front flex lines with 911 struts |
MrHyde |
Mar 17 2013, 12:55 PM
Senior Member Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Starting to do the brake lines on my 914 and i'm a bit stumped.. I got a set of braided flex lines that are fitting up fine on the back but on the front ..... not so much....
I'm runnging 911T struts and the hole for the flex line to go through is too small. I tried the remains of my original rubber flex line and it too does not fit. The tab on the strut does not look to have enough material to enarge the hole to fit the flex line. Has anyone else come accross this ?? Do i need to use 911 flex lines?? On side note.. I have a pair of braided front 914 flex lines if someone needs them.. Thanks! |
MrHyde |
Mar 17 2013, 02:56 PM
nevermind... sorted it out......
ldsgeek |
Mar 17 2013, 06:12 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
You can't fix a posted problem without also posting details. Come on, we need to know how you did it. Oh, BTW
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
MrHyde |
Mar 17 2013, 06:52 PM
Meh... I used my dremel tool and opened up the holes .. :-)
911 flex lines don't have the same fittings as 914 so thats what needed to be done. |
Eric_Shea |
Mar 17 2013, 07:06 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
It has a different "U" shaped attachment that goes on the hard line side.
Griffinroydonald |
Mar 18 2013, 02:15 PM
Newbie Group: Members Posts: 49 Joined: 21-January 10 From: Kings Mtn N.C. Member No.: 11,274 Region Association: None |
Very Nice picture for the thread. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 26th December 2024 - 12:42 PM |
