Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
ITB without filters
Attached image(s) ![]() ![]() |
Mark Henry |
ITB with filters
Attached thumbnail(s) ![]() Attached image(s) ![]() |
Mark Henry |
down the throat.
I am having issues with clearance of the fuel rail on the 1/2 side in the bug conversion. Most likely I'll have to cut a hole on the inner fender to clear it. then I'll have to make something to clear it. Attached thumbnail(s) ![]() |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Flip them, put the rail in the inside
Mark Henry |
Flip them, put the rail in the inside You really think I didn't try that? (IMG:style_emoticons/default/confused24.gif) It's been almost 2 months, so I looked at this again. Could I make it work flipping it around? Maybe, but I'd have to scrap the filter base and re-design it and then scrap the manifold or weld it up and re machine it. It's easier to re-deign (reprofile) the rail, the only part interfering and cut an access hole. The hole would only be under the fender and I can make a cover for it. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Mark, you need to place them so that air will past THROUGH them and into the engine, preferably to the intake part of the head. You can identify this by it being on top of the engine (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/poke.gif)
Mark Henry |
Mark, you need to place them so that air will past THROUGH them and into the engine, preferably to the intake part of the head. You can identify this by it being on top of the engine (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/poke.gif) https://www.youtube.com/watch?v=Qw9oX-kZ_9k |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,342 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Mark, Have you seen this - vwmegasquirt.tk and there is a guy out there named supaninjanick with a blog who has done this on a type 4 in a notchback using CBR 600 ITB's Cool project
Mark Henry |
Mark, Have you seen this - vwmegasquirt.tk and there is a guy out there named supaninjanick with a blog who has done this on a type 4 in a notchback using CBR 600 ITB's Cool project Looks good. I looked at using the cut off stock manifold but the bung is in the wrong place for a bug conversion, it would/could work in the type 3/4 or 914. In the bug conversion the engine surround (car bodywork) gets in the way. |
kevin311 |
Member ![]() ![]() Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None ![]() |
Please finish this!! For all of us that started and never finished.
My ITB project had to be sidelined so im glad there is someone else attempting it. Good luck and keep us updated (IMG:style_emoticons/default/beerchug.gif) |
Mark Henry |
I'll keep working it but it might be spring by the time it's done.
I used some scrap wood to make a stand so I can work on them a bit more hands free. Attached image(s) ![]() |
Mark Henry |
I did some re-profiling on the 1/2 side fuel rail for clearance.
Not sure how it's going....
But.... Have you considered bolting those throttle bodies directly to the head....? What is the downside of moving the throttle plate that close to the valve? |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,925 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Ya, what about cutting down the intakes?
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,211 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Question: is it better to have the injector nozzels High on the intake as with these TB's atop the intake runners or low nearer the port mouth like the OE intakes ?
TeenerTim |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region ![]() |
Question: is it better to have the injector nozzels High on the intake as with these TB's atop the intake runners or low nearer the port mouth like the OE intakes ? Always better to be close to the port. The atomized fuel has less of a chance to condense into droplets. It also provides better throttle response and low end performance. Think about driving a car with a tunnel ram intake. It takes time for the air to reach a good velocity so there is a huge lag. Not a problem if you are drag racing and dumping the clutch with a wide open throttle. Edit: This is still much better than the single plenum and long runners of the stock type 4. |
Mark Henry |
Question: is it better to have the injector nozzels High on the intake as with these TB's atop the intake runners or low nearer the port mouth like the OE intakes ? Also depends what you are going for, maybe emissions, but really on our cars I doubt if it makes a lot of difference. BTW also note that mine are going into a VW bug, there is absolutely no way of getting the injector closer to the stock location without cutting up the engine metal surround. Not going to happen. |
Are you doing ITB's on the six you are building.
Mark Henry |
Mark Henry |
It's alive (IMG:style_emoticons/default/thumb3d.gif)
Lo-Fi Version | Time is now: 20th April 2025 - 06:23 PM |
