> Broken Clips, Whats the best glue?
ezbngreen914
post Mar 18 2013, 09:27 AM
I seem to be suffering from broken clips syndrome. I broke one of my trunk targa top clips a week or two ago and I just found that the clip that holds the rain tray drain/spring break beer funnel in place is also broken. Any recommendations on what glue to use to dry to get these back together? I tried epoxy on the targa clip but I think the break was to clean and the epoxy didn't have anything to "grab" on to. Wandering if model glue, the type that fuses the plastic together, would work better. Any suggestions would be great! or maybe I'm the only one this has happened to... (IMG:style_emoticons/default/lol-2.gif)
SLITS
post Mar 18 2013, 09:30 AM
"This Utah shit is HARSH!"
ACE or other hardware stores will carry "plastic glue". It works sometimes.
Replacement is better solution.
JawjaPorsche
post Mar 18 2013, 10:52 AM
One of my funnel clip tab was broken too so I swapped the right side clip for left side. The clip has tabs on both sides.
Auto Atlanta sells the roof holder:
http://www.autoatlanta.com/Porsche-Reprodu...1455921910.html
Katmanken
post Mar 18 2013, 04:49 PM
You haven't seen me if anybody asks...
Just by a new one and avoid the cost of buying a bunch of glues that won't work well for this application. The material itself is a slick plastic which is difficult to glue, and the part is probably old and brittle.
The next break is usually right across the glue line for one of two reasons. First, glues are almost never stronger than the material being glued so the softer glue line is a natural break point. Two, glue doesn't stick well to certain types of plastic (like this one) and the glue separates from the plastic.
914itis
post Mar 18 2013, 05:04 PM
QUOTE(ezbngreen914 @ Mar 18 2013, 11:27 AM) *
Pm me your address and I will send you a targa clip holder.
Dave_Darling
post Mar 18 2013, 08:18 PM
914 Idiot
Yep, doesn't matter what glue you use--none of them will work for those.
--DD
McMark
post Mar 18 2013, 08:41 PM
914 Freak!
Yup. (IMG:style_emoticons/default/agree.gif) Dave Darling has it right. You can glue it as long as you put the finished product in a glass case and never touch it. (IMG:style_emoticons/default/biggrin.gif)
Mikey914
post Mar 19 2013, 12:44 AM
The rubber man
There is a special plastic repair kit that uses a powder and CA (superglue) to bond plastics and fill.
I've been told you can use baking soda as a filler with CA, but haven't tried it. Give it a shot. The color will even be about the same.
If you need a new upper clip I do have them, but I'm betting you won't need it.
-mark
ezbngreen914
post Mar 19 2013, 07:29 AM
QUOTE(914itis @ Mar 18 2013, 05:04 PM) *
PM Sent
ezbngreen914
post Mar 19 2013, 07:41 AM
QUOTE(McMark @ Mar 18 2013, 08:41 PM) *
So, I guess my next question is where can I get a Targa Clip sized glass case...? (IMG:style_emoticons/default/lol-2.gif)
I swear that when the clip broke after the first time I glued it, it sounded like it was laughing at me!
914itis
post Mar 19 2013, 08:08 AM
QUOTE(ezbngreen914 @ Mar 19 2013, 09:29 AM) *
PM Sent
Got it!
Will be out in the mail this week.
ezbngreen914
post Mar 19 2013, 08:21 AM
QUOTE(914itis @ Mar 19 2013, 08:08 AM) *
PM Sent
Got it!
Thanks!!! (IMG:style_emoticons/default/beerchug.gif) Thats Awesome!
Katmanken
post Mar 19 2013, 06:35 PM
QUOTE(Mikey914 @ Mar 19 2013, 02:44 AM) *
-mark
Hey Mark,
Baking soda is not a filler, it's a kicker that sets CA up quickly.
Squirt CA on the table, mix in some baking soda and that mix will foam and bubble and release a lot of heat. You end up with a CA foam that's not real strong.
Somebody has been making a fortune for years selling baking soda in water as a CA "Accelerator" at the hobby stores.
Montreal914
post Mar 19 2013, 07:14 PM
White Targa clip in front of the trunk?
914 Rubber has them for $6, good deal vs AA at $20
Mikey914
post Mar 20 2013, 06:29 AM
The rubber man
Yeah, The kicker i I didn't even make them. They are OEM.
- Lo-Fi Version Time is now: 26th December 2024 - 06:59 AM
