4 Pages V < 1 2 3 4 >
> JOE's 2013 Hershey Emergency Thread, 5th ANNUAL
VaccaRabite
post Mar 21 2013, 04:41 PM
Post #21
En Garde!
If you bring it over this weekend we could hookup my leak down tester and see ifthere are any obvious issues.just let me know.
struckn
post Mar 21 2013, 06:32 PM
Post #22
QUOTE(Dave_Darling @ Mar 20 2013, 08:35 PM) *
QUOTE(jsayre914 @ Mar 20 2013, 03:15 PM) *
The intake adjuster is now tight against the rocker arm, this is a swivel foot adjuster and the arm was ground down to get the extra play. The play is now Gone. Is that a huge problem for now?
Yes.
Could be a dropped seat. Could be a stretching valve. Neither of those things is anything you want to drive on. Not unless you like holes in the heads, the case, and so forth.
Could be less-dangerous stuff, but do you want to risk it?
Between the shrinking valve clearance and the plug that won't come out, I think the head needs to come off. Now.
--DD
Joe this is too weird. What Dave discribed..... "Could be a dropped seat. Could be a stretching valve"....is exactly what Tony told me last year with mine two weeks before Hershey if you remember. Running on three cylinders, valve would not adjust in or out......... it was a dropped seat. Glad you're not messing around and took it to Tony, you did the right thing and saved your engine by doing so, I think.
Doug
r_towle
post Mar 21 2013, 07:35 PM
Post #23
Custom Member
It runs fine again, most likely it was an over tightened valve that was left open.
Blow back into the heads and or case could cause high pressure in the case or valve covers that might be enough to blow one of the breather hoses off the smooth fittings, then oil blows everywhere.
Barbed fittings for the breathers helps to prevent that...
Stuck plug should be handled by your professional mechanic.
He will remove it and the helicopter coil, then fix it.
Rich
jsayre914
post Apr 9 2013, 07:40 AM
Post #24
Speed Up !!!
(IMG:style_emoticons/default/dry.gif) The seat was hammerd into the head.....
again.
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Head is now at the machine shop, engine is on Tonys floor, Hershey is 11 days away.
(IMG:style_emoticons/default/stromberg.gif)
jsayre914
post Apr 9 2013, 07:41 AM
Post #25
Speed Up !!!
(IMG:style_emoticons/default/sad2.gif)
VaccaRabite
post Apr 9 2013, 06:23 PM
Post #26
En Garde!
QUOTE(jsayre914 @ Apr 9 2013, 08:40 AM) *
Well that blows.
Was there any possible reason mentioned for the failure? Overheating or something like that?
Zach
dirk9141973
post Apr 9 2013, 06:39 PM
Post #27
Unregistered
(IMG:style_emoticons/default/blink.gif) what does valve hammer in head look like ?
saigon71
post Apr 9 2013, 08:27 PM
Post #28
QUOTE(jsayre914 @ Apr 9 2013, 09:40 AM) *
again.
Sorry to hear the news Joe...please let us know what caused it. (IMG:style_emoticons/default/sad.gif)
914_teener
post Apr 9 2013, 10:25 PM
Post #29
Geez, I am wondering after reading the past threads through the years if these are the same 1.8 heads?
If so.....maybe they are bad castings and time to pitch them. (IMG:style_emoticons/default/confused24.gif)
jsayre914
post May 15 2013, 10:22 AM
Post #30
Speed Up !!!
It has now been 52 days 2 hours and 17 min since my car went to TONY.
I am having serious withdraw.
I went to Tonys yesterday and stood behind a 912 while he was adjusting the carbs. The fumes did take the edge off a little. (IMG:style_emoticons/default/sad.gif)
The head was repaired, the crank was repolished, the bushings that Warrior made for the small end of the rods were bad. everything has been cleaned and I sent my exhaust to Chris for an upgrade on the muffler mount. My car is in the back of the garage waiting to breathe again.
Each week I ask Tony..... how long.....
Each week he always tells me "2 Weeks"
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
I am in good hands.
I am patient.
breathe
relax
I can,t take it.......
AAAAAAAAAAAAARRRRRGGGGHHHHH !!!!!!
Joseph
ChrisFoley
post May 15 2013, 10:58 AM
Post #31
I am Tangerine Racing
The exhaust is ready to ship to Tony.
jsayre914
post May 15 2013, 01:07 PM
Post #32
Speed Up !!!
QUOTE(Racer Chris @ May 15 2013, 12:58 PM) *
Such a nice guy (IMG:style_emoticons/default/wub.gif)
jsayre914
post May 15 2013, 01:08 PM
Post #33
Speed Up !!!
QUOTE(914_teener @ Apr 10 2013, 12:25 AM) *
Nope,
these are 2.0 heads, I was switching back and fourth with 2 motors
rgolia
post May 15 2013, 02:15 PM
Post #34
GeoJoe
I know how you feel Joe...I am waiting for my wheels to get back to Tony from the re-finisher. Waiting Sucks, especially this time of year. Car is on stands.....and it is 70 degrees outside. I want my wheels....... (IMG:style_emoticons/default/hissyfit.gif)
jsayre914
post May 15 2013, 02:34 PM
Post #35
Speed Up !!!
QUOTE(rgolia @ May 15 2013, 04:15 PM) *
Does that mkean our cars are hanging out togeather?
that does make me feel a little bit better. At least its not lonley
VaccaRabite
post May 15 2013, 03:06 PM
Post #36
En Garde!
That's good news.
Did he dyno the engine? I'd love to know what it's putting out.
Zach
jsayre914
post May 15 2013, 04:39 PM
Post #37
Speed Up !!!
QUOTE(Vacca Rabite @ May 15 2013, 05:06 PM) *
That's good news.
Zach
Maybe I miscommunicated (IMG:style_emoticons/default/confused24.gif)
Everything is cleaned sitting in a pile waiting for reassembly.
It will be on the Dyno before he is finished
struckn
post May 15 2013, 07:16 PM
Post #38
Hey Joe, like you told me last year, "the wait will be worth it when you see how good it's going to run after Tony gets done with it".
You were dead on, I never knew how much more fun a great running 914 can be and no more worries.
jsayre914
post May 29 2013, 03:51 PM
Post #39
Speed Up !!!
66 days 8hrs 7 min
jsayre914
post May 29 2013, 03:52 PM
Post #40
Speed Up !!!
still waiting......
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 12:10 PM
