New Rear Mirror Replacement |
Kaduku |
Apr 23 2013, 01:18 PM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
I was just about to pull the trigger on a new rear mirror replacement, but I just found out that you just can't hank the old one off without breaking the windshield.
Anyone successful in replacing their mirror without damaging your windshield? |
7TPorsh |
Apr 23 2013, 01:35 PM
heat up the area with a hair dryer. then use a wire or guitar string to pry off the base
Kaduku |
Apr 23 2013, 01:51 PM
7TPorsh |
Apr 23 2013, 01:57 PM
I did but not on my 914. I changed the glass on my teener so never had to.
I went with the BMW replacement so the new mirror is not glued... |
DBCooper |
Apr 23 2013, 02:01 PM
I've done it that way, several times. I use a single edged razor to loosen all around the pad glue once it's hot. You can get it pretty hot but don't overheat the glass, you can discolor the plastic safety layer.
Joe Owensby |
Apr 23 2013, 05:15 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I did this. I used the heat gun to heat the metal piece instead of the glass. Then used a gentle pry to get it off the window. JoeO
Kaduku |
Apr 23 2013, 05:21 PM
JawjaPorsche |
Apr 23 2013, 05:42 PM
What is funny is there was recall on the mirrors because they would fall off the glass without warning. Mine did!
I went with the BMW mirror that screws into the sun visor holes when I replaced my windshield last fall. |
kwlane |
Apr 23 2013, 11:00 PM
Member Group: Members Posts: 91 Joined: 9-February 12 From: Newcastle, WA Member No.: 14,108 Region Association: Pacific Northwest |
Where can one get the BMW mirror? My project car's mirror is not on the windshield so rather not have to deal with getting it back on.
Kaduku |
Apr 23 2013, 11:08 PM
JawjaPorsche |
Apr 24 2013, 04:24 AM
Where can one get the BMW mirror? My project car's mirror is not on the windshield so rather not have to deal with getting it back on. Here is link http://www.ebay.com/itm/Porsche-914-interi...440&vxp=mtr |
DBCooper |
Apr 24 2013, 11:48 AM
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me.
Madswede |
Apr 24 2013, 04:09 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me. This is my concern, as I'm on the tallish side. I'm going to order one just to try it out anyway. I suppose if I don't like it, I'll either re-sell it at a swap meet someday, or have someone cut a length of the arm off and re-weld it closer to the bracket or something. But then it might look a bit too funky. We'll see. |
JawjaPorsche |
Apr 24 2013, 04:13 PM
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me. This is my concern, as I'm on the tallish side. I'm going to order one just to try it out anyway. I suppose if I don't like it, I'll either re-sell it at a swap meet someday, or have someone cut a length of the arm off and re-weld it closer to the bracket or something. But then it might look a bit too funky. We'll see. The seller makes them. Contact him to see if he has a shorter arm. One word of caution, a shorter arm might interfere with your sunvisors. Just letting you know. |
andys |
Apr 24 2013, 04:29 PM
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me. This is my concern, as I'm on the tallish side. I'm going to order one just to try it out anyway. I suppose if I don't like it, I'll either re-sell it at a swap meet someday, or have someone cut a length of the arm off and re-weld it closer to the bracket or something. But then it might look a bit too funky. We'll see. I installed the BMW mirror, and I find it is at its upward tilt adjustment limit which is not quite enough to see very far behind......I find myself ducking down just a bit to get a better view. I might try shimming the mounting base. I'm only 5'9", so I can imagine a taller driver would have an issue with this. Andys |
Kaduku |
Apr 24 2013, 04:52 PM
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me. This is my concern, as I'm on the tallish side. I'm going to order one just to try it out anyway. I suppose if I don't like it, I'll either re-sell it at a swap meet someday, or have someone cut a length of the arm off and re-weld it closer to the bracket or something. But then it might look a bit too funky. We'll see. I installed the BMW mirror, and I find it is at its upward tilt adjustment limit which is not quite enough to see very far behind......I find myself ducking down just a bit to get a better view. I might try shimming the mounting base. I'm only 5'9", so I can imagine a taller driver would have an issue with this. Andys I am not surprise with these replies. When I first saw these on eBay, I tried to imagine how they would look like while I was seated in the car. In my case though, I am very short so the higher position on the windshield was obviously going to be a problem for me. |
Kaduku |
Apr 24 2013, 04:53 PM
DBCooper |
Apr 24 2013, 06:34 PM
Well mine isn't THAT bad. It's lot better than the standard 914 mirror, just not quite perfect. For me.
Madswede |
Apr 24 2013, 09:47 PM
The seller makes them. Contact him to see if he has a shorter arm. One word of caution, a shorter arm might interfere with your sunvisors. Just letting you know. Thanks for the info, I'll contact the seller. I'm leaving the sun visors off, so that shouldn't be a problem. I'm a shade under 6'3" tall, so as it turns out I never really use the sun visors anyway - they tend to block the road ahead. I'll check back in if/when I get something installed. |
kwlane |
Apr 24 2013, 10:06 PM
Thanks for the link, I'm 6'2" and also don't use the visors. A shim would be easy to install.
Lo-Fi Version | Time is now: 2nd January 2025 - 06:13 PM |
