moparrob |
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None ![]() |
So I decided I want a new sweatshirt and figured it would be cool (to me) to have an image of a Weber 40 IDA 3C carb on it, of which two reside on my 3.0 litre engine in my six conversion:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1367806864.1.jpg) So I dug around the internet and could not find any for sale, but I did find a stock exploded view - but of low quality. (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1367806864.2.jpg) I guess I would settle for that, but no one makes that either , as far as I can tell. Does anyone have any suggestions where to buy one, or how to have one made? I have seen custom sweatshirt sites but you would need to have a high(er) res image to send them, which I can't seem to find. Doesn't one of our member make t-shirts? Perhaps he can be bribed/persuaded to do a run? Any help is greatly appreciated. |
moparrob |
I'm going to have this one made up, but I was hoping for something a bit more, um, dramatic? Bolder?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1367807684.1.jpg) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
moparrob |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler.
That's about it. Should be good for 200 HP. |
Mark Henry |
Sounds nice, those carbs must have cost you but at least you can bolt those puppies on and forget about it.
do you know what emulsion tubes and venturi's you are running? |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Should be a nice runner. The SC cams and P/C don't allow you to run as wild a cam, though I've heard that a 964 grind is better without swapping out the pistons.
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,542 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Should be a nice runner. The SC cams and P/C don't allow you to run as wild a cam, though I've heard that a 964 grind is better without swapping out the pistons. I was going to mention the same thing. Kind of like how an SC cam works better on a 2.7 that still has the old P/C in there. Maybe he's saving up that couple hundred for a future all-out rebuild? BTW that engine looks really nice! |
GeorgeRud |
I guess I'm old school, but I think these engines always look best with the Weber carbs or the MFI system on board. I love the drivability of modern EFI systems, but they just don't look as nice (well, maybe the PMO system is still quite nice!).
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. 200 seems like a low guess ???... nice work BTW (IMG:style_emoticons/default/smile.gif) maybe group buy in the shirts im in |
Mark Henry |
Crap I was thinking mine was going to be just over 200hp...I might be off a bit...
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,928 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
I bought this design in a t-shirt version, but you can buy a sweatshirt.
![]() http://www.cafepress.com/+hooded_sweatshirt,237708554 |
moparrob |
I bought this design in a t-shirt version, but you can buy a sweatshirt. ![]() http://www.cafepress.com/+hooded_sweatshirt,237708554 Thanks, I did see that one in my search but the image is actually on the back - not the front. Also, I would like something a bit more 'realistic' if possible. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,713 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,402 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke |
moparrob |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke Sorry about the delayed response guys - work has been busy.. Specs: 34 Main Venturies, 140 Main Jet, 160 Air Correction Jet, 60 Idle Jet, F3 emulsion tubes Talk to perry@qsnap.com for a custom wiring loom. He helped me to bypass my old relay panel and built a custom loom for the new distributor and MSD box. Awesome work! |
rgalla9146 |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke Sorry about the delayed response guys - work has been busy.. Specs: 34 Main Venturies, 140 Main Jet, 160 Air Correction Jet, 60 Idle Jet, F3 emulsion tubes Talk to perry@qsnap.com for a custom wiring loom. He helped me to bypass my old relay panel and built a custom loom for the new distributor and MSD box. Awesome work! Thank you for the specs. Can you tell us ( I assume you've driven the car ) if there were adjustments to the carbs after driving it initally ? I'm not asking about mixture or balance but rather any jet changes, emulsions venturies etc. I ask because Bruce Anderson (RIP) specs 160 mains and 175 air corrections as a startup. Were changes done as a result of dyno tuning ? TIA Rory |
patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Are you me? Almost exact same thing here except with an '81 SC 3.0L. Recurved with Barry, Paul cleaned up my 40IDA3C carbs, headers from MSDS, oil cooler conversion from Rich Johnson. I swapped the Bosch ignition for a MSD. Just waiting for my 2nd garage to be built (foundation/driveway poured this past week) and I'll have the room to start the conversion - everything else is ready to go! |
moparrob |
QUOTE Sorry about the delayed response guys - work has been busy.. Specs: 34 Main Venturies, 140 Main Jet, 160 Air Correction Jet, 60 Idle Jet, F3 emulsion tubes Talk to perry@qsnap.com for a custom wiring loom. He helped me to bypass my old relay panel and built a custom loom for the new distributor and MSD box. Awesome work! QUOTE Thank you for the specs. Can you tell us ( I assume you've driven the car ) if there were adjustments to the carbs after driving it initally ? I'm not asking about mixture or balance but rather any jet changes, emulsions venturies etc. I ask because Bruce Anderson (RIP) specs 160 mains and 175 air corrections as a startup. Were changes done as a result of dyno tuning ? TIA Rory Unfortunately the engine has not yet been installed. Hopefully that will happen this summer as I may have found someone to help me get it to the finish line.... |
Mark Henry |
stock 1978 large port 3.0, upgraded turbo cam chain tensioners, stripped the fuel injection, added refurbished Weber 40 IDA 3C carbs (thanks to Paul at Performance Oriented), Barry Hershon rebuilt/re-curved distributor distributor, stock cams (for now), ceramic coated conversion headers from Marty at MSDS, liberal dose of powder coating, conversion oil cooler. That's about it. Should be good for 200 HP. Hi Hate to pile on but please provide as much carb info as possible. Venturies, jets, emulsions, air corrections and anything else you can think of. Thank you Rory I second that.. I'm in the same spot as Rory over here.. 83 3.0 with Weber 40's going into my brothers 914.. Plus any other things that you came across as a possible issue.. like wire harness or ignition. I'm aware of the clutch problem fitting onto a 901.. Got a PMS flywheel/disc kit coming. TIA, Luke Sorry about the delayed response guys - work has been busy.. Specs: 34 Main Venturies, 140 Main Jet, 160 Air Correction Jet, 60 Idle Jet, F3 emulsion tubes Talk to perry@qsnap.com for a custom wiring loom. He helped me to bypass my old relay panel and built a custom loom for the new distributor and MSD box. Awesome work! Thank you for the specs. Can you tell us ( I assume you've driven the car ) if there were adjustments to the carbs after driving it initally ? I'm not asking about mixture or balance but rather any jet changes, emulsions venturies etc. I ask because Bruce Anderson (RIP) specs 160 mains and 175 air corrections as a startup. Were changes done as a result of dyno tuning ? TIA Rory This jet info is OK to know as a baseline, but be sure that till you have actually tuned the carbs you will not know it's exact jetting requirements. Every engine will have different jetting requirements. I used this info to buy 34mm vents and F3 emulsion tubes (and rebuild kits) today. I'll be using a wide band to tune my carbs, with my WB and jet reamer kit I'll make my own jets. That said the Performance Oriented guesstimate on jetting comes from a lot of experience and I bet will be damn close. |
Lo-Fi Version | Time is now: 2nd March 2025 - 07:20 PM |
