Stranded by a wheel lock - can anyone identify these?, Got Them Off!!! Thanks Cap'n!! |
infraredcalvin |
Mar 24 2013, 10:58 PM
Distracted Member Group: Members Posts: 1,552 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I wonder if at least 2 pins will line up and allow for enough torque to get the lock off? They look press fit should be able to pull out pins. I'd be happy to donate my key if it might help...
carr914 |
Mar 24 2013, 11:12 PM
Racer from Birth Group: Members Posts: 121,083 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
My Pins don't look pressed in, but made as one piece with the Key
Cap'n Krusty |
Mar 24 2013, 11:20 PM
Well, here I am again. Maybe some of you aren't clear on the concept of theft prevention through the use of wheel locks. There are literally DOZENS of different pin configurations, maybe more. The hardened pins are set in aluminum keys. The improved version features a 3rd piece which attempts to hold the key snug to the lock. The "fix" was only marginally successful; the pins still sheared or popped out of the overstressed holes in the soft aluminum of either the lock or the key. If 6 pins, or even more, can't hold up under the torquing or loosening process, why would you EVER think two would? I speak from experience, a deep hole saw is going to do it, and all other attempts are simply going to complicate removal down the road. Using a punch is just going to distort the aluminum and make it even more resistant to removal.
Have fun. Most tool stores sell a nice set of hole saws in a handy dandy little cardboard box. I think you need a 9/16ths or 5/8ths cutter. The Cap'n |
Scott S |
Mar 24 2013, 11:32 PM
Small Member Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
*sigh*
Thanks all for the comments. Cap'n, once I drill the locks, what do I use to remove the remaining sleeve that will be left on the stud? Thanks Again - Scott S |
a914622 |
Mar 25 2013, 08:35 AM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Hang on hang on. Before you go banging on it like a monkey with a hammer. (IMG:style_emoticons/default/blink.gif) Take some clay or wax and make an impression. Take that to a machine shop in your area and see if they can make you a key. I did a few of them back in the 80s that way. I also made a set for my 2.0 fuchs that were bolts.
I would make a key because you probably have 3 more locks? With out a key I would try the over tork methed , before moving on. Vanagon rear nuts are steel. If you are going to drill, Drill the stud! start with a 1/4 dia and go bigger from there. Studs are cheap and easy to replace. Use a center drill to start and take your time. good luck |
DBCooper |
Mar 25 2013, 09:43 AM
Don't worry Cap'n, throw up your hands and walk away... they'll figure it out.
Just a note, I'd be willing to bet that lock is a lot softer metal and easier to drill than the stud. Check your options. If they have a perfect pattern to work from it would be easy for a machine shop to put hardened pins into a steel hex bar that size, but I'd also bet the cost and time would be a lot more than a hole drill and/or a new stud. |
pcar916 |
Mar 25 2013, 09:49 AM
I have this set (used on the 911) and never had any problem with it over a lot of years. But it's only for those that stick carefully to the proper torque and I always put some grease on the mating surfaces just like on the other lug nuts. Here's mine.
To get another key I remember that I would've had to call the company with my code to get another one made. It was (of course) a lockable glove box or hidden thing. The sleeve simply unscrews from the stud, and my pins are definitely pressed into the key. Just remembered that I believe Rich Bontempi (High Performance House, Redwood City, California) sold me this set and might remember the manufacturer if that helps. |
sixnotfour |
Mar 25 2013, 10:32 AM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
How NOT to do it..
Scott S |
Mar 25 2013, 11:46 AM
I have this set (used on the 911) and never had any problem with it over a lot of years. But it's only for those that stick carefully to the proper torque and I always put some grease on the mating surfaces just like on the other lug nuts. Here's mine. To get another key I remember that I would've had to call the company with my code to get another one made. It was (of course) a lockable glove box or hidden thing. The sleeve simply unscrews from the stud, and my pins are definitely pressed into the key. Just remembered that I believe Rich Bontempi (High Performance House, Redwood City, California) sold me this set and might remember the manufacturer if that helps. I was poking at them a bit this morning - I am surprised at how soft they are. I brought one of the "fake" lug nuts with me to work today and will be heading over to pick up a hole saw at lunch. The Cap'n has steered me through other issues, so my trust level is huge (it is my talent level with a hole saw that is very concerning!). One last question - per your picture Pcar916, how does the system work? I obviously see the lock and the key - what is that threaded sleave used for? Thansk again all - Scott S |
Spoke |
Mar 25 2013, 12:18 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
If the 2 holes are too far apart, maybe drill 2 holes in the base?
rgalla9146 |
Mar 25 2013, 02:06 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If the 2 holes are too far apart, maybe drill 2 holes in the base? The Cap'n is tellin you true. Get a hole saw that just fits over the stud, remove the guide drill by loosening the set screw on the side of the tool. Let the stud guide the hole saw. Watch carefully. You will be detaching the cup part of the nut. That is what holds the wheel tightly to the flange. I've used this method since the early '80s. It works and it is EASY. With care it will not damage the wheel. It is very effective on Porsche brand wheel locks which are aluminum. If your lock is steel it should work but will take longer. I'm glad to see others know of it as well. It is effective and does no damage. No need to re-invent the wheel. |
IronHillRestorations |
Mar 25 2013, 04:55 PM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Have you called the guy that sold you the car?
Mar 25 2013, 05:34 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would suggest going to Harbor frieght and getting a set of bent end needle nose pliers...
Use a torch to bend them right, and a grinder to get the pins right...they try to get it loose with those. I am not a great fan of using a hole saw in that situation. Make/borrow a key from someone and make the pattern correct for yours, then use that. Rich |
euro911 |
Mar 25 2013, 05:35 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
The hole saw method sounds good if you can't fine the 'key' laying around somewhere.
I had to make a tool similar to that (for removing some 'tamper-proof' screws on a real old fire alarm water flow sensor), but it only had two pins and no torque to speak of. We replaced the funky screws with Phillips type screws. |
Dr Evil |
Mar 25 2013, 06:15 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I would drill and tap several holes and then put some fasteners in it with something that can turn them. Might be as fast as a hole saw, though.
Cap'n Krusty |
Mar 25 2013, 07:09 PM
The threaded sleeve was a design change meant to hold the key snugly against the lock in an attempt to prolong the life of the setup. It kinda works, but not if the lock is overtightened. I think 50 ft/lbs is the recommended torque.
The Cap'n |
Dr Evil |
Mar 25 2013, 07:20 PM
90ft/lb is standard for the lug nuts. Is the lock nut different?
Steve |
Mar 25 2013, 07:58 PM
914 Guru Group: Members Posts: 5,687 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I had the same set years ago. I bought them from Automotion when they were in Santa Clara. The torque was 50 pounds. I remember taking my car to Otto's years later and the first thing he did was take them off and throw them away. He then installed the Porsche wheel locks. Another fond memory of the no bull shift style of JW.
pcar916 |
Mar 25 2013, 08:00 PM
What is the threaded sleeve for? The Cap'n got the parts right. The sleeve (threaded on the inside, smooth on the outside) fits into the smooth bore of the "key". In other words; The "key", which looks like a lug nut has a smooth bore that the sleeve fits into. The whole assembly gets screwed into place driving the small, ring tight onto the wheel. The little rings are radius'd just like the lug nuts. Torque? I always torqued them to the same spec as the other lug nuts... didn't see any instructions otherwise. The separate stud covers didn't need to be torqued to anywhere near that. Then you removed the sleeve by itself, pull off the key, and screw on a cover that goes over the stud and the pin holes, and makes it look like the other lug nuts. Those stud covers aren't shown in my picture but like the rest, there is one per wheel. The only parts in your glove box are the key and sleeve. It's a lot of parts but is a much more solid fastening system than some of the others I've seen. |
Steve |
Mar 25 2013, 08:04 PM
The threaded sleeve helped hold the key in place, to help prevent the pins from being sheared off. That's another reason the torque value was 50 pounds to also help prevent the pins from being sheared off. I also had problems with the pins falling out of the key.
Lo-Fi Version | Time is now: 27th September 2024 - 06:24 PM |
