendor section? I seem to remember someone making a gt kit.
--brett |
CG-914 |
Mar 7 2013, 11:59 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
I would hate to see them gone completely but with the fog lights from the '75 and '76 you could replace the 55W bulb with really bright once after adding a relay and use them as your headlights. For more details you need to ask somebody else though...
John1180 |
Mar 8 2013, 12:26 AM
euro911 |
Mar 8 2013, 02:27 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,859 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'm not thrilled with the pop-up headlights either, never liked the look (IMG:style_emoticons/default/dry.gif)
The fog light locations are typically too low to meet DOT regulations. Felix (neo914)? was probably one of the first guys that I've seen successfully install some decent looking headlights in the turn signal buckets. Try searching his topics. |
shuie |
Mar 8 2013, 06:53 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Unfortunately, the information on this site is pretty limited. The only thing you are going to find is the old group buy thread and some decent pictures from the pbase 914-6GT site of a kit install.
Here is the thread of the Mittelmotor kit installed: http://www.914world.com/bbs2/index.php?sho...=109603&hl= |
jasons |
Mar 8 2013, 08:22 AM
Jackstand Extraordinaire Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
jim_hoyland |
Mar 8 2013, 09:35 AM
Get that VIN ? Group: Members Posts: 9,551 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Here's an intresting headlight mod:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i721.photobucket.com-643-1362756933.1.jpg) |
jim_hoyland |
Mar 8 2013, 09:41 AM
Rand |
Mar 8 2013, 09:51 AM
Look for Turboman808 (I think that's his handle here). There are pics of his car in all it's phases. When he bought his car, the headlights were covered with clear but in the stock location in a fixed position. Didn't look right. Then they moved to the signal buckets and used a hood with the corners filled IIRC. I think RacerChris did the work - try searching that.
Bdog's awesome custom six had the headlights in the bumper and shaved hood. Technically not DOT legal because of the height, but depending on where you are it probably won't be enforced. Several others like that - as Jim showed above. Bottom line is they either need to go in the bumper or the signal buckets. Getting good lights in latter take a lot of work in such a small space. I used to want to delete the flip-up headlights. Now I wouldn't do it. It takes away a little piece of character from the car. |
gopack |
Mar 8 2013, 01:39 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
any one ever try any thing like this? i always thought i would like this solution
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.fieroforum.com-2472-1362771564.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.fieroforum.com-2472-1362771565.2.JPG) this is from a fiero, but this mod would work on a 914 |
GeorgeRud |
Mar 8 2013, 02:38 PM
The Fiero look isn't bad, but I kind of like the 'happy' look the raised headlights give the car.
I would be concerned about the DOT legality, and it could become a real bone of contention on a street car. Quite expensive to try to switch back. |
gopack |
Mar 8 2013, 02:54 PM
With the Fiero type i posted, all it would take is a different light holding mechanism and a reduced ratio for the lift mechanism. the only legal problem would be if the centers of the headlights dont meet the minimum height above the road requirements. WHat i don't like is the HUGE surface area of the open headlight, it looks so ungainly! the lower profile is much less ungainly.
California code: 24400. (a) A motor vehicle, other than a motorcycle, shall be equipped with at least two headlamps, with at least one on each side of the front of the vehicle, and, except as to vehicles registered prior to January 1, 1930, they shall be located directly above or in advance of the front axle of the vehicle. The headlamps and every light source in any headlamp unit shall be located at a height of not more than 54 inches nor less than 22 inches. |
Mike Bellis |
Mar 8 2013, 03:29 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
monkeyboy |
Mar 8 2013, 03:40 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
How high is that Mike? Is it legal?
gopack |
Mar 8 2013, 03:58 PM
I've seen Mike's in person, and my guess is that with the way his car is so lowered he might be close! all you need to do is raise it back up, bring it in for the fix it ticket and then lower it back down!
is the center at or above 22 inches Milke? would you measure it for us? |
carr914 |
Mar 8 2013, 06:46 PM
Racer from Birth Group: Members Posts: 122,420 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Here's an intresting headlight mod: (IMG:http://www.914world.com/bbs2/uploads_offsite/i721.photobucket.com-643-1362756933.1.jpg) That's a Real GT If you're going to eliminate the Pop-Ups, make sure what ever you do is Legal Height-Wise |
John1180 |
Mar 8 2013, 09:48 PM
Love all the headlight ideas! Keep 'em coming!
Cap'n Krusty |
Mar 8 2013, 10:02 PM
Not only do you have to consider the height requirement, the lights you use must be DOT approved for use as headlights. Lotta lights are "DOT approved",but not for use as headlights.
The Cap'n |
Elliot Cannon |
Mar 8 2013, 10:09 PM
I always liked the retractable headlights on the 914. (IMG:style_emoticons/default/biggrin.gif) I always thought of them as one of the more charming things about the car. That and two trunks, removable top and go-kart handling. (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 17th December 2024 - 10:40 PM |
