Porsche 914 - 8 GTT, August '24 Update |
Maltese Falcon |
Jun 2 2024, 08:47 PM
Advanced Member Group: Members Posts: 4,815 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Maltese Falcon |
Jun 2 2024, 08:52 PM
Maltese Falcon |
Jun 4 2024, 02:50 PM
NorCalScott |
Jun 7 2024, 07:22 AM
Newbie Group: Members Posts: 30 Joined: 6-February 21 From: Sacramento Member No.: 25,173 Region Association: None |
www.fittings.space in Sparks, NV, makes all sorts of 'Metric to SAE, AN, NPT adapters, which we used their *stainless steel part here/ in conjuction with a VDO ⅛" NPT sending unit. Saving this resource. Little things like this can be so frustrating when you can't find the right adapter. |
Maltese Falcon |
Jun 13 2024, 06:57 PM
Maltese Falcon |
Jun 13 2024, 08:52 PM
Maltese Falcon |
Jun 18 2024, 09:51 AM
Maltese Falcon |
Jun 18 2024, 09:55 AM
Maltese Falcon |
Jun 18 2024, 10:00 AM
Maltese Falcon |
Jun 18 2024, 10:15 AM
I think that with the adding of 2) Garretts, wastegates, intercooler and b/o/v are all packed into the 'Trunk area, No more luggage room avail. Maybe just strap these to the cold side of intercooler (IMG:style_emoticons/default/biggrin.gif)
Maltese Falcon |
Jun 20 2024, 04:30 PM
Good day today & tidied up runs of wire that have been pulled through into the trunk area. I use 'Goodridge fire sleeve which I've been sourcing at www.pegasusautoracing.com
Also purchased all sorts of racing hardware, Tilton pedal assembly, brake bias control, etc. from them; excellent product knowledge/ customer service (IMG:style_emoticons/default/thumb3d.gif) |
Maltese Falcon |
Jun 20 2024, 04:39 PM
Nice to see Goodridge product on the Porsche 963 (IMG:style_emoticons/default/biggrin.gif)
Looks like they are fire-sleeving the turbo oil supply (#4AN) lines, and #12AN (oil drain scavenge) lines which seem to be in a super hot zone ! |
Maltese Falcon |
Jun 21 2024, 06:20 PM
KELTY360 |
Jun 21 2024, 07:11 PM
914 Neferati Group: Members Posts: 5,080 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Maltese Falcon |
Jun 23 2024, 08:51 AM
@KELTY360 Marc, the 8gtt sounds should be an earful...even for a non-flat plane crank Cayenne v8 ! The basic tech in my shorty shorty header design, is how the placement of the tubes enter into the collector; left and right side headers respectively.
Following the Cayenne v8 firing order: 1-3-7-2-6-5-4-8 I place the tubes in a (rotational) position, so during the normal scavenging taking place = the exhaust pulses fire into the collector in a rotational fashion. This gives an extra performance benefit during evacuation of the exhaust pulses. Can't hurt getting the pulses to scaveng even quicker, right? |
Cairo94507 |
Jun 23 2024, 09:18 AM
Michael Group: Members Posts: 10,001 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Next level greatness for sure. (IMG:style_emoticons/default/smilie_pokal.gif)
Maltese Falcon |
Jun 25 2024, 05:19 PM
Passenger side exhaust header with EGT, and o2 port ready for install.
(IMG:style_emoticons/default/marty914.jpg) |
Maltese Falcon |
Jun 25 2024, 05:35 PM
I'm having a few sets of these 18ga. SS plates laser cut for use with these cool 914 headlights, which install into the previous front turn signal locations.
Since we are using Sheridan fiberglass body panels, when you slice the (faux) turn signal 'Pods from the top of the fenders you are left with a ¹/16" perimeter edge...which is not real sturdy to attach these light fixtures on. The thin plates will be epoxied into place, then these new light assemblies* will have a sturdy foundation to sit on. Then I will add another support bracket inside the fender, in order to catch the stud/nut on the assembly. Mfg. by* www.3DGAUTO.com |
Maltese Falcon |
Jun 25 2024, 05:43 PM
NorCalScott |
Jun 26 2024, 06:50 AM
very cool headlights
Lo-Fi Version | Time is now: 16th September 2024 - 12:58 PM |
