Front wheelwell wheelhouse repair |
shuie |
Mar 12 2013, 11:51 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Does anyone have any good pictures or experience in repairing the front inner wheelhouse structure of a 914 tub. The best pictures I can find so far are in the bringing out the dead thread. Some really good stuff there with the factory jigs, etc.
At some point my 914 was hit hard enough on the front driver side corner to crumple the front half of the wheel well. Everything in this area was hammered back into place and painted over. I've restored all of the front suspension pieces. I don't know if they are original to the car, but the a-arms & crossmember are straight and bolt onto the car fine, so I think there is a possibility that everything might still be pretty square. I don't have a Tram gauge so I haven't measured the suspension pickup diagonals yet. Assuming the car is still square enough to fix, I really want to do a proper structural repair. Either with a new fender, wheelhouse, front latch panel, and floorpan, or by building some kind of tube subframe that ties the strut towers and all of the front suspension points together. Does anyone here have the fixtures to do these repairs? These pictures are all from Jeff Hail's Bringing out the dead thread. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-2075-1363110702.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-2075-1363110702.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-2075-1363110702.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-2075-1363110702.6.jpg) |
falconfp2001 |
Mar 13 2013, 02:43 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
Awesome pics
jmill |
Mar 13 2013, 08:41 PM
You can make one yourself like I did. Check out the link in my signature.
shuie |
Mar 14 2013, 06:48 AM
jmil, that thread in your signature has a lot of the info I was looking for. Thanks. Nice work!
Yep, if I decide to try to do this myself I will make a similar fixture. I need to measure everything and make sure it's 100% straight and square. I don't know if I know enough to get everything perfectly level and measure everything properly. Im almost ready to put the car on a trailer and send it to someone like Scotty or Series9. If I could get a fixture that I knew was true and confirm that it bolted onto my car I would feel a lot more confident trying the repair myself. Here is another pic from Jeff Hail's Bringing out the dead thread that shows the measurements I am going to look at first. I think I need a Tram gauge to get these right. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-2075-1363268003.1.jpg) |
shuie |
Mar 15 2013, 06:30 AM
Does anyone know if the wheelhouse panels were different on an early car vs. a later impact bumper car? Repair panels for this part of the car are not real easy to find.
gms |
Mar 15 2013, 09:44 AM
Advanced Member Group: Members Posts: 2,708 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Does anyone know if the wheelhouse panels were different on an early car vs. a later impact bumper car? Repair panels for this part of the car are not real easy to find. The front wheel houses are the same all years except for the very early cars (1969) with different cowl and front fenders. |
A&PGirl |
Mar 15 2013, 01:00 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
I'm very interested in this as well. I have to replace both wheelwell and wheelhouses on my OSU orange car.
Katmanken |
Mar 15 2013, 05:51 PM
Me too.
I've got a car where the DAPO bondo'd the left wheelhouse, and the bulkhead had a deflection in the middle. Paging Rick Ollah..... |
gms |
Mar 16 2013, 10:40 AM
Me too. I've got a car where the DAPO bondo'd the left wheelhouse, and the bulkhead had a deflection in the middle. Paging Rick Ollah..... If you are close to Portage IN contact Garold Shaffer as he parts out a lot of cars and would have the sheet metal you need. |
gms |
Mar 16 2013, 10:42 AM
shuie |
Mar 23 2013, 11:45 AM
Any tricks for getting an accurate measurement of the suspension points without a tram gauge while the tub is on jack stands? I really don't want to buy a tool like that for a one time use.
FourBlades |
Mar 23 2013, 11:49 AM
From Wreck to Rockin Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Buy long bolts to put into the holes and stretch a tape measure between them.
I think my tram gauge from auto body tool house was around $250 or so. They are useful for doing alignment checks as well. John |
shuie |
Mar 23 2013, 12:22 PM
Buy long bolts to put into the holes and stretch a tape measure between them. yep, tried that first. The longest bolts I could find from the hardware store don't clear the bottom of the tub from the rear suspension console. I'll try a bolt store next week to see if they have something longer. |
mr914 |
Mar 23 2013, 05:03 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Does anyone know if the wheelhouse panels were different on an early car vs. a later impact bumper car? Repair panels for this part of the car are not real easy to find. The front wheel houses are the same all years except for the very early cars (1969) with different cowl and front fenders. I thought I was seeing things while putting my early 6 together (IMG:style_emoticons/default/w00t.gif) . Know it makes sense |
sixnotfour |
Mar 23 2013, 05:40 PM
914 Wizard Group: Members Posts: 10,680 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
buy some all thread and cut to length
Lo-Fi Version | Time is now: 26th December 2024 - 12:09 PM |
