Still a miss at 4,000 RPM..., Backfiring at WOT, even with all new ignition components |
May 29 2013, 08:13 PM
Custom Member Group: Members Posts: 24,638 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
This is a 1.7 liter motor?
904svo |
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Have you check your linkage to make sure both carburetors have the same travel?
What you describing is what happens when one carburetor is opening more than the other. To check this measure the distance from the throttle shaft to where the ball joint is connected they should be the same. |
May 29 2013, 08:15 PM
I asked in the other thread, post a pic of the linkage, or a few |
With those specs on a 1.7 you are not starved for fuel.
ThePaintedMan |
May 29 2013, 08:27 PM
Ack! So many questions, which really makes me happy... I'm just having a hard time keeping up.
Yes, I agree that my jetting settings should be more than adequate for a 1.7, based off of Tomlinson's Weber Manual tables.... that is, assuming it actually is a 1.7 and not some rebuilt monster (IMG:style_emoticons/default/smile.gif) In my dreams, right? The linkage is a Tangerine Racing cable setup, which I am really happy with. From every indication I have, it is synched... it's really hard NOT to have them synched with this setup actually. I need to re-synch again tomorrow since I adjusted the valves today, but before I did the valves today, they were synched both at idle and at 3,000 RPMs. |
May 29 2013, 08:31 PM
Yup, that setup stays synced.
Hmmm Did someone rebuild that motor at some point? Starting to wonder about the valve timing.... |
ThePaintedMan |
May 29 2013, 08:36 PM
Yup, that setup stays synced. Hmmm Did someone rebuild that motor at some point? Starting to wonder about the valve timing.... I dunno. I cannot recall ever really trying to push the car hard enough in the first year that I owned it and got it back on the road to even cause these symptoms to appear. It could be that it's been like this all along, but ever since I was getting it ready for the DE, the backfiring has been the bane of my existence. Rich, here's something interesting I noted today. The valve lash adjustment screws on the passenger side of the engine look pretty well adjusted in. As in, there are only a few threads left on them to allow me to continue to tighten them up. The drivers side seems to have closer to 4-5 threads showing on most of them. Not sure what that indicates, if it indicates anything. |
May 29 2013, 08:47 PM
May I suggest a slightly different way of adjusting your valves.
Pin the opposite valve wide open, then adjust the valve directly opposite that wide open valve. Then you know you are on the bottom of the lobe. If your ignition is correct, you have no manifold leaks, your linkage is setup, then it's back to the valve that may be opening to early for the intake stroke. I have never built a motor with the valve gear off by one tooth, but this may be the result. Try this. Go for a run once hot....take it down the street and come back towards the house in a low gear, as its backfiring.......run it like that for about 100 feet then shut it off. Do not let off the gas. Kill the motor at the higher rpm,s on the main circuit, not on the idle circuit. Then pull the plugs and rad them |
May 29 2013, 08:48 PM
Alternate would be to pull the oil pump and see if you have a stock cam gear, but even that could be put in wrong...
messix |
May 29 2013, 09:50 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
now that it is pulling good until the higher rpm i'm going with worn out/or broken valve springs.
type2man |
May 29 2013, 10:38 PM
Member Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I think I mentioned this before but have you tried swapping out the cap, rotor and wires. It seems to me like something is arcing and higher rpm. With the carb setup you have, you should have no problem revving unless there is a spark problem or even a distributor problem.
URY914 |
May 30 2013, 05:01 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,652 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Check your tire pressure.
URY914 |
Clean your windshield.
URY914 |
May 30 2013, 05:02 AM
Move your seat all the way back.
URY914 |
May 30 2013, 05:03 AM
Do your back-up lights work?
URY914 |
Check your heaterbox valves.
URY914 |
May 30 2013, 05:04 AM
Change your underwear.
URY914 |
May 30 2013, 05:12 AM
Try more brand in your diet.
ThePaintedMan |
May 30 2013, 06:33 AM
Don't forget the blinker fluid Paul!
carr914 |
May 30 2013, 07:40 AM
Racer from Birth Group: Members Posts: 121,608 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
How are your Muffler Bearings?
Lo-Fi Version | Time is now: 31st October 2024 - 10:27 PM |
