budget helmet recommendations? |
chunger |
Nov 18 2004, 03:31 AM
Member Group: Members Posts: 409 Joined: 11-January 03 From: Albany, CA Member No.: 133 |
Hello,
Christmas is around the corner, and I was wondering if you guys could point me to a good entry level helmet I could ask for for Christmas and possibly a good vendor to buy from. -'Chung |
ChrisReale |
Nov 18 2004, 03:34 AM
For AX, just go to a motorcycle shop and get a snell 2000 rated helmet. If you are doing track stuff, I would spend more money and get a proper road racing Bell or Simpson.
http://www.ogracing.com |
machina |
Nov 18 2004, 06:49 AM
Do you have a "budget" head? Spend some $$ and get a good SA rated helmet that fits right. Stick with the big names. Also, some brands fit different peoples heads better, so find out if you have a simpson head or a bell head, etc.
If you get a MA rated helmet it will be fine for AX but if you ever want to venture onto the track, you'll have to buy another helmet that is SA rated, that wouldn't be too cost effective. |
mudfoot76 |
Nov 18 2004, 07:16 AM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
QUOTE(synthesisdv @ Nov 18 2004, 07:49 AM) Do you have a "budget" head? Spend some $$ and get a good SA rated helmet that fits right. (IMG:style_emoticons/default/agree.gif) A helmet is too important to go cheap on. Get one with an SA2000 rating (it will be good for 10 years!) that fits you right. Go to a shop and try the different ones on. Open face? Closed face? Do you plan to wear a balaclava underneath? I wasn't aware that AX allowed M-rated helmets, but if you ever plan on running in DE, they all require the SA rating. |
Part Pricer |
Nov 18 2004, 07:39 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
If you don't need one right away, I would personally wait until the Snell 2005 rated helmets hit the market. That would give you a 10 year life span as most organizations allow current + 1 prior for helmets (meaning... next year you may need to have either a 2000 or 2005 rated helmet).
One other thing to be concerned with when looking at helmets is that the SCCA is looking at restircting the use of full-face helmets in airbag-equipped vehicles. So, if you think that you may be in an airbag-equipped car in an event in the next ten years, you may want to wait until the SCCA releases their more restrictive language. QUOTE Participant Bulletin DATE: November 16, 2004 FROM: National Staff TO: All Participants SUBJECT: Airbag Advisory It has been brought to the attention of SCCA Technical Services that the use of full-face or closed-face helmets while driving vehicles with active airbag restraint systems may result in injuries in the event of a crash that deploys the airbag. Because of the location of the steering wheel relative to a driver’s position, the airbag axis is on a level with the driver’s chin. In a crash with airbag deployment, contact with the chin area of a full-face helmet can be so powerful “that the risk of fractures to the jaw cannot be ruled out“ (Hubert Gramling, FIA Institute, FT3/AF, 18.5.1999). This applies to vehicle that may be used in Solo, RallyCross, High Performance Car Control Clinics, etc. Therefore, it is highly recommended that full-face helmets not be used in vehicles with functional airbag systems. Potentially more restrictive language is currently being considered for 2005, which could appear in an early 2005 issue of FasTrack. If you have any questions, please contact the SCCA at (800) 770-2055. http://www.scca.com/_Filelibrary/File/Airb...bagAdvisory.pdf |
ArtechnikA |
Nov 18 2004, 07:56 AM
QUOTE(Paul Heery @ Nov 18 2004, 05:39 AM) ...I would personally wait until the Snell 2005 rated helmets hit the market. That would give you a 10 year life span as most organizations allow current + 1 prior for helmets (meaning... next year you may need to have either a 2000 or 2005 rated helmet). One other thing to be concerned with when looking at helmets is that the SCCA is looking at restricting the use of full-face helmets in airbag-equipped vehicles. what i've heard (and someone please point me to a definitive source if i am wrong...) is that Snell releases its certifications on a 5-year period, and that they do so near the end (or beginning) of the Snell Memorial Foundation fiscal year - which is near the end of the calendar year. IOW - the Snell 2005 Standards will be published late in 2005 and new helmets with the 2005 certification will start reaching the market in mid-2006. this is consistent with my own experience trying to buy a conforming SA helmet. even as late as May 2000 there were no SA2000 helmets to be had from any source. i have a SA1995 as a result... oh well - it'll be a good base for airbrush design exercises when it's obsolete... BTW - i got a G-Force forced-air SA-2000 for Joy and the price was quite reasonable. although there is the additional hassle factor with forced-air ventilation, i really recommend it for a closed car in the sunbelt if it's at all workable for you. if my SA95 gets rendered obsolete before the SA05's are available (something the sanctioning bodies say they won't do, but...) i'll probably get a G-Force for myself as well. and remember as always - the Snell certifications are minimum standards, and helmets are graded Pass/Fail only. so - there MAY still be quality differentiations even among the rated helmets. i've read the standards (the link to the Snell site was posted here the last time we had a helmet thread...) and i am satisfied with a minimum-standard-conforming SA helmet. i track a 911 with a Targa bar *and* a cross-braced roll bar ... and despite its slight additional cost, i think the SA-rating is worth having *especially* in a closed car - FIRE BAD! |
Qarl |
Nov 18 2004, 08:14 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Don't skimp.
Would you buy budget seat belts, or budget rebuilt calipers on a racer car? Try some on first, buy on fit and safety vs price. |
VegasRacer |
Nov 18 2004, 09:44 AM
ELVIRA Group: Benefactors Posts: 8,526 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
All of the previous posters have given good information. I have checked with several suppliers and it will be another year before the SA2005's are available.
There are some good deals on-line, but you gotta try one on to see how it fits. Helmet City in Oakland sells most of the popular brands. They might be a good place to start shopping. |
dwillouby |
Nov 18 2004, 09:50 AM
Member Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
I have told people" If you have a 10 dollar head buy a 10 dollar helmet".
My brother took my advice. He later crashed his dragbike at over 100 mph at about 1/2 track. He slid through the lights at 60mph. Helmet (and leathers) saved his life. Buy the best you can afford. David |
boxerboy |
Nov 18 2004, 01:18 PM
boxerboy Group: Members Posts: 26 Joined: 12-June 04 From: Lone Tree, CO Member No.: 2,194 |
Ok, I'm going to show my age here, but when the first wave of Jap bikes hit the USA back in the 60's and really cheap helmets appeared all over, I remember a Bell helmet ad in one of the bike mags that said "If you've got a $5 head... buy a $5 helmet... if not, buy a Bell.
The prices may be different today, but the sentiment is still spot on. |
ArtechnikA |
Nov 18 2004, 01:34 PM
part of the problem (and confusion) is that there are far more options available now.
and there are "super-premium" products available. we also tell people "buy the lightest helmet you can afford." (all this is in the context of a helmet that meets the sanctioning body's requirements, of course...) other things being equal, among Snell-SA-rated helmets, carbon fiber will be lighter than Kevlar which will be lighter than fiberglass, and that's pretty much how the prices run, too. the "pro-level" stuff, suitable for Indy cars pulling 3+ lateral g's in the corners plus whatever the banking adds, will be light - and expensive. (pros have sponsors, contingency money, and endorsement contracts...) Kevlar is probably the lightest consumer-grade helmet most of us can afford. if you can afford a top-of-the-line Simpson in carbon fiber, great ! but most of us have to consider the full package, and a top-of-the-line CF Simpson is right around $1000. if an equivalently rated Kevlar helmet is a few ounces heavier and $500 less, i can think about replacing my belts every year instead of every three, for instance ... |
chunger |
Nov 18 2004, 01:44 PM
Thanks for the replies... . I should go check out helmet city in oakland so I can become a helmet head.
I figured there are a wide variety of things involved in helmets that determine price and may or may not effect strength/fit. For instance, you can use really expensive processes and materials to make a helmet very light w/ same strength at mabe double the price, but I won't need that Or stuck it in a 5,000,000 wind tunnel to shave .02 off drag coeficient on an open racer. . . just want to know what to look for. So, seems the concensus is stick w/ major brand. . . Bell, Simpson. . . get fire rated one, and get the one that fits best. -'Chung |
chunger |
Nov 18 2004, 01:49 PM
I won't enter into the debate about what dollar value to put on my head (IMG:style_emoticons/default/blink.gif) I have lots of surgeon cousins, and they tell me all the time how many head trauma people they see because they become organ donors. . . so I wear a good helmet when snowboarding, riding a bike, and certainly will invest in a suitable car helmet
mabe I should have posted this as a poll question: How much do you think 'Chung's head is worth? -'Chung |
ArtechnikA |
Nov 18 2004, 02:05 PM
QUOTE(chunger @ Nov 18 2004, 11:49 AM) How much do you think 'Chung's head is worth? guess it'd depend on if you were a tissue match or not :-) ... |
Sammy |
Nov 18 2004, 03:36 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
Caution, another urban myth ready to be challenged!
Spending a whole bunch of money on a big name brand is.... well it is expensive. You can get just as much quality and protection with a G-force SA2000 helmet and save some money for something else. If the helmet is for automobile use, get an SA2000, if it is strictly for motorcycle use, get an M2000. That's what they are made for and are not identical in design or construction. SA2000 uses kevlar weave and nomex lining and is designed to protect against multiple impacts and also fire. No one, and I mean no one, will ever be able to convince me that a Bell or Simpson will protect my knoggin any better than an identically rated G-force. For all I know they could be made in the same factory. The only reason to buy a more expensive helmet is if the more expensive one fits your haid better. You really should try several on before making the decision, everyone's haid is different. That saying "if you have a $5 head, buy a $5 helmet" (or whatever the dollar figures were) was written and distributed by marketing people to help sell expensive helmets and is pure BS IMO and I refuse to be brainwashed by marketing hype. They wouldn't distort the truth, would they? |
Joe Ricard |
Nov 18 2004, 03:42 PM
I bought a Scorpion (chinese) Full face Motorcycle helmet Snell and DOT approved. the entire lining comes out for washing and drying. If you ever sat in grid waiting to run and it's 95 hundred degrees outside. You may want to wash the insides before the next event.
theol00 |
Nov 18 2004, 04:02 PM
Member Group: Benefactors Posts: 242 Joined: 22-January 04 From: Campbell, CA Member No.: 1,586 |
BELL Helmets closeout - good deals
go to the the www.bellhelmets.com and look for closeouts http://www.genuineaccessories.com/Closeout...ut/closeout.htm |
scooter311 |
Nov 18 2004, 04:04 PM
Member Group: Members Posts: 231 Joined: 22-October 04 From: Upstate NY Member No.: 2,986 |
Been buyin noodle buckets for a while - don't forget either that if your noggin' takes a floggin, you may have to junk it and buy another. The foam / cell liner gets impacted, and can no longer protect your melon. I have a really nice Bell that I've had for a while, and the foam finally gave out - time to buy another..... It conforms to your head when new, and once it's crushed, even a little, it will fit a little worse and wont' have the impact protection any more.
I have a Shoei VFX as well - you can find lots of good deals on top dollar helmets after the new year, distributors will sell then real cheap once the new models come out. It was a 450 dollar helmet, I bought it at closeout for 179 bucks. I'll never pay full price for a top-name, but the cheepo ones are in most cases poorly made. Cheers! Jeff |
TimT |
Nov 18 2004, 04:30 PM
well its all good advice... but also get one that fits well.. try a few on, different brand helemets fit differently
the removable liner is a definite must. I also recommend a full face helmet. Even though my cars are closed I drive with the visor down. I have been hit by errant pebbles, faces full of dust, rubber tire snots etc... I dont want any of those things contacting my eyes, or skin when I pulling at 130 or so.. |
Nov 18 2004, 05:22 PM
914 Idiot Group: Members Posts: 14,997 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A few points from my perspective:
First, Chung's local PCA does allow M-rated helmets for both Driver's Ed and Time Trial. (As well as for autocross.) Things may very well be different if you go outside of Zone 7 PCA, Chung, but as long as you just play here you're fine with M. Second, as of a few years ago there were precisely two different tests that the helmets went through to get an SA-rating over an M rating. One was testing that the liner was fire-resistant. The other was a drop test onto a cylinder--a simulated roll-bar hit. This is in addition to the "ledge" hits, the point-impact hits, and so on and so forth. I believe it would be very difficult to design a helmet that would pass the other impact tests, and also fail the roll-bar hit test... And I know that some manufacturers have used a single shell design, with different liners for M- and SA-rating. And if it ever gets to the point where it matters if my helmet liner is fireproof or not, I am probably not surviving anyway. Third, any hard hit on the helmet turns it into a paperweight. The foam inside is a one-time-use kind of thing, and the shell is a one-time-stressed kind of thing. Bounce your head off the pavement while wearing the helmet, get a new helmet. Ditto for the roll bar or what have you--if you hit hard, new helmet time. Fourth, someone posted on the Pelican BBS (either Racing or 914) that the new -05 helmets are slated to start coming out in October of 2005. They said they got that from the Snell Foundation website. Fifth, fit is vital. Try on a whole bunch of different helmets--that's why it is important to go shopping in person. Hopefully there is a good salesperson there to help you out. My GF and I went to Wine Country Motorsports (I told her she'd pay a 25% premium for that, but she wanted to go there!) and the guys there were very knowledgeable and just great to work with. ...I personally have a head that ain't worth that much. I have a <$100 open-face M-rated helmet. It is nice and lightweight, and I can wear my glasses with it very easily. I have found that I have real difficulty putting on my glasses when wearing a full-face helmet. (Damn round face of mine...) There is a pretty good chance that I will get a full-face helmet anyway if and when I get back on the Big Track for real, but for a while I will be quite happy to use my heap-a cheap-a helmet. --DD |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:03 PM |
