45 Pages V « < 17 18 19 20 21 > »
> Porsche 914 - 8 GTT, November '24 Update
whitetwinturbo
post Feb 3 2019, 10:47 PM
Post #361
Auto nirvana (IMG:style_emoticons/default/pray.gif) .........I still love and need your wing and it's support set up. What does it take to get a copy?
Cracker
post Feb 4 2019, 06:39 AM
Post #362
Off the hook Marty, off the hook...great job!
Tony
rgalla9146
post Feb 4 2019, 07:26 AM
Post #363
Goodness gracious.
Unbelievable.
Maltese Falcon
post Feb 7 2019, 01:12 AM
Post #364
QUOTE(whitetwinturbo @ Feb 3 2019, 08:47 PM) *
I think that these wing supports can be easily duplicated , I can show you around the project and supply you with a few of the aluminum bits...then you can take it to the next level. Call me when you can & jump over here on a Saturday 818.five0seven.69three7 (IMG:style_emoticons/default/thumb3d.gif)
And thank you guys Dave, Mark, Lawrence, Tony & Rory for your support !!
Maltese Falcon
post Mar 2 2019, 07:58 PM
Post #365
Things to do while waiting on StopTech brake order...finish up the JRZ nitrogen cannister brackets. Once the brakes are received and mounted, I can then determine the offset measurements for the custom wheel order. Lots to do while waiting for special order parts...
Maltese Falcon
post Mar 2 2019, 08:00 PM
Post #366
...another view
Maltese Falcon
post Mar 2 2019, 08:02 PM
Post #367
4 JRZ cannister brackets walk into a Starbucks...Attached Image
sixnotfour
post Mar 2 2019, 08:11 PM
Post #368
since you have time..your gonna need bigger wheel bearings...??
Maltese Falcon
post Mar 2 2019, 08:41 PM
Post #369
QUOTE(sixnotfour @ Mar 2 2019, 06:11 PM) *
Jeff, just going to run new bearings and change these out as "Wear & Tear " parts through the race season. Would be great to have custom arms and run larger dia 934 c/v joints with bigger bearings, but even those will require change out intervals.
sixnotfour
post Mar 2 2019, 10:04 PM
Post #370
there is a guy that ended upwith a bunch of vellios castings..I know the history,,but,,easy . I believe he has some not fully machined castings still...
I bought the 2 fully machined sets one 3.o and turbp spacing...my other 914 has a machined set custom .from AZ.... time..
I am just sayin easy now..
KELTY360
post Mar 2 2019, 10:18 PM
Post #371
914 Neferati
QUOTE(Maltese Falcon @ Mar 2 2019, 06:02 PM) *
......and?
There's got to be a barista joke in there somewhere. (IMG:style_emoticons/default/shades.gif)
Maltese Falcon
post Mar 2 2019, 11:01 PM
Post #372
QUOTE(sixnotfour @ Mar 2 2019, 08:04 PM) *
Wonder what George was up to making trailing arm bits ¿¿ I only knew about his 916 (style) trans castings. Looks impressive.
Mayne
post Mar 3 2019, 08:29 AM
Post #373
QUOTE(Maltese Falcon @ Mar 2 2019, 09:02 PM) *
That’s a latte fabrication.
Maltese Falcon
post Mar 3 2019, 11:38 AM
Post #374
QUOTE(Mayne @ Mar 3 2019, 06:29 AM) *
(IMG:style_emoticons/default/biggrin.gif) ...the caffeine does help !
Kelty360...
Barista says : "I will need to keep the 4 of you in this tray so you don't Shock the customers"
gotta be something better than that (IMG:style_emoticons/default/smile.gif)
whitetwinturbo
post Mar 11 2019, 10:28 PM
Post #375
QUOTE(Maltese Falcon @ Feb 6 2019, 11:12 PM) *
Will do soon via nine4nine.three78.sixteentwenty-five
Maltese Falcon
post Mar 31 2019, 05:58 PM
Post #376
Looking for JRZ mounting areas...front is good , rear should work tucked in a corner
Maltese Falcon
post Mar 31 2019, 05:59 PM
Post #377
Getting into the new engine lid design
Maltese Falcon
post Mar 31 2019, 06:02 PM
Post #378
It's not a proper race car without some red registration-marks; these are for quick sight reference for neutral
Maltese Falcon
post Mar 31 2019, 06:08 PM
Post #379
Harbor Freight didn't have a small dolly for the nitrogen tank, so had to custom make one with coffee cup holders (IMG:style_emoticons/default/smile.gif)
Maltese Falcon
post Mar 31 2019, 06:11 PM
Post #380
Last mod needed on the SQS sequential shift module; a bit of an angle change to one of the brackets
- Lo-Fi Version Time is now: 24th November 2024 - 04:44 AM
