DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Need an early style cable window regulator, driver's side. It's getting warmer so not that urgent any more, but I'd still lke to get hat window to stay up.
Thanks |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
If you could tell me how to remove those without removing the triangle side window I would probably GIVE you one.
Stu |
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
The triangle side window is simple to remove.
Remove the two 10mm bolts right under the triangle window. Take a 13mm and loosen the lock bolt (on the adjuster screw)at the base of the triangle window/front door glass bracket (all the way down under the bottom of the door. Screw the adjuster bolt in with a straight head screwdriver (count the turns). Now you can gently pull the triangle window up - loosen the seal as you pull it. Pull the window up so you can see the adjuster screw in the door. Reach in and remove the adjuster screw. Now the triangle window and bracket can come out of the door. Probably only have to move it forward so it clears the window crank mechanism. |
DBCooper |
Wow, Bob, you're fast, thanks. Yes, Stu, what HE said. I could sure use that regulator. I'll send you a PM.
Thanks |
DBCooper |
Found one, thanks.
Lo-Fi Version | Time is now: 26th June 2024 - 04:50 AM |
