Temp heat for painting |
Mar 21 2013, 07:28 PM
Custom Member Group: Members Posts: 24,658 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Has anyone used a radiant heater for painting in the cold weather?
My current options are a wood stove or a salamander heater. Those both have open flames, so I think that might be a bad thing. Any suggestions aside from waiting? I need to repair and paint a car prior to Hershey and it won't be a stable temp until may in my area.... Rich |
Mar 21 2013, 07:39 PM
Oh, I might have access to a heated paint booth.
So one more question. With a typical 2 stage paint job...how long before I can safely trailer the car back to my place? |
914GT |
Mar 21 2013, 09:38 PM
Senior Member Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Polyurethane clears are no longer sticky after 2-3 hours at room temperature, but still quite soft. If I were you I would give it overnight before trying to move it, and then be very careful getting it onto a trailer.
pete-stevers |
Mar 21 2013, 11:08 PM
saved from fire! Group: Members Posts: 2,645 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
paint + cold = runs
bulitt |
Mar 22 2013, 04:05 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I will throw this up for you to read until Scotty and the other experts wake up and chime in. The hardeners or catalyst for your paint can be tailored to the temperature. So you should ask the supplier what ranges they can provide. I'm guessing high 60's in your garage would be the minimum.
rick 918-S |
Mar 22 2013, 08:41 AM
Hey nice rack! -Celette Group: Members Posts: 20,825 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Missed your call last night. I was setting up at the World of Wheels car show. Use the booth. Even if you have to pay for it. Yes you can get solvents of cool weather but unless your a seasoned painter you will not know how to adjust your painting technic for the temp. I painted dozens of cars in a garage when I was a young guy with a oil furnace sitting in the corner running full blast. Dumb? Lucky? you decide..
914GT |
Mar 22 2013, 08:53 AM
The paints I use, 65F is about a low as you can go and be in the recommended range of the reducers and activators. Going much below that you run into problems with the paints not flashing quick enough between coats. When painting a car you want as many things going in your favor as possible, and try to control the variables. IMO with the high prices for good paints now days you don't want to take any more risk then you have to.
brant |
Mar 22 2013, 09:00 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
those salamander burners throw a lot of fumes and unburned kerosene
I once had fish eye on a garage job attempt, that I am certain came from the heater |
Mar 22 2013, 04:53 PM
Missed your call last night. I was setting up at the World of Wheels car show. Use the booth. Even if you have to pay for it. Yes you can get solvents of cool weather but unless your a seasoned painter you will not know how to adjust your painting technic for the temp. I painted dozens of cars in a garage when I was a young guy with a oil furnace sitting in the corner running full blast. Dumb? Lucky? you decide.. dude, Forget about my issue, what are you doing at World of Wheels? Pic of the booth.... rich |
76-914 |
Mar 22 2013, 05:15 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/poke.gif) It's a proven fact that fish eye has never been the result of any painters action. (IMG:style_emoticons/default/bootyshake.gif) Hi Brant. (IMG:style_emoticons/default/biggrin.gif)
scotty b |
Mar 22 2013, 08:40 PM
Missed your call last night. I was setting up at the World of Wheels car show. Use the booth. Even if you have to pay for it. Yes you can get solvents of cool weather but unless your a seasoned painter you will not know how to adjust your painting technic for the temp. I painted dozens of cars in a garage when I was a young guy with a oil furnace sitting in the corner running full blast. Dumb? Lucky? you decide.. (IMG:style_emoticons/default/agree.gif) Unless you have been doing this for a while and know how to manipulate the hardeners, thinners etc. cold weather painting can be just as much a PITA as hot weather. As far as dumb luck, I have never had a heated booth, and when I did have a shop with good heat, as soon as the booth is turned on, that 70 deg room goes to 50deg QUICKLY. I currently put a salamander about 3 feet from the doors when I paint now, and have in the past had a small one right in the booth with me. Granted, I did have a booth, so airflow was constant, and the fumes got pulled away from the heater,not just stagnant in the room, but I never saw the heater flame up a bit. Temp wise, 70-80 with as low humidity as possible is ideal, but I have RARELY had ideal conditions, and I doubt most outside of So-Cal have |
Mar 25 2013, 05:57 PM
Found a new painter to do it for me (IMG:style_emoticons/default/smile.gif)
Best solution for me and my limited time right now. I am happy. rich |
Lo-Fi Version | Time is now: 26th December 2024 - 07:14 AM |
