Drop Valve Seat, How do you know? |
newto914s |
Nov 24 2004, 04:21 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
I was headed to the folks house for Thanksgiving. Stopped to get some gas(200 miles in) and when I stared it up it sounded like something was stuck in the fan or air passagess bouncing around. I shut it down, checked the oil and the pressure was pressure was ok. So I drove it the rest of the way home(about 50 miles).
The noise only came back when I was at idle up to around 1500 rmp. Above that everything was fine. Would the car still run with a dropped valve seat? How can I check if I dropped one? And is their anyway to check the air passages with out dropping the engine? Thanks guys, I've got my fingers crossed (IMG:style_emoticons/default/unsure.gif) Samson |
mike_the_man |
Nov 24 2004, 04:28 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I think a dropped valve seat would sound much worse. There are some pics at Pelican of a dropped valve seat. It blew out the top of the case. At the very least, your car would run like crap. More likely that something came loose and is rattling around somewhere under the tin.
Root_Werks |
Nov 24 2004, 04:31 PM
Village Idiot Group: Members Posts: 8,416 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
QUOTE(mike_the_man @ Nov 24 2004, 02:28 PM) I think a dropped valve seat would sound much worse. There are some pics at Pelican of a dropped valve seat. It blew out the top of the case. At the very least, your car would run like crap. More likely that something came loose and is rattling around somewhere under the tin. (IMG:style_emoticons/default/agree.gif) If you haven't lost any power, you are probably okay. Did something "crawl" into the cooling fan while you were getting gas? Maybe something fell off and got sucked in? (IMG:style_emoticons/default/idea.gif) |
Joe Ricard |
Beginnings of an exhaust leak. When it cools down make a deal withthe devil and check the exhaust nuts.
I would also pull the valve covers and check to see if everything is correct and tight. |
joea9146 |
Nov 24 2004, 04:32 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
Most Valve seat problems are on the 2.0 heads is that what you have.
A leakdown test should reveal if the seat has dropped. Sure its not a rod knock you are hearing. (IMG:style_emoticons/default/ohmy.gif) |
aircooledboy |
Nov 24 2004, 04:34 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
If the valve seat is dropped, you'll know because when the valve goes to sit down, it's ass will hit the floor. (IMG:style_emoticons/default/lol2.gif)
It sounds to me like maybe you sucked something into the fan housing. You would check by reaching into the center of the fan hub (with the car OFF) and maybe even by pulling off the heater ducting part where it attaches to the fan housing and see if there is something in there, I guess. I have had my alternator cover thingy sucked into the fan a couple times, and it sounded like what you described. I've never had a dropped seat, but I'm pretty sure it would make you car run a whole bunch worse than you've described. Sorry about the smart ass comment, sometimes i just can't help myself. (IMG:style_emoticons/default/happy11.gif) |
TheCabinetmaker |
Nov 24 2004, 04:36 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
QUOTE(Joe Ricard @ Nov 24 2004, 04:31 PM) Beginnings of an exhaust leak. When it cools down make a deal withthe devil and check the exhaust nuts. I would also pull the valve covers and check to see if everything is correct and tight. (IMG:style_emoticons/default/agree.gif) Exaust leak. Dropped valve seats will cause very poor performance or even a no run. I doubt you be able to drive a car 50 miles with a dropped seat. You would destroy a piston long before that, and have engine parts all over the road. |
914werke |
Nov 24 2004, 04:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,534 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I actually had a EX valve "head" in my 1.7 snap off and embed itself in the piston crown once.
Made a horrible racket while driving on the freeway, so I clutched in killed coasted off the freewaythen chked everything and then started up agian. It ran rough, there was audible knocking but it ran! (IMG:style_emoticons/default/blink.gif) When I took it all apart the valve head had broken into multiple pieces, tore the hell out of the head and piston then largest part emmbeded itself into the piston and was contacting the head on the upstroke. The rest of the valve head I found in the exhaust. (IMG:style_emoticons/default/sad.gif) |
Rhodes71/914 |
Nov 24 2004, 04:40 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I would agree with the above prolly not a dropped seat. I had one work it's way out but not come all the way. I knew it happened because I could here the piston hitting it. Somehow it fixed its self (good thing I was in the middle of the Alcan. Eventually happened again in downtown Seattle. When I took the head off there was a nice half moon indentation in the top of the piston. The engine had serious loss of power.
Sounds like something may have gotten in the fan housing. Did ya leave any tool in there when you were getting ready for your trip? |
newto914s |
Nov 24 2004, 04:44 PM
That's what I would have figured. I checked that pelican artical before posting (IMG:style_emoticons/default/icon8.gif) and those pictures are scary. I'll check the exhaust nuts and under the valve cover right now. Is there anyway to get into to the air ducts too?
About power it does drive fine, but when it's in that idle range when the noise starts the car bogs(like it's pulling something through the fan) and will stall if I don't give it gas. Oh, also according to some peckerhead at the gas station it was making the noise before I shut it down( I had the radio turned up) |
mattillac |
Nov 24 2004, 04:49 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
QUOTE(joea9146 @ Nov 24 2004, 02:32 PM) Sure its not a rod knock you are hearing. (IMG:style_emoticons/default/ohmy.gif) speaking of rod knocks, is it possible to have an "occasional" rod knock? i hear it usually when idling and at part throttle, but it goes away sometimes?! (IMG:style_emoticons/default/blink.gif) any ideas? |
TheCabinetmaker |
Nov 24 2004, 05:01 PM
Matt, a knocking sound that goes away, especially after warm up, is an indication of a "loose" valve seat. The seat has not came out, but is a little loose when cold, and could tighten up when warm. Could also be an exhaust leak. I could be wrong, but I don't think a rod knock will go away.
mattillac |
Nov 24 2004, 05:12 PM
i didn't think a rod knock would go away, but thats what it sounds like. a loose valve seat doesn't sound good. am i looking at some major repairs, new heads? or is this something that a competent machinist could take care of? my pop is an excellent machinist, and he could probably do any headwork i need for free.
SLITS |
Nov 24 2004, 05:23 PM
I dropped seats in two engines. First one, no sound of impending doom - just wound it up and bam, the engine siezed. Second one sounded like a BB in a tin can. Came and went. Then one day it went. Drove another 150 miles home missing on one cylinder - trashed the head badly.
Your guess is as good as the others! |
Allan |
Nov 24 2004, 05:37 PM
QUOTE(SLITS @ Nov 24 2004, 03:23 PM) I dropped seats in two engines. (Mine was a Datsun) First one, no sound of impending doom - just wound it up and bam, the engine siezed. Second one sounded like a BB in a tin can. Came and went. Then one day it went. Drove another 150 miles home missing on one cylinder - trashed the head badly. Your guess is as good as the others! What he said. I think. |
Allan |
Nov 24 2004, 05:38 PM
OOps! Hey Slits, the Datsun thing was mine. Just didn't know how to edit. Sorry. (IMG:style_emoticons/default/biggrin.gif)
mattillac |
Nov 24 2004, 05:39 PM
what's the best way to take care of the valve seat before i drop it and completely
ruin my motor, assuming that the valve seat is the problem. (IMG:style_emoticons/default/idea.gif) |
d7n7master |
Nov 24 2004, 06:17 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
That pretty much nails how my engine sounded over about two weeks or so of daily driving. During this time, never did it knock on cold start. Drove to work/came home.
A slight knock at idle @ operating temp. No knock at cruise speeds. Then I stopped one day on the way home & when I started it up again (about 10mins later) it started right up & KNOCKED HARD (read SCARY!!!) knock on startup. Teardown:#3 is smoked. (IMG:style_emoticons/default/barf.gif) I'll post pics comin' up. |
mattillac |
Nov 24 2004, 06:25 PM
now i'm starting to worry. i really dont want to have to do any major repairs when
i'm just now getting ready to get my 914 back on the road. i'd rather take care of this problem before i drop a seat. recommendations for repairs? should i plant on just rebuilding both of the heads to prevent this? what parts can i reuse if any? or should i just stick with all new parts as long as i'm doing a head rebuild? |
SLITS |
Nov 24 2004, 06:28 PM
Take the valve cover off and see if any of the valves have tightened up or see if one is really loose.
Other than that 1.) a leakdown test and 2.) Pull the suspect head |
Lo-Fi Version | Time is now: 21st September 2024 - 06:49 PM |
