45 Pages V « < 19 20 21 22 23 > »
> Porsche 914 - 8 GTT, November '24 Update
Maltese Falcon
post Sep 22 2019, 07:37 PM
Post #401
Good point Pete, and the wheel-bearing design-reference back to the '60s is a good point. The air cool era design could be inferior to the (newer) 996 design...however I'm using the latest ( slightly larger) bearing/ hub from the '87-89 Carrera. It's just one more wear + tear item on the car (as are the rear T- arm bearings) that will be inspected and changed out throughout the season of club racing.
I'll run this by my suspension guru Cary as well.
Appreciate your enthusiasm in our build project !
Lucky9146
post Sep 22 2019, 08:19 PM
Post #402
Just catching up on this thread.
Simply stunning Marty, absolutely love all you are doing.
I think the build is the most fun part, figuring everything out along the way is what really drives people to improve on things.
Congrats of continued progress and thanks for posting! (IMG:style_emoticons/default/beerchug.gif)
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg)
Maltese Falcon
post Sep 23 2019, 06:49 PM
Post #403
JRZ performs this (RSR) structural "Gusset" mod to the late 911 Carrera struts when you order their shock absorber system. A bit more strength...I'll run with these & change out the bearings as needed.
Note; the excess black coating on the spindle is removed prior to use.
Maltese Falcon
post Sep 23 2019, 06:57 PM
Post #404
Checking it twice ; updated the Haltech Elite 2500 with mods to the 8 coil pack grounds (-)
ECU cables/ control boxes going in first/ basic car wiring going in secondarily.
Maltese Falcon
post Sep 23 2019, 07:01 PM
Post #405
QUOTE(Lucky9146 @ Sep 22 2019, 06:19 PM) *
Jim (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/thumb3d.gif) !!
Maltese Falcon
post Sep 24 2019, 08:55 PM
Post #406
Another Gran Prix white with v8 Cayenne power, this is the Riley from 2010 Daytona era . Action Express team/ Lozano Bros. Porting engine !
Matty900
post Sep 24 2019, 10:24 PM
Post #407
Such an awesome build Marty & Matt. Let me know if there is anything we can do to help (IMG:style_emoticons/default/beerchug.gif)
MATTYLITE
post Sep 25 2019, 12:31 PM
Post #408
Thank you! We cannot express our gratitude enough to you guys over at 914 Rubber for the products we have on our project. Top notch quality all the way.
-Matt
QUOTE(Matty900 @ Sep 24 2019, 09:24 PM) *
Maltese Falcon
post Oct 31 2019, 10:16 PM
Post #409
Merting of the minds with Brian, founder of Sway-a-way products. Axel discussions ...lots of good info from him !
Maltese Falcon
post Oct 31 2019, 10:33 PM
Post #410
Since I haven't ordered custom length axels in a long time, Brian suggested this fail-safe measuring method: cut an old axel in 1/2, set into a 1 1/4" piece of angle iron, and using 2 gear-clamps (to hold final length in place)...measure the distance between c/v joints. Measurements taken in full rear suspension droop. The 996gt2 transaxle is not mfg with an off center case...so measurements will be within a 1/16" or so Left axel and Right axel lengths. Working direct with Sway-a-Way (approx 30 min from msds,inc) helps a lot too ! Our new axels are being made from 300M alloy, and have more spline (broach) lengths at both ends, so they float as opposed to being circlipped in place. Only using 1 circlip at the trailing arm side.
Maltese Falcon
post Oct 31 2019, 10:43 PM
Post #411
While waiting on axels...I jumped back on the left & right engine grill.
It's 2 seperate lift-off type.
Setting up some support plates and frame; transferring the grill-pattern (for 8/32 bolt holes) via spray paint ...
Maltese Falcon
post Oct 31 2019, 10:53 PM
Post #412
Drill transfer( grill pattern ) now visible on the 16 ga. metal side bracket. The lift-off grill sections will include the small side grill (next to targa sail) lifting out simultaneously.
Maltese Falcon
post Oct 31 2019, 10:57 PM
Post #413
Left and Right grill brace plates
Maltese Falcon
post Oct 31 2019, 11:01 PM
Post #414
How the right side prototype looks, the 3/4" aluminum channel is the main backbone where the next section of grill is mounted to ; kind of like building a gt grill with an extra section of material ( donor grill).Attached Image
Maltese Falcon
post Oct 31 2019, 11:07 PM
Post #415
Extra benefit from the VW/ Karmann mfg of our 914s; the prongs on these engine grills are nothing more than roof-nails...cost effective !!
With a bit of coaxing...I was able to put a 3mm die on these, and now have xlnt anchor points for fastening all of this puzzle together.Attached Image
Maltese Falcon
post Oct 31 2019, 11:09 PM
Post #416
Makes for a neat assembly...
Maltese Falcon
post Oct 31 2019, 11:17 PM
Post #417
I know that there is a Snap-on brand tool for removing these darn rubberized fasteners, but I just fabbed one up in 10 min...
Thank you Bruce Stone & Garold S. for being the Grill Sargents !!
Maltese Falcon
post Oct 31 2019, 11:28 PM
Post #418
More on the twin lift-off grills as I make progress...now onto the custom rear tow-loop. GCR's in my club won't allow the 914 tow hook, and Rennline does not mfg a rear tow-loop for 914. 911 size thread is different...so built one this way:
Pegasus online has the SCCA approved loop diameter, made for the Ford Fiesta, but no threaded portion. I cut one of Auto Atlanta's new tow hooks then welded it to a machined piece of 3/4" barstock , it is durable and flips down when not needed. Same spot in the rear bumper as always !
Shown not yet fully TiG welded...
Maltese Falcon
post Oct 31 2019, 11:29 PM
Post #419
Folded down at 90° when not in use...
Maltese Falcon
post Feb 14 2020, 11:33 PM
Post #420
Pre-fitting Right side, make a few small adjustments, finish in satin-black, then black rubber edging, and add 2 hood pins...this is how I rock the 914 grill
- Lo-Fi Version Time is now: 24th November 2024 - 07:04 AM
